Old 04-15-2010, 04:37 PM   #1
DreWRX
Member#: 65576
Default Clutch Bleeding Procedure on 02 WRX
Going to install a braided clutch line and found a nice writeup for bleeding by Peaty at Scoobymods here: http://www.scoobymods.com/bleeding-c...1.html?p=36199
However, his procedure is on non-turbo and his pic of the service manual page at the end outlines a different technique for turbo model. Basically it says instead of doing the pedal push-bleed-lift up pedal, it says to remove cylinder and use a clamp on the piston while bleeding.
Anyone done this that can tell me if I do the same procedure as for non-turbo w/o problems?
Thanks.
DreWRX is offline   Reply With Quote
Old 04-15-2010, 05:03 PM   #2
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
The reason to bench bleed the turbo clutch slave is because the bleeder nipple is not the highest part the slave. Therefore it is very hard to get all the air out if it is bled on the car.
181stLeader is offline   Reply With Quote
Old 04-16-2010, 12:51 AM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
the best way I've found to properly bleed a turbo slave cylinder is to unbolt the slave cylinder from the tranny, and hold it up as high as the line will allow. Then using a vaccum pump with tubing attached to the bleeder build up negative pressure, then open the bleeder and close it again before pressure reaches atmospheric. And repeat until no air comes out, while being careful not to completely empty the master.
ProdriveDreams is offline   Reply With Quote
Old 04-16-2010, 11:51 AM   #4
DreWRX
Member#: 65576
Dang, this doesn't seem that easy on the WRX then. Can anyone point me to a writeup with pics for the WRX? I have a Mightyvac, but never used it. Sounds funny how Subaru would not have the bleeder nipple at the highest point.
Old 04-16-2010, 11:56 AM   #5
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
BMWs are the same way.
09rexwagon is offline   Reply With Quote
Old 04-16-2010, 09:36 PM   #6
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
just take the intercooler off... all should be clear from there. You may need to remove the starter depending on your tool selection.
Old 04-19-2010, 10:58 AM   #7
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
This is how I have done it in the past. Works like a charm.
Steve Nastoff is offline   Reply With Quote
Old 04-19-2010, 11:37 AM   #8
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Bench bleed is a nice thought but wont always get the bubbles out fully. It's not full proof.
There are so many threads that have different methods. The manual says to remove the slave and bleed it with the nipple up like a brake caliper.
ok here is what I did. I tried several methods. Every time I got only 1 inch of pressure. I finally bench bleed it and installed it in the car. Same... I pumped the pedal top to bottom 100 times. Then re-bleed the system to get the air out that has now moved to the slave. If everything else fails and you have that little pressure, this will work.
Old 04-19-2010, 02:45 PM   #9
DreWRX
Member#: 65576
hybrid, since you have done this before your way as you say and it worked, would you mind posting a mini-writeup on my thread here? Like a step-by-step? Would be MUCH appreciated.
Old 04-19-2010, 02:58 PM   #10
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
The info seems to get lost as I have tired that a few times. Maybe I will write my own thread on this so it stops getting lost.
Old 04-20-2010, 12:13 PM   #11
DreWRX
Member#: 65576
Thanks. I just found a post of yours in another thread which basically outlines what you did. I think I'll roll with that.
Strange "overheating" problem on 02 WRX TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-07-2010 12:41 PM
wrx clutch bleed procedures JSBOOST Transmission (AT/MT) & Driveline 3 04-08-2004 09:47 AM
Procedure to set timing on 02 wrx engine? Aspen_2.5RS Service & Maintenance 5 09-01-2003 10:50 PM
clutch bleed procedure ANZAC_1915 Normally Aspirated Powertrain 12 10-19-2000 09:25 AM
