Closed Thread
Old 04-10-2010, 03:02 AM   #1
phantomspeed3
Member#: 229894
Default not hitting boost targets
So I have an 04' WRX running blitz catback and tanabe divorced wastegate downpipe and an cold air intake, i am running stage 2 91 with my accessport and i'm not getting anywhere near boost pressures, i spike about 10.4 and hold about 9.5 or less, i'm pretty positive theres not a boost leak but i could be wrong does anyone have any ideas on this?
phantomspeed3 is offline
Old 04-10-2010, 03:44 AM   #2
bako
Member#: 226211
2002 impreza WRX JDM
blue
it's actuator pressure. if u have stock bcs check it, or borrow it from friend to test again. also check hoses for leaks. or maby your car is in limp mode? any cell?
bako is offline
Old 04-10-2010, 04:42 AM   #3
joec wrx
Member#: 112359
14 Challenger RT
I'm gonna take a shot and say it's your INTAKE. To my knowledge, the OTS map is calibrated for the stock airbox, however it will work with the Cobb SF intake ONLY. Try putting in your stock airbox and see if that fixes your problem.
joec wrx is offline
Old 04-29-2010, 10:02 PM   #4
phantomspeed3
Member#: 229894
so we had a boost leak check done and found that the intercooler to throttle body hose was leaking so we replaced that, then we replace the turbo inlet because that was leaking as well and ripped, now its still not hitting boost pressures so I just don't really know where to go from here, the boost control solenoid could be it but it just doesn't feel like I'm driving a turbo'd car it build boost very slowly only holds around 9 and will spike around 11 I need some ideas because the car ran like this when we bought it stock and after all the mods seems like it hasn't gotten any better at all, had an 02' did the same mods and no tuning and it ran way faster than this one and picked up alot quicker even when it was stock
Old 04-29-2010, 10:07 PM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
There are 90000 causes, all of which you can find by:
a. using the RIGHT FORUM
b. calling the maker of your engine management system
Unabomber is offline
Closed Thread
Not hitting boost targets in 1st or 2nd? HELPr AccessPort 3 03-09-2010 09:50 PM
CT Protune Not hitting boost targets, HELP! KmofugginD AccessPort 4 07-30-2009 01:49 PM
Cobb Stage 2 logs - not hitting boost target Drivinwest AccessPort 2 06-26-2009 11:51 AM
Perrin GT30R not hitting boost targets is it FBC or something else roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-15-2006 01:30 PM
Cobb stage 2... not hitting boost target level... WRXVII Engine Management & Tuning 37 06-06-2004 01:14 AM
