North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Closed Thread
Old 04-15-2010, 10:12 AM   #1
easy jesus_151
Member#: 33944
2003 18g'd wrx
black
Default Question about tgv's deleted and accessport V2
Does anyone have any problems passing DEQ while running tgv deletes? I keep failing DEQ becuase of being unready for evap and 02 sensor. I not throwing any codes, but on the accessport it shows a P1086 and P1084 tgv open circuit code. These codes will not clear off of the accessport when I do a ecu reset. I had a OBDII scanner hooked up and it does not see any codes.
I was wondering if anybody that had their tgv's deleted, and have a accessport, do u still see these codes on the accessport?
I might have to put the tgv's back on.
easy jesus_151 is offline
Old 04-15-2010, 11:49 AM   #2
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Call surgeline and see if they can send you an updated map with the TGV codes turned off.
wrx_driver_2002 is offline
Old 04-15-2010, 05:35 PM   #3
easy jesus_151
Member#: 33944
2003 18g'd wrx
black
that's the problem, both codes are turned off and they still show up on the accessport.
Old 04-15-2010, 05:59 PM   #4
Dunkin
Member#: 113496
(V) (;,,;) (V)
There are several codes that must be defeated when the TGV deletes are installed.
What are the TGV delete CEL codes I need to turn off?
2004 STI, the TGV codes are called "Tumble Generated Valve" codes and they are codes P1086-P1097
2005+ STI, the TGV codes are called "Intake Manifold Runner" codes and they are codes P2004-P2022
WRX, the TGV codes are P2004, P2005, P2008, P2011, and P1086 though P1097 Tumble generator valve and valve circuit codes.
This information is somewhat outdated for the later models though, so if you see something has changed with later models or other models, please post up.
Copied from this link.
http://forums.nasioc.com/forums/show....php?t=1663677
Dunkin is offline
Old 04-17-2010, 06:31 PM   #5
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
I did mine 5 years ago CEL free always
Mine works with my UTEC I don't see why they wouldn't work with all engine management even stock ECU
the rod in place to keep it CEL free
cky211 is offline
Old 04-18-2010, 12:07 AM   #6
easy jesus_151
Member#: 33944
2003 18g'd wrx
black
I have grimmspeed's tgvs so I couldn't keep the rod in there. Anyway, today I had an ots opensource map flashed to my car with it being forced into a ready state. Car finally passed inspection.
Old 04-01-2012, 10:10 AM   #7
chadb
Member#: 198179
2007 STI
UGM
How do u shut off the code if you have the grimmspeed TGV.
chadb is offline
Old 04-01-2012, 11:51 AM   #8
Whitescoobysti05
Member#: 260448
05 STI
[quote="chadb"]How do u shut off the code if you have the grimmspeed TGV.[/QUOT
You need to get tuned and the tuner will do that.
Whitescoobysti05 is offline
Old 04-01-2012, 02:59 PM   #9
ltre87
Member#: 315318
04 jbp STi
scoop,badge&wing-less
i have aps tumbler deletes no cel ever
ltre87 is offline
Old 04-01-2012, 03:14 PM   #10
Sw20matt
Member#: 268770
2006 WRX TR
best answer you will get. I deleted my tgv's myself and deleted the codes from my map also. you will have to go to whoever tuned it and have them shut off the codes, there are a few of them. if those are the only 2 showing up then just delete those 2.
if you are using the race program simply go into your accesstuner race and uncheck the codes that are coming up for tgv. It was easy and took about 10 mins to do.
Sw20matt is offline
Old 04-01-2012, 08:13 PM   #11
Tyrus3
Member#: 133875
2000 Impreza RSTi
2005 Legacy Wagon
Mine show up in the AP but won't show to OBDII readers. I had a similar problem to yours when getting my car emission tested here in WA. I had three sensors showing not ready. I don't recall which three but evap was one of them. I went to a shop and had them force readiness for those codes, passed emissions and then reflashed the cobb map.
Tyrus3 is offline
Old 02-12-2013, 10:43 PM   #12
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Is this still a valid issue? I have an 07 WRX and have the Turn In Concepts TGV delete ready to install.
RallyImprezive is offline
Old 02-12-2013, 10:54 PM   #13
JamesBernard
Member#: 180038
IB You dont even
own a subaru!
No,
I know many people who have run TGV deletes and passed DEQ, I'm pretty sure you can pass DEQ with anything if you have an AP.
JamesBernard is offline
Closed Thread
questions about tgv deletes and passing inspection easy jesus_151 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-19-2010 09:46 PM
CT: Selling Cobb Catted TBE and Accessport v2 Jay26 NESIC Private Classifieds 11 09-30-2007 06:15 PM
Cobb turbo-back and accessport V2 Steadydpn1 SCIC Private Classifieds 4 06-06-2007 03:42 PM
quick question about tgv delete wiring. Jpizzzle Built Motor Discussion 10 02-14-2007 05:21 PM
newb question about tgv deletes scutt Newbies & FAQs 18 11-09-2006 02:38 AM
