Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 04-12-2010, 02:47 PM   #26
badvw68
Member#: 76166
68 STI Powered VW
Originally Posted by SCOOBY_ROO_2010 View Post
are you running the STI ECM?
No.... Im running the "EMS" system. http://www.emsnorthamerica.com/
The tuning seems to be right on, but I am needing a new bov it think!
badvw68 is offline   Reply With Quote
Old 04-12-2010, 04:49 PM   #27
tw000rs
Member#: 182102
02 WRX Aspen white
Built 257 07 STi trans
MAF sensor maybee?
tw000rs is offline   Reply With Quote
Old 04-12-2010, 05:41 PM   #28
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
there is no maf sensor ...
the stinger is a speed density ecu
few questions
-are you using a wide band 02 for tuning
-what are you using for "target" a/f at cruise/spool(below 5 psi)/above 5 psi
-do you have any sort of knock sensor
-what spark plug are you using?
- did you have to change the crank pick up between the ej20g (old engine which was 200,220 or 265ps not 165hp) and the new ej207
- did you rescale the injectors from [email protected] with the old engine to [email protected] bar for the new?
- what size of map sensor came with the stinger 2 or 3 bar?
sidenote - there is probably a market for the unused harness and ecu from the 207
Old 04-16-2010, 04:08 AM   #29
ALTRDTA
Member#: 161990
2000 Pontiac TA WS6
Black on Black
This is sick!
ALTRDTA is offline   Reply With Quote
Old 04-18-2010, 09:43 PM   #30
badvw68
Member#: 76166
68 STI Powered VW
So today I came across a factory OEM Subaru BOV and put it on.... WOW, now we are talking. Apparently the Greddy Type 2 that I have isn't worth a damn!
Now we are off to some of the small details that need to be tidied up and time to start tweaking the mapping.
Can someone help me out with the specs of the new "STI" motor that I have. What I know is this:
2001-2002 GDB JDM EJ207-T STI
Version 7
LHS20V006) LHS20V and RHS20V Heads
VF30 Turbo
Factory ECU was (22611AH191) - for sale soon
Is it true that it's pushing out almost 300hp in stock form, that it has forged internals? How much boost can this motor take safely? That it has a 8250rpm redline?
Thanks for the replys guys!
Old 04-18-2010, 09:46 PM   #31
badvw68
Member#: 76166
68 STI Powered VW
[quote=sidenote - there is probably a market for the unused harness and ecu from the 207[/QUOTE]
I have the ecu and the main wiring harness which I plan on putting in the for sale section soon. The "engine harness" I ended up using to make the harness for the Stinger EMS.
What is the harness and ecu worth?
Old 04-18-2010, 10:31 PM   #32
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
oh my God, that's an EJ207.
All of the above is true.
Oh my God.
XanRules is offline   Reply With Quote
Old 04-18-2010, 10:33 PM   #33
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
two questions.
1. Why did you put the radiator in the cabin?
2. What did you use for a transmission?
Old 04-20-2010, 12:27 AM   #34
Ham221
Member#: 243233
2003 wrx
wrb
question...how would the intercooler get air???
Ham221 is offline   Reply With Quote
Old 04-29-2010, 11:06 PM   #35
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Nice build. I am in the process of putting an 04 STi in a Meyers Manx with 930 transmission. Same radiator up front. Thanks for the inspirational viewing...
RSti_Spyder is offline   Reply With Quote
Old 04-30-2010, 11:48 AM   #36
Sububoy09
Member#: 222567
2000 2.5RS
Sedona Red
haha, this is great!!
Sububoy09 is offline   Reply With Quote
Old 05-02-2010, 12:03 PM   #37
badvw68
Member#: 76166
68 STI Powered VW
Hey Guys,
I have had the car running for about a month now, and boy is it fun!!!
I do have a few quesitons, I have a bit of an oil leak and want to verify that both of these ports off the block are infact case vents... Please let me know. I know the previous EJ20 that I had did not have the one closest to the center of the engine. Where do these go in a factory application?
Thanks for the help! Alden
Old 05-02-2010, 03:02 PM   #38
04wrexsti
Member#: 225937
15 Mustang GT
All subies gone
ive always wanted to do a project just like this.. good work man!
