Old 04-11-2010, 04:18 PM   #1
Blue_Rex
Member#: 236954
2010 WRX Base
Default Perrin Subframe Lockdown System (SLS) on 2010 WRX Sedan
I'm sure there is a similar post around here, but I figured I would add this since I couldn't find one to merge/comment on.
Install went exactly as described in the instructions and on the Internet. Loosen the 4 19mm (not 17mm) bolts as the instructions say, remove 14mm bolts, remove front 19mm bolts and install front bushings and bolts, install remove rear 19mm bolts and install back bushings and bolts, torque to specifications. Factory catback was not in the way, extensions required to reach everything, but no issues at all. I am a stickler for detail and made sure the rounded end of each of the bushings fit into the factory bushings, and the flat side against the metal washers.
Actual review:
NVH - Minor increase. I probably won't notice after a few days of driving.
Take off and driveline slack - Takeoff seems a hair snappier. The mod appears to have made driveline slack/lash from factory transmission/engine mounts more apparent.
1st-2nd shift - Significant decrease in 1st to 2nd thunk, but not completely gone when you hit it. But it also doesn't sound like your rear-end went supersonic anymore.
Once I get this thing on I95 tomorrow I may add some additional details and how I feel about how worthwhile the mod is.
________
Head shop
Blue_Rex is offline   Reply With Quote
Old 04-11-2010, 09:27 PM   #2
gsrcrxsi
Member Sales Rating: (7)
Member#: 236952
2010 WRX
Spark Silver
link to the system? is it just some bolts? is this similar or the same as the "botox" bolts?
gsrcrxsi is online now   Reply With Quote
Old 04-11-2010, 11:04 PM   #3
Blue_Rex
Member#: 236954
2010 WRX Base
http://www.perrinperformance.com/pro...ry=68&model=23
I have to add; packaging is top notch...they seem like a solid business. They even included a pair of Perrin stickers for the car.
________
BAG SYSTEM HERBAL VAPORIZER
Old 04-12-2010, 12:53 AM   #4
BlackFighter
Member Sales Rating: (12)
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Your kidding me right? Perrin has been around for years and yes they are a solid company, not business. They are nothign new my friend. I have a lot of theit stuff. One of the best for our cars. Anythign they make is top notch and will last for a lonf time. They are one comp that i trust having stuff stuck under my girls skirt. (My car if you have to ask)
BlackFighter is online now   Reply With Quote
Old 04-12-2010, 11:27 AM   #5
growling_boxer
Member Sales Rating: (4)
Member#: 165744
2000 LGT
2007 STi
that's debatable, but I would trust their bushings.
growling_boxer is offline   Reply With Quote
Old 04-12-2010, 11:02 PM   #6
Blue_Rex
Member#: 236954
2010 WRX Base
Here is some followup info over 100 miles later; still feels a bit snappier and tighter. NVH is similar to what you would feel if you over inflated your tires a little. You hear more on bumps on the road, but overall nothing to complain about. A good mod for the money.
DIY Perrin Rear Differential / Subframe Lockdown System PERRIN_Ken NASIOC Project Cars 154 01-22-2012 01:55 PM
Perrin Differential Lockdown System Question Blue_Rex Transmission (AT/MT) & Driveline 1 05-30-2010 09:00 PM
FS: PA: Perrin subframe lockdown kit. bisonjr MAIC Private Classifieds 4 10-14-2008 08:32 AM
FS: Perrin Subframe Lockdown Kit. bisonjr Drivetrain 0 10-13-2008 04:52 PM
Brand New Powerslot front rotors for STi + Perrin Subframe lockdown Ozer Suspension/Brakes/Handling 7 01-20-2008 08:08 PM
Message Board Statistics All times are GMT -4. The time now is 10:33 PM.
