Old 04-15-2010, 09:43 AM   #1
quadturbo
Member#: 75777
2003 Forester 2.5x
green
Default fuel leak/tank removal
So I have a fuel leak from one of the hard lines that goes over top of the tank. Ive been looking around and apparently i have to remove the whole rear end to drop the tank. My question, is it possible to remove those hard lines without dropping the whole tank and removing the entire rear end? Possibly just lower the tank as much as I can with out removing anything else? Any help is appreciated.
quadturbo is offline   Reply With Quote
IM Removal and Fuel Leak Fix JSarv Factory 2.0L Turbo Powertrain 2 11-09-2008 10:00 PM
Fuel leak only when fuel tank is full TJRCS Service & Maintenance 4 04-28-2008 09:35 AM
Fuel Surge Tank and External Fuel Pump epoth Factory 2.0L Turbo Powertrain 23 11-09-2005 12:20 AM
fuel leak from gas tank area 808sti Factory 2.5L Turbo Powertrain 5 10-06-2005 03:58 PM
Fuel leak / vacuum leak mmm3587 Factory 2.0L Turbo Powertrain 5 04-01-2004 08:38 AM
Message Board Statistics All times are GMT -4. The time now is 05:27 PM.
