Old 09-13-2012, 04:32 PM   #26
68Cadillac
Member#: 95901
Originally Posted by Paidfor View Post
What your ROM cells say and what the ACTUAL AFR is....is a different story.
I've seen that. You may need to redo your MAF table and/or Injector size in the ROM. Once I get my MAF and Injector dialed in the AFR measured by the wide-band is usually +/- 0.2 from Target AFR.
68Cadillac is offline   Reply With Quote
Old 09-13-2012, 09:01 PM   #27
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
All those quotes say nothing of it being every car in that range. In fact they say words like "generally" and "should" and "most." That leaves quite a bit of wiggle room to completely negate your argument.
Just because they all say the same thing doesn't mean it's proof either.
And I've never heard of a car's commanded being the same as actual WITHOUT a tweaked tune for that exact thing... but this also in no way means it can't happen. Just that "most" "generally" "should" fall in that first group.
ProfessWRX is offline   Reply With Quote
Old 09-13-2012, 09:05 PM   #28
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
My car actually did the same thing. I am using a stock meter in a stock box, with stock injectors... And I always see a richer mixture than the Target AFR.
Black94Snake is offline   Reply With Quote
Old 09-14-2012, 12:44 AM   #29
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Large scale manufacturing with many precise electrical parts, there is going to be some drift car to car but only one rom so the tuning has to accomodate all the expected variance.
You also have to remember there are no absolutes when trying to compare between different engines as design plays a big role. What works for a 4g63 is not going to work the same for a turbo EJ engine. Evo motors tend to run leaner (closer to 12/1) than EJs, but they also run less timing and have longer strokes and higher compression. A friends 951 turbo Porsche runs 12/1 under boost and has no problems because that engine is OK doing that.
And I would not look at what commercial tuners as the "best way" either, they have to cover their bases since customers blowing up motors is bad for business. Better to be richer and more conservative than risk a broken piston trying to eek out a touch more torque. I am always more conservative tuning others cars than I am my own, I keep a close eye on everything and my CEL flashes if I get knock but I know most normal people will just keep going if there is a problem.
lukeskywrx is offline   Reply With Quote
Old 09-29-2012, 01:06 AM   #30
Airboy
Member#: 72829
2006 WRX
2015 WRX
I will throw in a couple of "data points" here.
Background info:
-gas is 94 octane with (up to 10%) Ethanol
-Wideband is in the (Cobb) Downpipe bung
-Injector scalar is used to change AFR
First plot: Injector scalar changed by 5%.
Second plot: Injector scalar changed by 3% and then back (to check repeatability). This group of plots is not directly comparable to the set above as the ignition curves are slightly different.
Airboy is online now   Reply With Quote
Old 09-29-2012, 02:26 AM   #31
Alistairh
Member#: 268286
2011 STi
Dark Grey
in the second set of plots, are you running more advance?
It seems like what was mentioned originally can be true, and that a slightly leaner (~11.5:1) AFR seems to make (slightly) more peak torque.
However I think there is a lot more at play here on modern engines with AVCS and variable ignition timing. It's not like the earlier days of EFI where more values were static, and the AFR was really your only way to generate power.
But I'm probably just stating the obvious Awesome thread though!
Alistairh is offline   Reply With Quote
Old 11-09-2012, 09:16 AM   #32
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
I just saw this thread and wanted to add my findings. Although I messed with this years ago, my finding was that although a leaner afr produced more power, it wasn't enough to make me want to run a lean afr, even on race fuel.
The car was a n/a mustang gt. No ecu just straight carb for afr and distributor controlling advance. I started at 13.0, 12 and 11 afr. The power difference was slightly less than 10 hp going from 13 to 11 afr. That's with no timing added or subtracted due to timing controlled by rpm's and the distributor.
On same car same day I ran 12 afr and added 4* advance to the distributor and picked up close to 40hp at the wheels. So timing plays a lot larger role in producing hp than afr ever would.
To me its not worth tuning to a lean afr to produce power, go rich and find a good balance between boost and timing to make power on whatever octane fuel your running.
fastblueufo is offline   Reply With Quote
Old 11-09-2012, 11:18 AM   #33
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
For anyone that says leaner AFR's are ok....especially leaner AFR's and LESS timing....I would love to see EGT data on that. Even going from 11 to 11.5 can increase EGT's ~300-400*.....now you start taking away timing its going to increase ~50* with every degree.
I've had an EGT gauge in my wrx since 2003 and in my STi since 2006 and have never found any leaner tuning strategy be EGT friendly. Or even make enough extra power to be worth the diminishing safety net.
And as far as the places that post up 11.5-12 AFR plots in PPB.....i ask everytime i see one what the EGTs were on the car and the answer everytime has been "the car didnt have a gage".
From my pov tuning to 10.8 and having a nice EGT safety window available if the car develops a leak and leans out to 11.8 a much better strategy than tuning the car to 12:1 and having it lean out to 13:1 during a leak and melting holes in the pistons.
And as someone already mentioned.....heres a JDM Version8 fueling map....8.88 Targets.....how do the people that always bring up washing cylinder walls and getting fuel in the oil explain how stock subaru motors survive the stock fueling mapping?
