Old 04-13-2010, 07:38 PM   #1
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default Gauging interest for GD wagon owners with Koni, Tokico shocks who want springs!
We used to make wagon springs. They worked well when paired with aftermarket firm struts. These springs are intended for Tokico D specs, Ohlins fixed perch( no longer available) and Koni inserts.
We stopped making these because there wasnt enough interest. Lately there has been some interest. So I figured I would post here to see.
If anyone is interested let us know.
Again, this is for 02-07 WAGON owners who have upgraded rear mounts( 04-07) mounts and also Tokico shocks, or KYB shocks, Koni etc.
**** THESE ARE NOT INTENDED FOR STOCK SHOCKS**********
PLEASE CONTACT RCE at [email protected]
Myles
RaceComp Engineering is offline   Reply With Quote
Old 04-13-2010, 07:42 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Sorry, the rates are 275/259.
Old 04-13-2010, 08:00 PM   #3
Mr. Sociable
Member#: 176200
1997 Toyota Tacoma
Was white once...
Depending on when deposit/payment would be due, I'm interested. I was planning on picking up some black's from you guys since the wagon's were discontinued, but would love to get wagon specific instead. I was going to purchase them sometime mid-summer.
Mr. Sociable is offline   Reply With Quote
Old 04-13-2010, 08:17 PM   #4
wrxracer519
Member#: 149890
09 Forester
Green
I am interested. Wagon is down right now and waiting to hear the final call on it. Already have the d-specs with 06 sti springs/hats.
wrxracer519 is offline   Reply With Quote
Old 04-13-2010, 10:22 PM   #5
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
running sti pinks on D-specs because the wagons were no longer available 07 wagon soon to do the sedan lca's and axles to get my camber back without camber bolts.
so i would be interested
subiesoho is offline   Reply With Quote
Old 04-14-2010, 02:51 PM   #7
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Interested! Bump for wagon owners.
Dentt42 is offline   Reply With Quote
Old 04-14-2010, 03:01 PM   #8
jeisen
Member#: 27258
who dat be dat was?
I just recently switched from the Koni/RCE wagon/Group N tophat combo to coilovers since I'm not daily driving with that car anymore. I have to say that they were fantastic when I still needed to use the car everyday on the street and stiff enough when I wanted to go auto-xing. If anyone is thinking about using these springs, you won't regret it.
jeisen is offline   Reply With Quote
Old 04-14-2010, 03:07 PM   #9
Back Road Runner
Member#: 60082
2004 Forester STI
I used to run the front wagon springs paired with Prodrive STI rears on my Forester(personal handling preference/goals). The Wagon fronts were a nice upgrade from the Prodrive STI springs for the car.. These are certainly a performance level spring given the spring rates but also low (cut your bumpstops). For anyone looking for some fun at the track or auto-x, you certainly do want to step to these kind of rates.
RCE you may want to suggest sway bar rate options in relation to handling balance. To folks not familiar, this kind of setup can promote oversteer in some situations. Sway bar choice will become important for handling balance.
My bro bought the Blacks a while ago and finally got them put up paired with D-Specs. If my suspension goals were different, I'd probably be on the Wagons right now.
Old 04-23-2010, 09:14 AM   #10
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Soooo....what happened with these? I didn't WANT to go with my second choice of the STi pinks. Teasing is for teenage girls.
Old 04-23-2010, 09:23 AM   #11
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
what happened is what happened the last time I tried to see where the interest is and there is not enough interest simply put. This isnt a tease, it is what it is, gauging interest.
Myles
Old 04-23-2010, 10:15 AM   #12
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
okey dokey
Old 04-23-2010, 12:13 PM   #13
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We have been getting wagon owners into yellows with Dspecs lately and they have been very pleased. The yellows are close enough to the wagons that they are a good substitute.
Tony
Old 04-23-2010, 12:20 PM   #14
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Tony
I already have a set of Koni inserts and 2002 wagon struts to put them in. If I use the 2004 strut mounts, the TIC Scooby921 spacers and the D_rex Koni strut extenders, will the yellows work? Also, is there a need for the saggy-butt shims?
Old 04-23-2010, 02:03 PM   #15
hklatte
Member#: 131234
2007 WRX Wagon
interested for higher spring rates. (say... 350 / 325)?
hklatte is offline   Reply With Quote
Old 04-23-2010, 03:08 PM   #16
CycleOrange
Member#: 237694
2002 WRX Wagon
interested, sent an email a while ago, no response
CycleOrange is offline   Reply With Quote
Old 04-23-2010, 03:35 PM   #17
Turn in Concepts
Member#: 93646
Many Track Records
Yellows will work. You don't NEED the koni strut extenders, but they are nice to have.
Depending on the inserts for the rear - if youbought the 04-07 inserts you won't need the spacers.
Again, the shims are up to you, but yellows actually work out to a pretty nice even drop on the wagon.
Old 04-23-2010, 07:40 PM   #19
cueball89
Member#: 90513
2003 wrx wagon
black
Tony
What kind of ride heights are you getting with yellows on a wagon?
STi tarmac rates. I've already got a set of your wagon springs, but if you make them this stiff with the same or slightly more ride height(~.5") I'll buy another set.
cueball89 is offline   Reply With Quote
Old 04-23-2010, 07:59 PM   #20
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
PM me when you're ready to sell 'em.
Old 04-23-2010, 09:58 PM   #21
hklatte
Member#: 131234
2007 WRX Wagon
Yeah, me too have already got RCE wagon + Koni setup. I just got it done a couple weeks ago . I would definitely like another set of springs with higher rates. It would be really nice to go even higher rates than the STi tarmac. +1 on gaining some ride height slightly for more bump travel.
Old 04-24-2010, 06:58 PM   #22
Dr.Claw
Member#: 130382
would deff be in for another run!
Dr.Claw is offline   Reply With Quote
Old 04-25-2010, 07:44 PM   #23
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Ditto, I really want springs with 250 in/lbs.+ but want to avoid the hassle of doing GC springs. I have Koni yellows in my 2005 wagon.
BrandonDrums is offline   Reply With Quote
Old 05-26-2010, 09:48 PM   #25
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Post
Just PMd GTWorx. I'm definitely down!!
that1dude is offline   Reply With Quote
KONI Yellow Shocks and Tein Springs millertime21 Newbies & FAQs 19 07-01-2010 07:02 PM
NC: Wagon struts with Koni adjustables, Eibach springs, and two sets of tophats! saab-on-the-cobb Suspension/Brakes/Handling 10 05-06-2009 06:51 PM
gauging interest for now...17" subzero's with RE070's ekoh81 NESIC Private Classifieds 12 02-01-2007 09:18 AM
gauging interest for trade: Rota Slipstreams with new rubber ScoobySnackZ Tri-State Area Forum 8 06-29-2004 12:17 AM
gauging interest... kyb agx suspension setup with kg/mm 1.25" drop springs (jdm) legacy2003 Legacy Forum 2 05-17-2004 12:42 AM
