Old 04-15-2010, 12:06 AM   #1
rhurley13
Member#: 243339
2004 STi
Default Cobb Stage 2 Lean
I just flashed my ecu to the Stage 2 93 oct map. Went out for the test drive and I can hear detonation. I turned logging on and gave it a few more runs to gather data and it seems as though my AFR is way lean. I was hitting target boost levels of ~17.5 (17.86 at the highest), but the AFR was in the mid 14's! Seeing as how this is super dangerous, I uninstalled the Cobb tune and am back to the stock map. Has anyone experienced a similar issue?
I did some more testing with different maps, such as the stage 2 91 oct and took out 3 degrees of timing. With this configuration, I had the least amount of pinging but it was definitely still present. Unfortunately I did not have the logging on for that run, so I don't know where my numbers were at exactly.
My thoughts right now are to replace to fuel filter and possibly the fuel pump. Anything else I should be considering??
rhurley13 is offline   Reply With Quote
Old 04-18-2010, 03:37 AM   #2
Sokkarr
Member#: 215320
2009 WRX STi
Did you get a tank of bad gas?
Sokkarr is offline   Reply With Quote
Old 04-18-2010, 03:52 AM   #3
kh15
Member#: 132400
thats more than bad gas! you need to try and do some logging
kh15 is offline   Reply With Quote
Old 04-21-2010, 11:05 AM   #4
riderome
Member#: 210603
2005 STI
Default Re: Cobb Stage 2 Lean
I get mid 10-15s as well on a stage 2 map. the afr logger might be off because I do get the occasional black smoke and backfire.
riderome is offline   Reply With Quote
Old 04-21-2010, 03:29 PM   #5
PERRIN_Chris
Member#: 186665
2014 BRZ
Remember that the AFR readings from the AccessPORT aren't very accurate, since it's reading from the rear O2 sensor. That means that it'll read after any cats if you have any, plus the sensor is a narrow band. To accurately read AFRs, you will need a wideband O2 sensor. Do you have the stock intake?
PERRIN_Chris is offline   Reply With Quote
Old 04-21-2010, 04:25 PM   #6
riderome
Member#: 210603
2005 STI
For me I have a cat and it is stock 02 sensor so that is probably why.
Old 04-22-2010, 07:32 PM   #7
arghx7
Member#: 232940
let me guess, you used an OTS map on an aftermarket intake, which is exactly what Cobb says not to do.
arghx7 is online now   Reply With Quote
Cobb stage 2 running lean. 06rexwagon AccessPort 2 07-12-2006 12:04 AM
STi Cobb stage 2 running rich or lean? SubaruBen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-14-2005 12:48 PM
Cobb stage 2 (w mods) VS. Cobb stage 2 (w mods) Happy_Days Proven Power Bragging 7 11-28-2004 04:25 AM
my cobb stage 2 running lean!!! swol3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 09-18-2004 07:55 AM
Cobb Stage 2 running very lean grozgon Engine Management & Tuning 33 06-15-2004 11:01 AM
