Old 04-14-2010, 12:49 PM   #1
Victor1620
Member#: 146001
'96 Impreza L
559 Red
Default Best steel for turbo header?
I can't seem to find a straight on answer, if there is one. Opinions?
Victor1620 is offline   Reply With Quote
Old 04-14-2010, 12:52 PM   #2
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
2010 Volvo C30R-design
Inconel 625
its not steel, but it IS best.
Inconel alloys are oxidation and corrosion resistant materials well suited for service in extreme environments. When heated, Inconel forms a thick, stable, passivating oxide layer protecting the surface from further attack. Inconel retains strength over a wide temperature range, attractive for high temperature applications where aluminum and steel would succumb to creep as a result of thermally-induced crystal vacancies (see Arrhenius equation). Inconel's high temperature strength is developed by solid solution strengthening or precipitation strengthening, depending on the alloy. In age hardening or precipitation strengthening varieties, small amounts of niobium combine with nickel to form the intermetallic compound Ni3Nb or gamma prime (γ'). Gamma prime forms small cubic crystals that inhibit slip and creep effectively at elevated temperatures.
Dirty25RS is offline   Reply With Quote
Old 04-14-2010, 01:08 PM   #3
Victor1620
Member#: 146001
'96 Impreza L
559 Red
Wow. Steel is more in my price range.
Old 04-14-2010, 01:13 PM   #4
Dirty25RS
Member#: 56731
T304 although I'm sure about the heat range.
http://www.matweb.com/search/DataShe...37098da&ckck=1
Old 04-14-2010, 01:27 PM   #5
Victor1620
Member#: 146001
'96 Impreza L
559 Red
That site wants to feed my computer cookies, however, thanks.
Old 04-14-2010, 02:06 PM   #6
Dirty25RS
Member#: 56731
matweb is an unmatched resource for material property and sourcing information.
Its no BS.
Old 04-14-2010, 02:16 PM   #7
Victor1620
Member#: 146001
'96 Impreza L
559 Red
Absolutely. Very informative site, thanks again.
Old 04-14-2010, 08:56 PM   #8
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
11 Taurus SHO daily
304 really isn't a good choice at all, even though most turbo headers are made from it. They use it because it is cheaper than a proper material. This is one of the biggest reasons, that even name brand turbo headers have a bad reputation for cracking. I'd rather use mild steel and have it Swain Tech coated than use 304. For an NA header it is not bad. The added exhaust temperature in a turbo application causes the issues. The problem with 304 is Chromium precipitation. At high temperatures, like during welding, or use as a turbo header the Chromium (what makes stainless steel, stainless) starts to precipitate out of the material. Over time this allows the stainless to corrode. Sometimes it pits, sometimes it causes intergranular stress corrosion cracking. Anyways 304 is not good unless your bottom line is more important than the product.
321 stainless is a much better material for high heat applications. It is much less prone to Chromium precipitation. It's not quite as good as some of the different Inconel alloys, but it's much cheaper.
FourOnTheFloor65 is offline   Reply With Quote
Old 04-14-2010, 10:05 PM   #9
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
+1 for 321 S.S. if you can source everything that you need.
kharris4 is offline   Reply With Quote
Old 04-14-2010, 10:14 PM   #10
Darcros
Member#: 196496
2006 STI
http://www.burnsstainless.com/ there should be no more post after this one
Darcros is offline   Reply With Quote
Old 04-15-2010, 06:37 PM   #11
Token-Negro
Member#: 81659
2010 Fozzy XT
Ice Silver Metallic
Simple, 321 and if you can afford 625 do that.
Token-Negro is offline   Reply With Quote
Old 04-15-2010, 10:30 PM   #12
stispeedwagon
Member#: 172915
9698 outback, 2.5 rs
killer red, flat black
321 with a nice ceramic coating shuld suit you just fine. howdy token
stispeedwagon is offline   Reply With Quote
Old 04-20-2010, 09:19 AM   #13
downest
Member#: 194343
1990 CRX B18C5 turbo
REDISH
I've built a lot of turbo manifolds with 304 stainless with no issues. Yes, 321 is better, but 304 is more than enough for manifold duty when properly welded and backpurged. Honda guys have been using it for years without problems, it's pretty much the standard. I have personally never seen any kind of precipitation or breakdown of 304 due to use, only from improper welding.
downest is offline   Reply With Quote
Old 04-21-2010, 12:12 AM   #14
sofiagonza
Member#: 193535
Default very nice explanation
wow..........very nice explanation.............thanks a lot
sofiagonza is offline   Reply With Quote
Old 04-22-2010, 02:12 PM   #15
GEE-OTTO
Member#: 201277
2008 Legacy
No to T304SUS and I would only use 16ga. or heavier 321 I would use 625 but it is pricey but I wonder how well T202 would work and never use T409 really for anything hahaha it is bad unless coated.
