Old 04-16-2010, 10:04 PM   #1
toddc420
Member#: 226156
2006 wrx
obp
Default 06 wrx stage 2 not holding boost
just took my wrx to stage 2 a couple weeks ago (cobb ap) and lately it seems like when i take off hard and go through the gears the boost will start off at like 15 lbs and slowly fall off as low as like 10 lbs by the end of the gear. but the weird thing is, this wont happen if i am in say 3rd or 4th gear and floor it-the boost will seem to hold. is this normal or is there some sort of problem? any input will be helpful.
thanks.
toddc420 is offline   Reply With Quote
Old 04-16-2010, 10:42 PM   #2
ajp11
Member#: 175821
2011 x5 diesel
yeah the turbo can't hold full boost to redline....it can't flow enough air.
Totally normal, should fade to about 9-11 psi in all gears by redline.
ajp11 is offline   Reply With Quote
Old 04-17-2010, 09:03 AM   #3
arghx7
Member#: 232940
Without a series of accesstuner logs it's hard to say if there's anything going on, but the boost should fall off up top.
arghx7 is online now   Reply With Quote
Old 04-23-2010, 09:41 AM   #4
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
Target Stg II is 15psi or so, tapering to 9-11psi @ redline.
Sounds pretty Healthy to me, does it pull strong?
Also, when you start your pull in 3rd gear does it hold 15lb all the way to redline? Or, does it hit target boost around 3-4k then tapper off around redline still?
Kupkake is offline   Reply With Quote
Old 04-23-2010, 06:01 PM   #5
Sobe185
Member#: 186508
2005 WRX
target is 16.5 +/- .7
Sobe185 is offline   Reply With Quote
Old 04-26-2010, 12:44 PM   #6
d4nk
Member#: 127103
2006 WRX Wagon
Grey
Its 15.2 +/- 0.7 for the 06 wrx
d4nk is offline   Reply With Quote
06 WRX Stage 2 vs 04 STi Stage 1 Vid BlowDro Off-Topic 29 09-01-2011 08:54 AM
06 wrx stage 2 boost eb_rat_7 AccessPort 4 07-07-2008 07:16 PM
06 WRX, stage 2 COBB TBE: is 3" too loud? dchampagne Newbies & FAQs 25 12-03-2005 06:28 PM
05 wrx stage 2 vs 06 wrx stage 2? dodiox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-11-2005 11:31 AM
Cobb stage 2... not hitting boost target level... WRXVII Engine Management & Tuning 37 06-06-2004 12:14 AM
