Old 04-18-2010, 05:21 PM   #1
chigger702
Member#: 226917
2009 Impreza 2.5i
white
Default Will this wheel set up fit on an 09 2.5i?
Im planning on running 5zigen ZR+520 +47 offset with 225/45R17 tires and lowering my car about an inch. Im trying to go as low an offset without having to roll my fenders. Ive looked around and found the +48 works well with stock suspension but would i be able to run a lower offset with wheel spacers with the setup i want?
chigger702 is offline   Reply With Quote
Old 04-18-2010, 05:23 PM   #2
Cain0023
Member#: 239135
2007 Jetta GLI
white
well i have rota torques in 17x7.5 + 48, lowered an 1.5 inches, tire size 225/45/17 and no rubbing.
Cain0023 is offline   Reply With Quote
Old 04-18-2010, 05:32 PM   #3
SubaruGenki
Member#: 65058
02 Eagle Summit
TSi
You will not rub unless you have some biggun's in the back of your car.
SubaruGenki is offline   Reply With Quote
Old 04-18-2010, 05:34 PM   #4
chigger702
Member#: 226917
2009 Impreza 2.5i
white
yeah thats pretty close to what i want. any speedo changes? does it look aggressive enough for you?
Old 04-18-2010, 06:48 PM   #5
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Why do you think you need to run spacers?
Also, your info is not adequate enough to answer your question.
Byzantium is offline   Reply With Quote
Old 04-18-2010, 11:07 PM   #6
chigger702
Member#: 226917
2009 Impreza 2.5i
white
haha at SubaruGenki
Old 04-18-2010, 11:09 PM   #7
chigger702
Member#: 226917
2009 Impreza 2.5i
white
what other info do want? and i was talking about spacers because i was thinking of lowering the offset later
Old 04-18-2010, 11:20 PM   #8
Byzantium
Member#: 207826
85k 2002 WRX
This will actually be a potentially harmful course of action. There is absolutely no reason to lower offset.
Hub bore and bolt pattern are pretty critical.
Old 04-19-2010, 12:36 AM   #9
chigger702
Member#: 226917
2009 Impreza 2.5i
white
bore size is 56 and bolt pattern is 5x100.
Old 04-19-2010, 01:11 AM   #10
Byzantium
Member#: 207826
85k 2002 WRX
Then all is well. Just run them as they are, sans spacers.
Will 04-07 Stock Brembos Fit On My 09 2.5i in any way???? [FIL] Brakes, Steering & Suspension 16 03-24-2014 06:27 AM
STI rear anti sway bar on an 09 2.5i roanokeimpreza Normally Aspirated Powertrain 15 06-11-2010 02:14 PM
Will 09 STI suspension fit on my 09 2.5i? CrotchMonster Brakes, Steering & Suspension 3 03-30-2009 04:36 PM
Will 02 WRX struts fit on an 07 2.5i?? Chris Phelps Brakes, Steering & Suspension 2 06-07-2007 10:33 PM
Will this 04 set up fit my 02 wagon? Mr Ian Newbies & FAQs 9 05-17-2005 11:13 PM