GEE-OTTO is offline   Reply With Quote
Old 05-01-2010, 01:08 PM   #16
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
How does 316 compare to 321? I assume slightly less ideal but is it still better than 304?
Thanks for the help.
Ben
Old 05-20-2010, 12:00 AM   #17
XplicitRacingDesign
Member#: 242434
2004 WRX STi
Blue/Charcoal Grey 2 tone
I agree with using 321 s.s.
I've used 304 in the past, it's usually alright as long as it has some wall thickness to it, and i would def recommend getting everything high temp coated.
XplicitRacingDesign is offline   Reply With Quote
Old 05-20-2010, 10:14 AM   #18
GEE-OTTO
Member#: 201277
2008 Legacy
T202! high nickel content or T321 I have used T308 and T304 they work well and will suffice .16 ga min use a good stainless wire or rod or filler (depending on welding method) mandrel bend everything to maintain true radius in bends
Old 05-25-2010, 04:14 PM   #19
madmax718
Member#: 172501
Most of the time headers I've seen fail are from rust, or thin steel. 304 is fine, but you have to use a minimum thickness to prevent problems. The other part is, things will generally crack at the welds (especially stainless) as the extreme heat at the welding site will migrate the contents of the alloy. Thats why most cracks are at the weld line.
There is no perfect answer- especially if you want to keep things light weight.
madmax718 is offline   Reply With Quote
Old 05-25-2010, 04:21 PM   #20
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
what about the thickness of the 321? how thick should the piping be?
All4bSpinnin is offline   Reply With Quote
Old 05-26-2010, 10:52 AM   #21
GEE-OTTO
Member#: 201277
2008 Legacy
I would find a good source for 321 i see it a lot in 18 and 16 gauge but for a manifold i would like see something beefier.
If only cast iron wasn't such a bitch!
Old 05-27-2010, 02:41 PM   #22
madmax718
Member#: 172501
You can weld cast iron. Just takes patience and time. No guarenteed results, but a nickle rod works ok.
Old 05-28-2010, 07:55 PM   #23
smallblock
Member#: 132647
2004 Forester XT
Java black pearl / rust
The problem with austenitic stainless (300 series) is that chromium carbides precipitate in the sensitization range (~850-1500..hey my EGT's are somewhere in there..). Essentially, the chromium would rather be close friends with carbon than hang out in the alloy, and precipitates into the grain boundaries as chromium carbide. When 304 headers crack, it is primarily because the welder did not solution anneal the part (1900 F for 30 min soak) to re-dissolve the chromium carbides. One alternative is to use "L" grades (304L / 316L...), which have a lower carbon content. The Carbides precipitate into the heat affected zone. Further cycling in the sensitization range just makes this worse. 321, 347, etc. alloys are what are referred to as "stabilized" alloys, where titanium(321), niobium, or tantalum have a greater affinity for carbon, and allow the chromium to remain in solution. A greater nickel/chromium content doesn't hurt, either.
smallblock is offline   Reply With Quote
Old 05-29-2010, 10:51 AM   #24
downest
Member#: 194343
REDISH
On most of my inline four turbo manifolds, I use sch 10 1.5" 304 with 308L filler, backpurge, two passes with the first being pretty much all fusion welding. There is no sugaring after welding, and I have never seen it develop from high EGTs either. I think this is common practise for many manifold builders for Hondas, DSMs, etc. Obviously for an EJ manifold, sch 10 would be extremely heavy and probably not the best for the job.
Old 05-29-2010, 08:01 PM   #25
GEE-OTTO
Member#: 201277
2008 Legacy
I know it can be welded but finding a person to weld it is the bitch even when you want to pay
Best Place for Detail?? dasnowman Vancouver Impreza Club Forum -- VIC 4 06-05-2010 11:49 AM
best engine for turbo chello4life Factory 2.0L Turbo Powertrain 4 12-12-2005 05:03 AM
World One Performance the BEST place for TURBO XS Deals!! Videos WorldOne Engine/Power/Exhaust 11 05-06-2005 06:25 PM
best place for Turbo XS UTEC Stage 4 install SoCalWRXwagon Southern California Impreza Club Forum -- SCIC 6 06-30-2004 03:19 PM
best exhaust for turbo? RS2000 Normally Aspirated Powertrain 5 12-03-2000 07:33 PM
Message Board Statistics All times are GMT -4. The time now is 12:06 PM.
