Old 04-10-2010, 11:42 PM   #1
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
Default 2006 Impreza Sedan Speaker Install Question
Alright so right now I have the stock speakers installed in my 06 2.5i. I want to get these from Crutchfield: http://www.crutchfield.com/p_130TSG1...3R.html?tp=105
I have been told the mounting depth on an 06 is 2". Since these speakers are 1 and 11/16" deep does that mean that I don't need to use spacers to install these speakers? Can I just take the stock speakers out and install these without and modification?
Thanks in advance to anyone that can help.
subiedude676 is offline   Reply With Quote
Old 04-11-2010, 12:14 PM   #2
RootUsr
Member#: 39652
2007 WRX TR (UGM)
R.I.P d00m Wagon
make yourself some spacers for them. unfortunately the cutout diameter is a bit small for the kartboys...
Basically, the speakers are made to mount with 4 screws, your door is made to have speakers mount with 3 screws, the 'stock spacers' are actually part of the speaker basket, so good luck reusing those... you could probably get away with using a thin hdpe cutting board (rigid) for your spacers.
Amazon.com: HDPE (High Density Polyethylene) 0.25" Sheet, 12" x 24", White: Industrial & ScientificAmazon.com: HDPE (High Density Polyethylene) 0.25" Sheet, 12" x 24", White: Industrial & Scientific
that might work for you (I had to make some 3/4" spacers, which worked great, and I used a sheet of hdpe I got from them)
the 1'x2' should be enough to make 4 spacers (in case you screw up on 2)
RootUsr is offline   Reply With Quote
Old 04-11-2010, 03:45 PM   #3
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
Alright, thanks for the help with that.
I was chatting with a Crutchfield techs last night and from what he told me I get some kind of spacers with my purchase? I am guessing that I could also use them as well?
Old 04-11-2010, 06:47 PM   #4
Ash_J
Member#: 78125
07 WRX STi Ltd 128
Satin White Pearl
The Crutch should supply you with serviceable spacers that will fit correctly and do the job. That's why you're paying so much more than the stuff is worth, after all (j/k, btw; lots of people say they're overpriced, but warranty+support+install gear has got to be worth something, right?).
If you go the DIY route, use MDF or that HDPE cutting board (incidentally, thanks for that link, RootUsr; I'm gonna have to buy some of those to experiment with)...it's pretty easy to make your own spacers if you have a jigsaw and a bit of skill.
Ash_J is offline   Reply With Quote
Old 04-11-2010, 08:14 PM   #5
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
Alright that sounds cool.
Now how do I go about installing 5 and 1/4" speakers in the rear doors, instead of the 4" stock ones?
Old 04-30-2010, 04:20 PM   #6
AtomikSub
Member#: 216932
06 impreza hatch
blk
i just put 5.25`` speakers in the rear . i used 8 self tapping screws. pretty big ones.short but big. ...get some dual sided tape.go around the speaker hole with it about an inch width.i used that dual sided tape for a dampener.so its not metal on metal. worked good for me.
AtomikSub is offline   Reply With Quote
Old 04-30-2010, 06:09 PM   #7
JDAspenW02
Member#: 179875
2006 WRX
CGM
I have these in my 06 wrx and you dont need any spacers for it to fit. I had to drill a few new mounting holes because the screw placement was different.
JDAspenW02 is offline   Reply With Quote
2004 WRX sedan, speaker upgrade question wolfcri Car Audio, Video & Security 6 06-05-2010 11:34 AM
2006 impreza sedan tail lights JV03 Exterior/Styling 4 05-09-2010 01:26 AM
MY08 Subaru Impreza Sedan - Speaker size query MattKeaton Car Audio, Video & Security 3 01-09-2010 01:08 AM
WTB 2006 Impreza Sedan Foglight + Trim Candor Private 'Wanted' Classifieds 1 08-12-2009 01:11 PM
Picts of ~97 impreza component speaker installs. dexterous Car Audio, Video & Security 0 01-16-2005 10:52 PM
