South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 04-17-2010, 04:09 AM   #1
C-grunt
Member#: 152713
2010 G37 Sedan
Gray
Exclamation Car problems need help.
I know its hard to diagnose over the internet, but any ideas for tomorrow when Im gonna try and track the problem down would be helpful.
So today my car started idleing like crap and was kinda hessitant under partial throttle when going to full throttle.
Check engine light came on and said P0171 which is lean fuel mixture. I had the car off for a while and tightened down the adjustment on my 50/50 BOV untill its almost full recirc. After that it pretty much went away.
So tonight Im out at dinner with my wife and it starts doing it again. Under the hood I noticed the large hose that comes off the BOV down into the engine had come loose. I tried to get it back on as best I could, but I didnt have any tools so it was just kinda finger tightened on as best I could.
After that Im taking it easy trying to get home. Still idleing rough. On the freeway all of a sudden the car starts kinda shaking/vibrating under throttle. Its pretty smooth just coasting along but would do it if accelerating.
Then when I get off the freeway I started hearing a ticking at the stoplights. Under the hood it sounds like its comming from just to the left and under my battery. Now its idleing really really rough.
Any ideas?
C-grunt is offline   Reply With Quote
Old 04-17-2010, 05:17 AM   #2
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Large hose as in recirc hose coming off the BOV? That would be a gigantic vacuum leak and would cause rough idle and a lean condition for sure. Ticking and rough idle once put back on doesn't sound too good though...
KP is offline   Reply With Quote
Old 04-17-2010, 10:56 AM   #3
NeedBoost21
Member#: 150337
2007 E92 335i
Black Sapphire Metallic
is there a clamp on the recirc hose to the bov? Might be bennificial to take off the ic, check your hoses and if a clamp is need to put one on.
NeedBoost21 is offline   Reply With Quote
Old 04-17-2010, 11:32 AM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
If that recirc hose came loose, it was sucking in A LOT of post MAF, pre-turbo unmetered air. This is not good at all...
Get that hose fixed immediately and hope it isn't too late.
Old 04-17-2010, 03:46 PM   #5
C-grunt
Member#: 152713
2010 G37 Sedan
Gray
Got the hose on. The ticking was cylinder 1 spark plug connection that came completely off. I have NO idea how that happened
Now its running like normal.
Shout out to Fish for the help!
Old 04-17-2010, 07:51 PM   #6
racingfish
Member#: 60976
1969 LGT
FATURBO
waka waka waka!!!
racingfish is offline   Reply With Quote
Old 04-18-2010, 12:16 PM   #7
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the ho's.
spark plug gnomes, happens all the time.
bobturismo is offline   Reply With Quote
Old 04-18-2010, 06:34 PM   #8
racingfish
Member#: 60976
1969 LGT
FATURBO
his bolt was completely out... the cp was just hanging
car problems need help little scooby Factory 2.0L Turbo Powertrain 5 04-24-2009 05:13 PM
My lights in the car dont work when my cars off need help plz stage2?? Electrical & Lighting 29 03-08-2009 04:26 AM
Non-Subaru car problem...need help soulbazz Off-Topic 7 06-13-2007 02:10 PM
car shudder/knocking problem need help 2007scooby Warranty Issues & SOA Problems 1 03-12-2007 04:16 AM
Car problems, need help finding the source Aken Legacy Forum 6 10-15-2004 08:12 PM
Message Board Statistics All times are GMT -4. The time now is 03:39 AM.
