Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 06-05-2002, 10:10 AM   #1
SupaSench
Member#: 9982
2002 Impreza WRX
Blue Pearl
Default Mobil One Synthetic
Are there any problems using a synthetic with a turbo????
I hear good things about Mobil 1 or the more expensive racing synthetic.
Please let me know, I am due for an oil change
Sench
SupaSench is offline   Reply With Quote
Old 06-05-2002, 01:50 PM   #2
NJDrew
Member#: 18535
2002 Impreza WRX
Brick Red
SupaSench, I chaned my oil in my 01 WRX for the first time at 3000 about a month ago and I used Mobel 1 Synthetic. To-date I have about 3750 miles and I haven't noticed any problems.
Drew
P.S. I also read my manual and it dosen't anything about sythetic causeing problems.
NJDrew is offline   Reply With Quote
Old 06-05-2002, 02:09 PM   #3
Rich10
Member#: 14934
Conventional wisdom says that you shouldn't put a synthetic motor oil in a new car. It has to do with allowing the car to break in (having the valves seat properly). Beyond say 3,000 miles, I would think that there would only be upside to using a synthetic motor oil.
Rich
Rich10 is offline   Reply With Quote
Old 06-05-2002, 06:16 PM   #4
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I changed to Mobil 1 Tri-Synthetic oil when i hit 10k miles. I noticed a big diffrence in the way the engine behaved at low rpms; Much less likely to strain, or shudder under load like going up hill or just at low rpms, which means the oil is working good to me.
Now i use Mobil1 SuperSyn. it's new, and supposedly better then Tri-Syn. I havn't had any problems, and my car is at 23,500miles.
Paul
PaulRex is offline   Reply With Quote
Old 06-05-2002, 06:39 PM   #5
Rich10
Member#: 14934
There have been a few threads on Mobil 1 Super Syn. IIRC, it is a synthetic blend, not a full synthetic like Mobil 1 Tri Syn.
Rich
Old 06-08-2002, 02:04 PM   #6
impez
Member#: 3622
Platinum Visa Metallic
What is the final word on this? I saw some at the store today, and the box cleary reads "Fully Synthetic," with no mention on the packaging or on Mobil's website about SuperSyn being a blend. I'm all confuseded.
impez is offline   Reply With Quote
Old 06-08-2002, 02:38 PM   #7
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
The final word on Mobil1 Supersyn is that it is a fully synthetic motor oil. It says so right in the front too..(i have container in front of me)
peace!
Paul
Old 06-08-2002, 03:58 PM   #8
annointed
Member#: 5960
FXT 11.6@118 93 oct
NSX 450 whp SC'd (93 oct)
There are tons of posts about this in Factory Forced Induction. The Subaru Rally team uses Motul Synthetic, and the consensus of the posts in FFI settle on Motul as the preferred motor oil.
Do a search, and check out:
http://www.i-club.com/forums/showthr...ighlight=Mobil
http://www.i-club.com/forums/showthr...ighlight=Motul
Also, you'll notice a trend of WRX people leaving Mobil 1, as the new blend, SuperSyn, is apparently of lower quality, yet they're still charging the same prices for it, which some peeps feel may be a ploy to boost their bottom line. Not to disparage Mobil 1, as it is still a great oil (it's in my car right now, in fact! ).
At my next oil change I'm switching to Motul 300v 5w40 until November or December, when I'll use a 5w30 oil.
annointed is offline   Reply With Quote
Old 06-08-2002, 04:39 PM   #9
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Ok, i went and read all those links, and the most informative of all of them was on vwvortex not I-club unfortunatly. So i read through all 8 pages of techinical info on that site and it gets all very confusing!
Anyway, from what i've gathered the new MOBIL1 SUPERSYN. is still a base IV not a base III synthethetic oil(the IV is better than III)
I have some tri-synthetic formula and the new supersyn right in front of me now and i'm going to type out the rating and specifications of each that are printed on the containers:
TRI-SYNTHETIC SAE 5W-30:
-Meets ILSAC GF-3 and GM 4718M
-Pours ar -49F(-45C)
-Protects at oil temps. of 400F(205C)
-Exceeds API Service SL,SJ/CF. Meets Japanese valvetrain requirements.
SUPERSYN SAE 5W-30:
-Exceeds ILSAC GF-3
-Meets GM 4718M
-Pours at -49F(-45C)
-Meets ACEA A1/B1/B5 and Japanese valvetrain requirements
I think i'm going to stick with supersyn, and keep changing my oil/oil filter every 3k like i've been doing for the last 23,500 miles.
Paul
Old 06-08-2002, 08:53 PM   #10
limshady88
Member#: 8780
02 suby wrx wagon
midnite black
Default Mobil1, no problem
My brother and I both uses Mobil 1 Syntech from the very first oil change. We both have a WRX, and he has about 25K miles on his and 18K on mine, so far no problem. We change our oil at 6000 miles.
Good Luck
limshady88 is offline   Reply With Quote
Old 06-10-2002, 04:13 PM   #11
naveeny
Member#: 12381
2002 Impreza RS
I am using the 0-30W Supersyn Mobil 1 and I noticed some major differences.
1) The engine is reving better. I am noticing more horsepower and pick when starting, plus it is idling better also.
2) The engine sounds better in the morning. The revs aren't so high and it seems to be heating the engine faster also.
I am using the 0w because I am mostly doing city driving where there is a lot of stop and go traffic since my work is only 2 miles away. Higher viscosity may not be good for my car unless I probably used 5w but so far the 0w since to be working marvels for me.
naveeny is offline   Reply With Quote
Old 06-10-2002, 05:08 PM   #12
BigElm
Always under your radar!
Member#: 1568
I know you've asked about Rex's but if this is a Subaru question then I guess I can put my 2's in here as well....
I've been using Mobil 1 Tri-Synthetic since my first oil change on my '00 RS, and I can say amazing behavior and performance. You can feel the smoothness and response on a low-end torque boxer engine. So I definitely give it two thumbs up
Now where is the 5 quart jug of 5W-30??? I can't find it anywhere now
BigElm is offline   Reply With Quote
Old 06-10-2002, 07:48 PM   #13
nizz
Member#: 188
2004 Forester XT
24k gold on white
As for using synthetic in a turbo motor, most hardcore turbo freaks don't use it because they just get into the habit of changing their oil every 2000 miles with conventional oil. Imagine buying 4.25 quarts of synthetic every 2000 miles.
The last 5 quart jug of Mobil-1 I bought was from Walmart in Albany about 8 months ago. I think they stopped selling the 5 quart jugs and started selling 4 quart jugs instead. They have the 4 quarts jugs at BJ's. The jugs are so much more convenient to bring used oil to the gas station to properly dispose.
nizz
nizz is offline   Reply With Quote
Old 06-11-2002, 03:16 AM   #14
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I hear ya' nizz'. It does get expensive, although i change my oil every 3,000miles not 2000. 2000 is a little premature i think, unless you do some track time, or its a track car.
Mobil one synthetic Bad? 05ASPINREX Service & Maintenance 66 12-24-2008 09:04 PM
Lots of mobile one synthetic motor oil! ryanjorunner Private 'For Sale' Classifieds 12 03-26-2006 09:51 AM
Mobil One vs. other synthetics AaronBBrown Service & Maintenance 81 12-18-2002 01:03 AM
i just mixed mobil 1 synthetic with valvoline synthetic (both 5w-30)... db97 Service & Maintenance 4 03-08-2002 10:50 PM
Mobil One synthetic Tranny fluid is it worth it Jimmy Normally Aspirated Powertrain 6 06-04-2001 08:14 AM
