Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 04-12-2010, 12:53 PM   #1
akplaaya
Member#: 239954
2005 Rex
Default Heat wrapping up and down pipe
I have an 05 wrx looking to go stage 2. just wondering if there is any benifit to heat wrapping the up and down pipe with heat tape? see some with and some with out.
akplaaya is offline   Reply With Quote
Old 04-12-2010, 01:46 PM   #2
Blue06RexWagon
Member#: 208897
2006 WRX Ltd Wagon
I heat wrapped my DP before installing it. The advantage is that it significantly reduces engine bay temperatures and therefore reduces heatsoak of your TMIC. I don't know how much difference it really makes in terms of power. If you already have the pieces out of the car you might as well do it.
Blue06RexWagon is offline   Reply With Quote
Old 04-12-2010, 02:13 PM   #3
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I'm going to take a stab and also say that it keeps the heat in the exhaust gasses and improves velocity?
Subian is offline   Reply With Quote
Old 04-12-2010, 02:16 PM   #4
WRBlueGDB-F
Member#: 170013
2006 WRX
VF39'd PDX Tuned
If you decide to heat wrap, buy some large hose clamps to hold it in place.
They work much better than the metal zip ties.
WRBlueGDB-F is online now   Reply With Quote
Old 04-12-2010, 02:23 PM   #5
Penguin_02
Member#: 180460
02 WRX
i recall reading somewhere that heat wrapping parts may reduce life on the part.
http://forums.nasioc.com/forums/showthread.php?t=445812
Originally Posted by Unabomber View Post
Downpipe FAQ
What about ceramic or other heat wrap coating? Though there are pros and cons to heat retention treatments with exhaust components, the general consensus with headers is that heat retention benefits outweigh the liabilities.
Pros:
Increased heat retention, which is beneficial for exhaust flow.
Reduces underhood temps, which decreases IC heatsoak.
Cons:
Additional expense.
Additional lead time, in the case of coatings.
Increased heat retention, which in some cases, can accelerate metal fatigue, especially at weld joints.
No proven HP increase.
If you plan on using a coating, ensure you are aware of what impact this will have on your header warranty if applicable. Coating or wrapping your header can void exhaust component warranties. If using a ceramic-type coating, ensure it's working heat range is above the known EGT. EGTs can be as high as 1400-1600 degrees in the extremes. Some normal coatings are not rated to this temperature level.
What types of ceramic or other heat wrap coating are available? The two most popular manufacturers of heat wrap are Thermo Tec and DEi. The two most popular coating manufacturers are Jet Hot and Swain Tech Coatings. Wrapping is a DIY project with a shorter life span than the professional only coating with a longer life span.
Excellent coating thread
.pdf file on coatings
Car Craft magazine's testing of Jet Hot
Penguin_02 is offline   Reply With Quote
Old 04-12-2010, 02:27 PM   #6
WRBlueGDB-F
Member#: 170013
2006 WRX
VF39'd PDX Tuned
^^^That's because many aftermarket headers are prone to cracking.
Old 04-12-2010, 03:06 PM   #7
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Yes and No. There are many pipes that do crack under extreme heat, very unfortunate thing. The goal is to get good welds, thick flanges, thick pipes that fit great, so no extreme pressures are put on the pipes.
When wrapping these pipes many people wrap over flex sections and this is a big no no. Retaining that much heat in a flex section can create problems for sure. If you are that worried about it you could always go the route of ceramic coatings.
Will
GrimmSpeed is offline   Reply With Quote
Old 04-12-2010, 04:28 PM   #8
akplaaya
Member#: 239954
2005 Rex
so i take it then heat wrapping is somewhat good to do on a dp and up then. there isnt like a tape type wrap or just have to use hose clamps on each end?
how much heat wrap will it take to wrap headers and down pipe jeremywrx15554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-29-2008 02:03 PM
turboxs up and down pipes and CEL's BillS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-28-2004 06:16 PM
Is there any downside to wrapping the up and down pipes? LarryW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-14-2003 11:06 PM
is it ok to have a 3" up and down pipe? and go 3 all the way back? gokou006 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-25-2003 09:00 AM
Minnam turbo peeps check your heat wrap on the down pipe Andre Vandenberg Normally Aspirated Powertrain 2 02-19-2001 08:42 AM