Old 11-09-2012, 03:21 PM   #34
fastblueufo
Member#: 212154
02 billet crank
@phatron- keep on tuning brother. I feel the same way about afr tuning unless your just after every ounce of power. Even trying to use afr to speed up flame propogation is rather pointless. As for egt, I've always looked at having two types of high egt. One from leaner afr and one from retard timing with the latter not being of much harm to the engine.
With regards to the fueling table, those are not target values. Those values are only enrichment or enleanment of the base fuel curve set by the maf scale. They could have scaled the injectors and maf to different values and made the table more accurate to actual afr values. I think they could have accomplished the same goal by making the maf scale a 3d table.
I think a whole different team of engineers tuned the jdm cars from the rest as most of the jdm tunes look to use a different strategy than say the usdm tunes. Even though the fuel is a better octane in japan, you can just tell that a lot of the tunes were done with a different mindset.
Ed
Old 11-09-2012, 03:25 PM   #35
Phatron
Member#: 36033
CEO PhatBottiTuning
yeah...with regards to the JDM mapping its amazing how smooth and perfect some of the timing, boost, fueling and avcs are in various roms....compared to how ours look like 2 monkies were ****ing on a keyboard.
Old 11-09-2012, 03:38 PM   #36
reid-o
Member#: 103631
2004 STI
Wouldn't the safety window depend largely on the EGBP? I don't notice such swings in EGT when I'm playing with a lot of the bigger turbine turbos like the 6266 and the 35r as compared to a 60mm turbine on the 30r or a stock location turbo with a smaller A/R, which I try to keep to the guidelines that you both suggest here. I noticed that most of the larger turbines and a/r turbos drop egts too much below 11:1 to the point where I need to increase timing to bring torque back up. I've found that 11.2 or near 11:1 seems to produce a bit more torque on the larger turbines. I do try to stay below 11 if the car is running some type of 63 housing or some strange hybrid turbo.
reid-o is offline   Reply With Quote
Old 11-09-2012, 03:53 PM   #37
ecbmxer
Member#: 228059
2010 WRX
Spark Silver Metallic
If we're still talking about the OP's statement, I think it's the difference between best in theory and best in practice. I haven't read that book, but the theoretical "best" AFRs are probably based on some ideal calculations of in-cylinder pressure or heat release. It may not even take into account using a liquid fuel and all the complex mixing that goes on (lots of times iso-octane and n-heptane are used in place of gasoline or diesel in numerical calculations). I would trust the advice/experience of the known tuners who commented above over theory of a generic engine (unless he has some nice CFD models with reacting flow and heat transfer).
ecbmxer is offline   Reply With Quote
Old 11-11-2012, 04:12 AM   #38
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
I have done several AFR tests on a LOAD based Dynapack and my conclusion was when running PUMP Fuel (RON98 ~ MON93) that best Power was around 11 - 11.5 AFRs. I tried leaning out as lean as 12.2 and got no extra power but more knock activity. I tried richening up in the hope to be able to add more timing and gain more power but that didn't work out. I went as rich as 10.4 AFR and instantly lost 40 BHP. There was no way timing was going to recover that.
On a TMIC I would use 10.8 ~ 11.2 AFRs thereabouts.
On a FMIC I would use 11.2 ~ 11.5 AFRs thereabouts.
There is typically much more Torque/Power to be had from properly dialling in AVCS on a LOAD based dyno than playing with AFRs.
My 2 cents,
Jasper.
jkopinga is offline   Reply With Quote
Old 11-11-2012, 10:17 PM   #39
reid-o
Member#: 103631
2004 STI
My 2 cents,
Jasper.
I hoped that this isn't too off topic, but when doing your tests with the tmic and fmic, what was your final strategy for iat compensation for timing? With the temp sensor in the end tank outlet I'm not clear on what to set the compensation to. I've tried the following strategy: 0 out the compensation and tune for best torque while watching heat soak. I let the sensor come back to baseline before pulls, the temp of the first pull. Sometimes it takes quite awhile. I note the average peak temp from logs and then pull 2 degrees for ever 5 degree rise past the noted peak temp and start applying the compensation from then on.
Anyone else have a better strategy other than constant logging in daily driving?
Old 03-26-2014, 02:13 PM   #40
grangepack
Member#: 375989
97 ej207 v9 gf8
Originally Posted by NSFW View Post
For example:
I hope that means you can show us a couple of your own dyno sheets, showing how much more power you were able to get with 11:1 vs 12:1. Because that would be awesome.
I've seen a couple of his dyno sheets (via email) showing 12:1 on pump gas and totally reasonable power. And I've seen other tuners post dyno sheets showing 11.5:1 or leaner, here on NASIOC, and get raked over the coals for allegedly making time bombs out of their customers' cars. We all know exactly what would happen if he posted in PPB.
There are people in the world who crave the respect and admiration of the pseudonymous masses of NASIOC, and there are people who don't. Why would you expect someone in the latter group to even thing about posting something contentious here? It's not going to happen, and frankly it makes me wonder how much interesting, useful stuff doesn't get posted here because of the way NASIOC reacts to anything out of the ordinary.