04wrexsti is offline   Reply With Quote
Old 05-07-2010, 09:08 PM   #39
STiGuy23
Member#: 215108
02 rex sti and jdm
flat black stealth mode
yo ive got an 02 wrx with an ej257 swap and for the extra vent i just teed it into the other. np
STiGuy23 is offline   Reply With Quote
Old 05-24-2010, 12:13 AM   #40
badvw68
Member#: 76166
68 STI Powered VW
Does anyone have any EMS Stinger maps for the EJ20T's or know where I can find some maps. Prefferablly some the have benn derived from dyno tuning? Thanks!
Old 05-24-2010, 12:19 AM   #41
pezcore
Member#: 178045
06 WRX
CGM
that crazy box connecting the TC to the IM kills me; weld a pipe!
Awesome project though!
pezcore is offline   Reply With Quote
Old 05-24-2010, 12:37 PM   #42
TheLordChesterfield
Member#: 234539
Something I noticed - the exhaust is really close to the timing belt cover. Hopefully no damage occurs! Could be dangerous....
TheLordChesterfield is offline   Reply With Quote
Old 05-28-2010, 08:30 PM   #43
CatfaceType-R
Member#: 81102
extremely bad ass setup, I am not sure about that crossover pipe port, if i am not mistaken..i think our usdm engines don't have that port..i will do some research and get back to you..
did someone tell you to get the oem bov(it's actually a by pass valve) or did you figure that out intuitively? if so, you are one smart man as the bov's aren't setup in 50/50 form, the usually vent 100% and don't recirculate back and that's why your ecu was tripping out
CatfaceType-R is offline   Reply With Quote
Old 05-28-2010, 10:18 PM   #44
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
that center port is a direct vent for the crankcase but since you have the others you can just cap it off like everyone else does on hybrid builds.The port by the turbo is where the sti has the pcv connected to,the pcv is a plastic three port piece that is about 10.00 at the dealer.I hope this helps.^^^^he does not need to recirc the bov his stinger ecu is speed density --the maf is gone.
john 1badSTI is offline   Reply With Quote
Old 05-29-2010, 05:03 PM   #45
CatfaceType-R
Member#: 81102
ahh that's right, I wonder why it still made the car happier ?
Old 10-25-2010, 09:20 PM   #46
badvw68
Member#: 76166
68 STI Powered VW
Long overdue for an update....
We last left off back a number of months ago, I drove the car 2hrs north to Effingham Il, on Sat evening after work. About an hour on the interstate, I had to pull over as I noticed that the car was slowly getting hotter. This told me alot about what is needed in the future regarding the cooling. I pulled over at a rest area and started playing with the Stinger on the laptop. For some reason, the fans weren't triggered to come on, so I changed the values and we were up and going again. I think the ambient temp was pushing 100F that day.... None the less, I had previously installed some tempory "scoops" to direct the air flow from beneath the car up to the radiator. Considering that I was needing the fans to run down the interstate tells me that I am in need of possibly better ducting, larger radiator, or something I haven't thought of yet.
I continued up the road in time to meet up with a buddy that has a VW Buggy with an EJ20T and a bunch of other guys at a resturant. After talking vw's, subi swaps, our two cars specifically, I continued an additional 20miles north to stay the night with my friend at his house. Well, during this little trip, I sprung a leak in the radiator, but was able to make it. Unfortunately, one of the radiator fans rubbed/vibrated a hole in the cooling passage of the radiator, and was leaking tremendusly by the time I got to his house. Pic below is the antifreeze leaking on the exhaust.
I called around to all the parts stores trying to find a radiator out of a 6cy Jeep Cherokee (this is the rad. I am using) and ended up finding one. Due to the time of everything, later I replaced the radiator and drove 2.5hrs south home with no problems.
