Old 06-04-2002, 12:11 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Injectors for a 2.2L NA engine?
I am going to be putting my turbo it on it soon and would like to up grade the injectors really cheaply while at low boost. I plan on running it at only 5 psi in the begining and then next summer getting rid of my piggy backs and going for an ecu and some big injectors. Would WRX or RS injectors work? I would think RS SOHC engine injectors would and WRX wouldn't?
Thanks,
Joshua
yebokmj is offline   Reply With Quote
Old 06-04-2002, 11:17 PM   #2
MPREZYA
SCIC
Member#: 85
I really wanted to try this before I removed everything from my car but you can use 98rs injectors as well as the ecu. You bump from IIRC 240cc injectors to 270-280cc injectors. Or if you really want you can use Legacy turbo injectors with the stock ecu which are 360cc-390cc but you will definetly need an SAFC and probably an ITC at minimum.
I just used a 4:1 RRFPR with my 5psi turbo w/fmic and it worked just fine. Also do a search under the user name WAC as he posted alot about this.
Rich
MPREZYA is offline   Reply With Quote
Old 06-04-2002, 11:37 PM   #3
yebokmj
Member#: 2213
Brilliant Red
Default Thanks
I have a Super AFR to control fuel. I want to avoid purchasing to much so that I can save for an ECU. I will see if I can't come by 2.5 injectors that i can borrow.
Thanks,
Joshua
Looking for a 2.5 NA engine and harness dalesalignment&brake Vancouver Impreza Club Forum -- VIC 17 08-21-2009 02:33 AM
2.2L NA engine speedyHAM Private 'For Sale' Classifieds 2 03-29-2005 08:46 PM
FS: WRX rear diff, half shafts, crossmember, 2.2L NA engine and some other stuff speedyHAM Private 'For Sale' Classifieds 28 02-19-2005 11:06 AM
2.2l legacy engine and 2.5l RS engine jetfan8178 Service & Maintenance 10 04-02-2002 05:47 AM