Nobody is questioning that fact. Least of all me. I heartily agree that a search of the dyno sheets posted here will show damn near all of them right around 11:1. And that's why I tuned my own car to 11:1.
But that fact only indicates that 11:1 is popular. And that only tells me that its probably pretty safe.
I do remember seeing one post where a tuner with one of the bigger companies (Cobb or Perrin, I think) said that there was no measurable loss of power until the mixture got down into the mid 10s, or something in that range. But that is the only thing I've seen here (or at RomRaider) where someone described trying multiple AFRs and studying the results.
Let me be clear about something - if I thought 12:1 had a very high probability of making more power with no more risk, I would have at least tried it by now. By my guess is that if there are gains, they're small. And i have no idea what the risks are. And I'm too chicken to experiment with my own motor, so I'm following the crowd on this one, and I'm OK with that.
I know that there are plenty of people who say it's horribly dangerous to run 12:1 at WOT with pump gas, but there are also plenty of people who think that PTFB makes your motor lean out because there's "too much air." Or, you need a tune to safely run a TBE on any Subaru other than the STI. And so on. You know as well as I do that there's a ton of misinformation in this echo chamber. I believe nothing I read here, until/unless I've seen it tested, or better yet tested it myself.
"Everybody does it" is not particularly persuasive, especially in an environment where people are routinely ridiculed for doing unusual things, and more especially when I know a guy who looks an awful lot like a counterexample to the conventional wisdom.
I know you're one of the few who thinks outside of the box around here (I'm running your MBC+BCS setup, for example), so your reaction to this question really caught me by surprise.
Now that's real talk....
About to try out a 91octane map with 11.5 afrs. Coming from a tune that had alot of mid 10s. This scares me abit..
grangepack is offline   Reply With Quote
Old 03-08-2015, 07:34 AM   #41
Marek0086
Member#: 415393
Being ignorant is one thing... but being ignorant on a topic and running your mouth as if you know what you're talking about... is something much worse!.
I came across this thread by accident. And i just couldn't leave without saying something about all the bull**** being spewed on these forums when it comes to engine tuning.
Here are the cold hard facts... for all you morons who actually tune engines for money... and should know better. IF you need to run a RICHER AFR than 11.5:1 to ward off detonation... EITHER, your boost is too high... or... you need more octane... or... you need to retard timing. THATS ALL THERE IS TO IT!.
Marek0086 is offline   Reply With Quote
Old 03-08-2015, 08:26 AM   #42
quazimoto
Member#: 70395
Oh the irony...........
quazimoto is offline   Reply With Quote
Old 03-08-2015, 01:14 PM   #43
Marek0086
Member#: 415393
Yes... you're exactly the kind of dumbass i was alluding to.
Old 03-08-2015, 01:40 PM   #44
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Hardly. Too little timing can cause a knock like event. High IATs can cause knock... etc etc. There are several other reasons to which YOU are clearly ignorant to.
Sent from my SCH-I545 using NASIOC mobile app
Old 03-08-2015, 01:53 PM   #45
Marek0086
Member#: 415393
****!... you take the cake for all time dumbass on this thread!
Too little timing does NOT cause knock. And "knock like event" is just some bull**** that you just made up!!.
If you knew ANYTHING... you would know that "too much boost" incorporates too high an IAT. F uck off outta here *******... you're the EXACT kind of ****-talking dickhead i was alluding to.
Old 03-08-2015, 01:55 PM   #46
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You might want to go speak to people like Ron and M@.
Old 03-08-2015, 01:59 PM   #47
Marek0086
Member#: 415393
And YOU might want to go speak to someone who actually knows what they're talking about!.
Old 03-08-2015, 02:01 PM   #48
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
So you seriously found it necessary to join here, and post... just to be an *******? Seems as though YOU have more problems than I.
Old 03-08-2015, 02:16 PM   #49
Marek0086
Member#: 415393
Yes... im sick of dumb asses talking BS!!. And continuing the spread of BS throughout the internet!. So until you, and every other as s hole on here, actually LEARN... and UNDERSTAND the Physics of combustion dynamics... KEEP YOUR F UCKING MOUTHS SHUT!.
Old 03-08-2015, 06:49 PM   #50
Illicit1
Member#: 68372
Sounds like you're pretty confident so, rather than just swearing, why don't you school us in how to tune fuel in a Subaru?
Whats your background?
Illicit1 is offline   Reply With Quote
PA: Prosport oil temp, oil pressure, afr/battery voltage gauges and more MRF582 Interior/Dressup/Audio & Security 13 02-25-2010 12:53 PM
Your setup and ignition adv. @ peak torque and redline wittmer25 Built Motor Discussion 15 07-11-2008 07:40 PM
FS: Green Innovate DB digital AFR gauge WRX match and a few Maddad gauges Cyclops Interior/Dressup/Audio & Security 5 05-13-2008 01:04 PM
how much torque and hp from spt intake and heatshield? blacksti07 Newbies & FAQs 23 04-20-2008 02:03 PM
Torque and HP Curves Kenneth Stolz Normally Aspirated Powertrain 0 03-09-2001 02:07 PM
