Old 04-15-2010, 08:23 PM   #1
nhat
Member#: 140163
03 STi
hellaflunctional
Default hyperco springs with no markings?
i just picked up a set of coilovers which come with hyperco springs. the only marking i see on each spring is a hyperco sticker, nothing more.
so how do i figure out what the spring rates are?
Old 04-15-2010, 08:44 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Hmmm... that seems a little odd. Call them up.
since it's a coilover spring you can calculate the rate pretty easy using the standard spring rate formula.
Old 04-15-2010, 09:13 PM   #3
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
There's no marking on the side of Hyperco springs...it's etched into the top.
- Andrew
AndyRoo is offline   Reply With Quote
Old 04-15-2010, 09:31 PM   #4
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Yep, on top of the spring there's a small area with no paint and the rate is etched into it there.
boost junkie is offline   Reply With Quote
Old 04-15-2010, 10:06 PM   #5
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
And they do that so that the circle track guys can't cheat off of each other
Old 04-16-2010, 11:53 AM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
thanks for the info guys. i'll look for the etchings tonight
Old 09-22-2012, 12:01 PM   #7
Baay
Member#: 139645
07 WRX
UGM
Old topic bump, nhat, did you ever find the markings? im going to guess the spot they are etchd is where they sit on the spring seat, that is the first thing to rust! Both my springs are rusty on the tops
Baay is offline   Reply With Quote
Old 09-22-2012, 09:52 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
carefully 'sand' them with a scotchbrite pad lubed with something like wd40....the numbers may come out enough to see them
Old 09-23-2012, 03:48 AM   #9
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Some chemical based rust remover (naval jelly, or that reusable/recyclable/biodegradable one they keep plugging on Truck U) might be a bit better to reduce the chance of removing the markings themselves. Not that a lubed up Scotchbrite pad is all that aggressive.
Counterfit is offline   Reply With Quote
Old 09-23-2012, 08:04 AM   #10
Baay
Member#: 139645
07 WRX
UGM
SOL, the markings on them are long gone, oh well. Thanks for the tips guys!
Visual speed estimates by police are guesses with no formula, just practice, to guide AVANTI R5 Non-Subaru News & Rumors 56 09-21-2011 07:30 AM
Possible Tranny issue, grinding with no load battlewaggin Transmission (AT/MT) & Driveline 3 06-06-2010 01:02 AM
Modified forester largest sway bars and sti springs with no drop, yes I searched? excipient Brakes, Steering & Suspension 1 04-17-2007 08:30 AM
is there a good stiff spring with no drop kdogae86 Suspension/Brakes/Handling 1 08-08-2006 05:25 PM
Spring with no drop or the shortest jroberts Brakes, Steering & Suspension 4 08-05-2004 05:58 PM
