Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-13-2010, 08:51 PM   #1
Nathan Explosion
Member#: 215525
2006 WRX Wagon
Default Slight smoke on idle with AC on
In about the last week or so my car has started slightly smoking at idle, but only when the AC compressor is on, and only after sitting for a while (5 or more minutes). I've read this is most likely a sign of failing seals in my TD04, but wanted some more opinions. The smoke is thin enough that it's hard to get a good gauge on the color, but I would lean more towards burning coolant than oil. The car is a 2006 WRX with 67000 miles, the last 2000 or so have been with an Invidia V3 and a Perrin "Stage 2" e-tune on my AP, the last 500 or so with a ebay giant TMIC, and probably about 8k before that with a Perrin "Stage 1" e-tune.
I plan on getting a compression and leakdown test done tomorrow to verify it's not the motor, is there anything else wise to rule out before I start looking for a VF series? Also planning on pulling the DP and looking for obvious signs of leakage within the turbo itself.
Nathan Explosion is offline   Reply With Quote
Old 04-13-2010, 09:22 PM   #2
hammyt
Member#: 92585
2005 Saab 9-2x Aero
13.6@100 EJ205 VF48 93Oct
Check the TMIC for oil as well. Sounds like you are going a this properly.
hammyt is offline   Reply With Quote
Old 04-13-2010, 11:03 PM   #3
ktmrider
Member#: 125687
2005 Legacy GT - 6MT
Seen a bad PCV do that, how old is yours?
BTW if not aware get an OEM one if replacing, Framinators WILL fail and make a mess of your intake tract.
ktmrider is offline   Reply With Quote
Old 04-13-2010, 11:06 PM   #4
Nathan Explosion
Member#: 215525
2006 WRX Wagon
It may still be original. I've only lived in a place where I can do my own work to the car for about six months, so everything was dealer scheduled maintenance before that. I'll definitely look into it when I get in there tomorrow.
Edit: was replaced at ~36k miles. Found the receipt. Will test/replace tomorrow.
Old 04-14-2010, 10:37 AM   #5
rockhound76
Member#: 147103
2007 STI
Blue Pearl
My wife's 08 Audi did that and it was crankcase ventilation. They seem to go out quickly these days.
I hope that is your problem. You are thinking about it in the right way.
rockhound76 is offline   Reply With Quote
Old 04-14-2010, 08:38 PM   #6
Nathan Explosion
Member#: 215525
2006 WRX Wagon
After playing with the car a bit today, I got a good look at the smoke under proper light, and it looks alot bluer than I thought. Thinking it's probably a failed turbo seal based on tests, data, and a few outside opinions I got today.
Thanks for the help guys, I'll keep this thread updated with the exact solution when I find it.
Hiccup @ idle w/ AC on... Kev5n24 Baja Forum 17 07-09-2007 12:13 PM
Surging/pulsing idle with AC on? Slalom RS Normally Aspirated Powertrain 8 09-11-2006 02:57 PM
Screeching with AC on trojan9x Normally Aspirated Powertrain 6 04-20-2002 12:21 PM
Humming noise with AC on. kkozma Legacy Forum 5 09-18-2001 03:59 PM
