Old 04-17-2010, 01:28 AM   #1
Mechkiller31st
Member#: 38474
1998 Impreza Wagon L
Brilliant Red
Default Looking to do motor swap soon. need advice
I am planning on maybe swapping my motor out for something with a bit more performance.... I remember reading here a while ago that the eJ22 out of the old (91-94) legacy's were turbo'd and that the motor was suppose to be a beast when it came to boosting. does anyone know what motor im talking out cus if that is true i would like to do that.
On a side note i am not hugely power hungry... so 150-200 WHP is what i am wanting to do. so the other moters i was thinking about was
a Ej25 out of an RS or doing a WRX motor swap.
any opinions or recomendations on what motors/setups to use?
oh FYI i have an EJ22 SOHC with 115K miles on it
Mechkiller31st is offline   Reply With Quote
Old 04-19-2010, 12:27 AM   #2
westwind999
Member#: 231872
1999 Forester
Green
The EJ22T is the early Turbo motor. Very strong motor with a bunch of improvements over the basic EJ22.
westwind999 is offline   Reply With Quote
Old 04-20-2010, 03:48 PM   #3
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Yes. Most importantly being that it was made with a closed deck so the block was almost indestructable. You can push quite a bit more power with these motors but will be just fine for 200whp no sweat.
A wrx swap is also a good option as they are readily available and fairly innexpensive + so many people have swapped them you can find hundreds of write ups.
Will
GrimmSpeed is offline   Reply With Quote
Old 04-20-2010, 08:20 PM   #4
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
agree. Just get a wrx motor, then your easily at 200 + whp and can upgrade that nicely when wanting more boost!!
freeride is offline   Reply With Quote
Old 04-21-2010, 07:52 PM   #5
Mechkiller31st
Member#: 38474
Brilliant Red
Well i found the motor with turbo and everything (minus the trans) for $250. but does anyone know where i can find info regaurding the motor. more specifically the specs of it like the compression ratio, forged or cast parts and such.
its good to hear that the motor can take alot... though i do plan to stay around the 200HP mark. if i can use it to keep up or even beat a stock WRX ill be happy... im not looking for STi status or anything
Also.. anyone know if this motor will directly bolt up to my 98 Automatic transmission? yes the motor is comeing from an Automatic from 93
also.... anyone know of some writeups for dropping these EJ22T into new model impreza's like 98's or so
also anyone know if i have to change the ECU in my car to work with this turbo'd motor. And/or which ecu i will have to use for this motor and my automatic trans to make it OBD II compliant.
Old 06-01-2010, 02:35 PM   #6
dirtypaws
Member#: 232419
1996 Impreza 2.2L
Mechkiller : What did you end up doing? I am in a similar situation.
Thanks
dirtypaws is offline   Reply With Quote
What Do I Need To Do Motor Swap WhiteShadow Built Motor Discussion 2 02-28-2009 11:54 AM
Looking to buy WRX or STI - need advice metroplex General Community 21 12-24-2008 12:14 PM
Coming back to the Bay Area soon - Need Advice hp12c Bay Area Impreza Club Forum -- BAIC 3 01-24-2007 08:19 PM
Aspen White STi looking to do trunk swap. West Virginia BGPKR Mid Atlantic Impreza Club -- MAIC 4 10-15-2004 04:02 AM
doing EJ20 swap soon need help! TSimpreza Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-09-2002 04:36 PM
