Old 04-12-2010, 05:47 PM   #1
lotarg
Member#: 90940
Default Anyone have first-hand experience with Tokico D-Specs on road courses?
I have read around, and was going to go with Koni struts for my daily driver that sees about 2 track weekends a year. However, I do not feel like chopping up stock struts for the inserts, so I am looking at the Tokico D-Specs. I know they have a good reputation, but the Konis are superior for road course use while maintaining a comfortable ride on streets.
Will I notice a significant disadvantage with the D-Specs compared to Konis? Has anyone driven these on a road course on the stiffest settings and can comment on how they take high-speed corners?
I am not interested in coilovers because of the cost/maintainance/ride quality.
Thanks.
lotarg is offline   Reply With Quote
Old 04-13-2010, 04:59 AM   #2
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
What springrates are you using? Konis are rebuildable and need to be rebuilt periodically just like any full coilover system. Very dependent on how hard you abuse them.
Dubstar112 is offline   Reply With Quote
Old 04-13-2010, 01:14 PM   #3
lotarg
Member#: 90940
High rates... I am giving Vogtlands a shot.
Front: Initial 125 lbs, Final 302 lbs
Rear: Initial 91 lbs, Final 360 lbs
Old 04-13-2010, 07:02 PM   #4
vzezera
Member#: 61312
2009 sti
I used tokico d-specs on my old wrx wagon. They worked well on road courses, while being very good daily when you turned them down. I had rce wagon springs on the wagon. One of the stiffest springs you could get for a wagon... they worked best about 2 turns from full stiff. Full stiff was too strong... I think the rates were high 200's around 280 290 I think. I had camber issues as it was a wagon and the track was narrower. If the camber bolts did not slip every track day I would have been super happy with them. If you do not have a wagon and can get stiff springs I think they are very good.
vzezera is offline   Reply With Quote
Old 04-13-2010, 07:30 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I have setup customers' cars with dspecs and springs and have driven a few on track and have always thought it was a good setup. It reacts well to bumps and keeps the car on track. They also last a very long time and are incredibly adjustable meaning they can handle many different springs rates. The rates you want to run would be no problem for them, but I would look at different springs with more appropriate rates.
The only thing about the konis that is nicer is the warranty. The dspec warranty is a pain and takes forever. That being said the dspecs tend to last longer especially at lower ride heights.
Tony
Old 04-13-2010, 09:45 PM   #6
lotarg
Member#: 90940
Thanks for the info. How much longer do they last?
First hand experience with 225's on RS Wheels REX8 Tire & Wheel 4 03-08-2006 12:31 AM
First hand experience with Phantom Grip in WRX front diff? mbtoloczko Transmission (AT/MT) & Driveline 14 01-10-2006 11:49 PM
Anyone have first-hand experience with Kosei K1 Racing wheels bending? gypsymoth Brakes, Steering & Suspension 7 09-27-2002 12:25 PM
Anybody have first hand experience with the Vishnu AND UR Crank pulleys? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-11-2002 01:21 AM
First hand experience with MRT mufflers? dvancleve Normally Aspirated Powertrain 6 09-03-2001 02:10 PM
