Old 04-12-2010, 05:03 PM   #1
Adrenalinecrisis
Member#: 84519
2005 LGT wagon
Default HELP turbo sounds weird and not hitting peak boost
Recently my turbo has been making a lot more noise than normal. Also, i'm only hitting 13 pounds when i was hitting my peak of 16.5 a couple weeks ago. Boost is also taking forever to come on and i'm using a stock TD04. I do have 120,000 miles so maybe my turbo's taking a dump. My mods are catless TBE, perrin uppipe, short ram intake, and a generic opensource reflash to set to 18 pounds. So do you think that my turbo is going out?
Adrenalinecrisis is offline   Reply With Quote
Old 04-12-2010, 05:12 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
The turbo could definitely be going out but it's also possible that you have a pre turbo exhaust leak if you're hearing noise and it's not boosting all that well. I would check for exhaust leaks quick and if you can't find anything then pull the DP off and see how the exhaust wheel feels on the turbo.
Mike
GrimmSpeed is offline   Reply With Quote
Old 04-12-2010, 05:25 PM   #3
Adrenalinecrisis
Member#: 84519
2005 LGT wagon
I did put in the Perrin uppipe in January so I really hope that it isn't leaking. But i'll check it out.
Not hitting peak boost with Accessport V2 and extreme taper. BrianMR2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 04-04-2010 11:00 PM
Not hitting peak boost :( eurospek AccessPort 1 08-30-2007 07:38 PM
Boost Gauge not working...not reaching peak boost. mnwrx78 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-29-2006 10:20 AM
not hitting peak boost with vf 34 blackrod punishment General Community 9 03-07-2006 09:45 AM
STi hits peak boost, then boost drops and it won't rev higher WR^2X Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 12-30-2005 12:15 PM
