Old 04-16-2010, 03:06 PM   #1
toflaherty
Member#: 212765
2003 WRX
Default 03 WRX bad cold start idle in closed loop / rich open loop fuelling
Hey everyone, I just built and installed a new ej205 in my 03 wrx and have some strange behaviour during the start, I was wondering if maybe someone could help me out.
First, all relevant engine mods..
BC +1mm intake/exhaust valves
Ported intake/exhaust ports
Shimless buckets
USDM STi TMIC
Hose Techniques TMIC hoses/t-bolt clamps
Gimmick Motorsports crank pulley
SPT Catback
Custom Shorty DP (stock 3rd cat, w/b in rear o2 position)
Grimmspeed Ceramic Uppipe
Ported exhaust manifolds
Ported crossover pipe
TGV deletes (including harness mod)
Walbro GSS342 255lph fuel pump
Perrin V2 fuel rails
Gimmick Motorsports turbo inlet hose
Gimmick Motorsports after MAF hose
Intake silencer snorkus delete
GM BCS
Engine is stock compression, stock turbo for now, stock airbox, stock injectors, i think that about covers it..
Anyway, car starts fine on the stock tune, but then proceeds to idle poorly the instant it goes closed loop, with wildly fluctuating AFR (aem w/b o2) from 10 to 18.4 (clipped out of range), and corresponding huge negative and huge positive a/f correction, and wildly fluctuating engine speed in tune with the AFR. After idling for a while the a/f learning #1 was maxed out at -14.99%. After the car is fully warmed up, the AFR is rock solid around 14.7-14.8 and the idle is perfect too.
Since I noticed the start was stable, but rich, until going closed loop, I unplugged the o2 sensor and did a cold start yesterday and the idle and AFR was rock solid, although very rich (around 11:1 AFR), so i think the o2 sensor is probably the cause, so i ordered another one. Hopefully that will arrive early next week and I can confirm that it is the reason of the fluctuating afr and engine speed when switching to closed loop on a cold start.
Also, the open loop fuelling is extremely rich in comparison to target afr. One thing I noticed is that stock injector scaling is 420 cc/min, but i had my injectors cleaned by deatschwerks and they also flowtested them to around 450 cc/min at 43.5 psi, so should i go ahead and make this change? That would help lean it out a little but probably not enough, so the only thing left after that would be MAF scaling.
Should i just keep increasing the injector scaling above the 450, if needed, to get the a/f learning near 0% at idle? not sure which to change, injector or maf, since they are both stock for the most part..
Any help would be appreciated, I couldn't seem to find any old threads with this specific problem, most of them are +15% a/f learning from a leak, but mine is negative, too rich...
-Tim
toflaherty is offline   Reply With Quote
Old 04-16-2010, 06:35 PM   #2
toflaherty
Member#: 212765
2003 WRX
here's a learning view screen shot to show what i'm talking about.. i'm quite sure there's a ton of false knock at low load/rpm also.. so it's very rich, maxed out negative learning at low load, and also either false knocking or lightly knocking due to the huge lean spikes..
Old 04-17-2010, 09:06 AM   #3
arghx7
Member#: 232940
you pulled out the TGV's. That's not helping.
arghx7 is offline   Reply With Quote
Close loop to Open loop and vice versa Walker Lam Open Source Reflashes 8 01-30-2009 10:51 AM
Closed Loop to Open Loop Transition, when? NavyBlueSubaru UTEC 19 03-03-2006 10:30 PM
What exactly is closed loop vs. open loop fuel control? Neek Engine Management & Tuning 5 03-09-2005 12:50 AM
My thoughts for closed-loop to open-loop with link. Chav Normally Aspirated with bolt-on Forced Induction Powertrain 0 06-28-2002 02:10 PM
Cold Start Idle goobie Normally Aspirated Powertrain 9 11-02-2001 01:02 PM