That very next day, the 2010 Hot Rod Power Tour came thru my area, only 20mins away in DuQuoin Ill, they said there were over 3000 cars on display. I headed up there that afternoon in the VW, showed the car, noticed from the distance spectators pointing to the engine compartment in disbeleaf
The Highlight - On my way home from the show, I was sitting at a stoplight on the outskirts of town (immediately turns to 55mph and not another stoplight, entrance or exit for 2miles) and up next to me rolls a 69 Camaro. Now let me tell you, this was one badass car! Silky smooth paint, lowered with larger rims and low profile tires, and I dont know for sure, but possibly a big block! It sounded everybit as good as it looked! Now my heart is racing, my palms are a bit sweaty, and I look over and rev the VW waiting for the green light. He looked back with a smile - probably thinkin what a joke! The funny thing was the joke was on him!!!! The light turned green, I let the clutch out aggressively but not side stepping it ( I still have the factory orginal 1968 VW Tranny) he had a bit better reaction time was just a bit ahead. I then immediately put the pedal to the floor, shifted to second and all of a sudden I am looking at his headlights out the passenger rear window, threw it into third and I couldn't believe it, I am now seeing his headlights decending in the rear view mirror, into fourth for a bit and decided that was it!!!! I am now in disbelief but yet also have the biggest smile on my face... It wasn't even close, I must have been every bit of 50ft ahead of him, yet right off the line, he was 3ft or so ahead of me... As I slow down, now cruising at 60ish mph he pulls up beside me, shakes his no and gives me a thumbs up. He then pulled off at the next light and went to the hotel as I continued on. I couldn't help but think, did he just get back to the hotel (parking lot was full of old cars) and tell his buddys what had just happened, or not say a word? Either way, its pretty funny! Who would ever think while driving a old hopped up Camero, that an old VW Bug would spank them.
That following week, My Father came to visit, and was anxious to go for a ride as I had told him this story and how well the car was running. We go for a small little ride, to get the engine up to temp, I pull out of my subdivision and romp on it, shift from 1st to 2nd and BANG!! there went the trans! It now has no forward or reverse gears. Due to how busy I have been, I pushed it into the garage where it has sat ever since. I am planning on getting a Rancho Trans this winter and replacing the tranny.. Its a never ending project!
At the rest area trying to figure out why the cooling fans aren't kicking on
Pulling into my buddies house, antifreeze driping on the exhaust
At the Hot Rod Power Tour 2010
Dad and I pulling out, a few minutes later, the trans blew!!!
Old 10-26-2010, 01:05 AM   #47
icanfly
Member#: 176929
2005 STI Powered Dub
Carbon Black
Nice project.
I am dropping an 05' sti powerplant into a 1969 VW BUG IRS chassis at the moment.
Running it through a fully built porsche 901 5spd in order to hopefully avoid what has fallen your poor car...
Your doing great work, stick to it.
Looking forward to hearing about it more.
Thanks for sharing.
icanfly is offline   Reply With Quote
Old 11-02-2010, 03:19 AM   #48
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Pretty badass man!
I would worry about ****ing up the header and oilpan though, they look like they sit REAL low. Any way to make some kind of skid-plate to protect the engine?
Also very jealous of your engine.
OrbitalEllipses is offline   Reply With Quote
Old 11-02-2010, 04:20 AM   #49
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Put your engines in the for sale forums.
silver arrow is offline   Reply With Quote
Old 11-02-2010, 10:15 AM   #50
Master slacker
Member#: 249916
1970 VW Bug
My dad and I are considering the swap to either a 205 or 207. The current 1641 being rebuilt needs a few heli-coils installed, so it's time to tear down again. Does anyone know whether a 207 can be used with a 205 ecu and rewired harness? 205s in my area run steep, but an ecu / harness are relatively cheap. Just want a comparison with the cost of the Stinger eco 4.
Master slacker is offline   Reply With Quote
sti swap into a gc8 almon23 Subaru Conversions 2 01-27-2005 12:19 PM
sti swap into RS ImprezaRSfan! Subaru Conversions 5 04-20-2004 02:40 PM
AC lines after V7 sti swap into a wrx.. cronic Subaru Conversions 3 02-20-2004 10:16 PM
Can a new age ver 8 STI swap into a GC8?? bebeGDB Subaru Conversions 12 01-20-2004 03:21 PM
04 STI swap into gc8 need4gforce Subaru Conversions 16 11-12-2003 11:51 AM
