Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 03-29-2010, 11:09 PM   #1
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Default Improved strut tower bars :)
Here's mine-
The original STI bar wouldn't fit with the new AWIC, so I fabbed a new one. It weighs 1/2 lb more, but it is much stiffer than the STI bar and it triangulates back to the firewall.
Old 03-29-2010, 11:58 PM   #2
Deathclutch
Member#: 232012
that is awesome! great job.. you have given me a good idea for the one i wanna make
Deathclutch is offline   Reply With Quote
Old 03-30-2010, 12:11 AM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
here is one i made for somebody.
PARANOID56 is offline   Reply With Quote
Old 03-30-2010, 12:22 AM   #4
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Paranoid56: What did you make that out of? Is it mild steel, chromoly, 304 stainless, or what?
FourOnTheFloor65 is offline   Reply With Quote
Old 03-30-2010, 12:51 AM   #5
PARANOID56
Member#: 22035
2003 Brocoma DCab
i made it from 120 DOm
Old 03-30-2010, 01:05 AM   #6
raceckr
Member#: 242353
1997 impreza L
green gc4
wow sick guys nice job
raceckr is offline   Reply With Quote
Old 03-30-2010, 08:29 PM   #7
fastwrx25
Member#: 126441
03 bugeye
the bar you made for someone...can you still remove the bar? I see it is welded to the firewall.
fastwrx25 is offline   Reply With Quote
Old 03-30-2010, 08:45 PM   #8
PARANOID56
Member#: 22035
2003 Brocoma DCab
you dont see it welded that part bolts to the firewall. so its totally removable
Old 03-30-2010, 08:51 PM   #9
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
To the OP, weld the joint to make it functional, like Paranoid's bar!
MConte05 is offline   Reply With Quote
Old 04-02-2010, 11:33 PM   #10
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
1. It's pretty hard to weld steel to aluminum.
2. With the bolt torqued appropriately, there isn't any rotation at that joint so welding it solid is unnecessary.
Old 04-08-2010, 01:31 PM   #11
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Great work guys, This is one of the first things I plan to do when I bite the bullet and swap my tnic for my fmic...
Old 04-09-2010, 04:05 PM   #12
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
I made this one for my car.
my4isflat is offline   Reply With Quote
Old 04-10-2010, 10:45 PM   #13
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
^^^ I like the ends, looks like some nice precision machining, but why put in the heim joint ends on the links? Solid links would have worked just as well. Granted they would not have looked as nice.
Old 04-12-2010, 12:11 AM   #14
lettucemanatee
Member#: 32493
2002 Impreza WRX
rock chipped blue
i've got old GC topmount camber plates, the ones they're selling as rally spec on their site now, look like:
as you can see, there are already 2 points on them tapped for a strut bar. GC never released one and i'm interested in making one to tie in the middle against the firewall and also clear a larger TMIC.
any tips? sources to get threaded fittings for pre-tension?
lettucemanatee is offline   Reply With Quote
Old 04-12-2010, 12:30 PM   #15
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Personally, I would recommend against tieing the strut tower bars back to the firewall. It was not meant to be a load bearing in the vertical (front to back) direction, so it's not going to give you any additional strength by triangulating back to it.
Legacy777 is offline   Reply With Quote
Old 04-13-2010, 12:09 AM   #16
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
The engine pitch mount is tied into the firewall just below where my bar is bolted in. That pitch mount loads the firewall much more than the strut tower bar ever will.
The firewall at that location is actually pretty strong and stiff in the fore-aft direction and contributes quite a bit to the stiffness of the chassis by tying the strut tower bar into that location.
Old 04-13-2010, 02:38 AM   #17
Deuce Cam
Member#: 130444
'85 AE86 GTS
The Litchfield type 25 race car has a custom triangulated weld-in strut bar connecting the strut towers and firewall - much like bars pictured above, but more affective. I couldn't find a good pic.
Deuce Cam is offline   Reply With Quote
Old 04-15-2010, 04:00 AM   #18
my4isflat
Member#: 120002
2000 2.5 RS, '95
Thanks. I use the heim's for three reasons. The first being I just like the look, and the second I can set the preload on the brace, and the third being it provides a cleaner install. When you say solid links do you mean solid rod ends vs. spherical endlinks. The reason I can't use solid links is the bracket on top of the pitchstop mount would be to large to mount. The heim's allow for the misalignment on the pitchstop bracket. If the strut tower brackets and the pitchstop bracket were on the same plane for the mounting holes then the width of the bracket would prevent a clean install, and I couldn't get my torque box back on.
I just wanted to add the pitchstop mount is also right above the trans. tunnel too. This area of the chassis is quite possibly the stongest, most ridged area of the chassis.
GC8 Front Strut Tower bar Impact.blue VIC Private Classifieds 2 06-05-2010 12:46 PM
WTT: Tein front strut tower bar for Cusco front strut tower bar AwkWarD RMIC Private Classifieds 20 05-13-2009 03:05 PM
FS: Cusco Front Strut Tower Bar + Cusco Carbon Rear Strut Tower suby44 Suspension/Brakes/Handling 4 01-03-2008 01:47 AM
Central coast CA.: Cusco, STi, Perrin - strut tower bars, sway bar, lower arm bar I awdbeast Suspension/Brakes/Handling 13 02-04-2007 03:46 PM
Removed Strut Tower Bars...Ride "Quality" Amazingly Improved! Brian Broz Brakes, Steering & Suspension 16 02-18-2006 02:33 PM
