Old 04-15-2010, 05:39 PM   #1
yahookendogg
Member#: 232137
2007 Subaru STI
gray
Default Squeaking when going over speed bumps.
My rear suspension is making a squeaky annoying sound whenever I go over speedbumps or just moderate dips. I only have around 38k miles on my 07' STi.
yahookendogg is offline   Reply With Quote
Old 04-15-2010, 06:08 PM   #2
kbrok
Member#: 238958
2009 Impreza WRX
struts?
kbrok is offline   Reply With Quote
Old 04-15-2010, 06:10 PM   #3
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
the beginning of the famous sti strut clunk .
tekfoc is offline   Reply With Quote
Old 04-15-2010, 06:11 PM   #4
kbrok
Member#: 238958
2009 Impreza WRX
just get used to it haha
Old 04-15-2010, 11:03 PM   #5
yahookendogg
Member#: 232137
2007 Subaru STI
gray
the strut needs to be replaced?
Old 04-16-2010, 02:55 AM   #6
kbrok
Member#: 238958
2009 Impreza WRX
yes...
Old 04-16-2010, 08:21 AM   #7
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
strut clunk is a clunk, not a squeak. The squeak could be as simple as swaybar bushings needing a little grease. Try that first, its a whole lot cheaper. White lithium grease works well.
Scooby921 is offline   Reply With Quote
Old 04-16-2010, 08:51 AM   #8
GHK
Member#: 103886
2005 WRX
You beat me. ^ this exactly what I was going to say. try using teflon pipe thread tape with a coat of grease.
GHK is offline   Reply With Quote
Old 04-16-2010, 09:36 AM   #9
The_Prodigy
Member#: 116467
2004 STi
lithium grease is oil based, it will deteriorate rubber try silicone lube
The_Prodigy is offline   Reply With Quote
Old 04-16-2010, 10:47 AM   #10
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
^^ won't deteriorate the rubber at a fast enough rate to matter. Considering the majority of stock bushings are made with some kind of self-lubricating rubber and have no lubrication from the factory, any amount of lubrication helps with the friction and noises.
If you want some really nice grease check out the energy suspension formula 5. Works great and its very sticky so it stays in place. Also has a teflon additive.
http://www.energysuspensionparts.com...p?prod=9.11104
Old 04-16-2010, 03:03 PM   #11
Web Foot STi
Member#: 39086
2004 STi
Mine squeaks over speed bumps when the suspension is cold. i.e. it squeaks going out, but doesn't coming back. It is different than the clunk. That I have under control with grease on the rear struts. The squeak is on both ends. I think it's the shock oil. In real cold weather I've had non performance cars do the same thing.
Web Foot STi is offline   Reply With Quote
Old 10-08-2010, 03:04 PM   #12
RogueM3
Member#: 224285
2005 WRX Wagon
Now that it is getting colder out, my rear swaybar is creaking over bumps and driveways. I had it greased last year by a local mechanic when he fixed all of the issues found during the PPI. However, I have never done it myself.
I was planning to buy some of the Energy Bushing Lube (mentioned above)...but since I haven't done this before, I was looking for some advice:
Do I need to put the car in the air (remove load from the suspension) in order to remove and re-lube the swaybar bushings (front and rear)? Or can I simply crawl under there with the car parked and remove and re-lube?
Thanks in advance!
Jack
RogueM3 is offline   Reply With Quote
Old 10-08-2010, 03:23 PM   #13
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Thanks in advance!
Jack
You want the front or rear to be equally loaded as in don't jack just 1 corner up. You can probably do the rear without getting the car in the ground. With the front, you may have to remove the subframe to get to the d-mount nuts. If you have a 12mm swivel head gear wrench or a ujoint socket, you might not have to. Just get the d-mount off and slide the bushing a bit till you can get it off the bar, clean it, regrease and reinstall.
The rear should be cake. No subframe to remove, just loosen the two 12mm fasteners on each d-mount, remove the bushing, clean, grease, install (don't strip these nuts/bolts, it can be easy).
For the rear, you probably don't need to get the car in the air, but the front you probably do.
09rexwagon is offline   Reply With Quote
Squeak from rear when going over bumps CletusTheDwarf Brakes, Steering & Suspension 6 01-31-2005 02:57 PM
STi question - knocking sound from steering wheel when going over bumps WRXIN Brakes, Steering & Suspension 16 05-05-2004 07:59 AM
noise when going over bumps! Kyguy Brakes, Steering & Suspension 1 02-02-2004 01:52 AM
Noise when going over speed bumps and up/down driveways Evaider Brakes, Steering & Suspension 10 05-23-2002 03:14 AM
