Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 04-18-2010, 07:51 PM   #1
rexblake
Member#: 178426
2010 Audi S4
Default can't block out codes with tuning
So, I keep getting codes.
P0240: manifold pressure barometric pressure circuit low input
P0245: turbo wg solenoid low (I run ewg)
P1094/P1096: TGV codes (I am TGV less)
And the new one: P0340: camshaft position sensor "a" circuit
Now, the last one kind of scares me simply because I don't know anything about it.
With that said, the first four codes are supposedly locked out from every showing up. Yet, somehow, I still get them everyday. Incredibly annoying. Any thoughts?
rexblake is offline   Reply With Quote
Old 04-18-2010, 11:01 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
fix the issues then the codes will go away
yer map sensor needs to be fixed and.......oi vey
Old 04-19-2010, 12:15 AM   #3
rexblake
Member#: 178426
2010 Audi S4
What issues should I fix? The TGV's? O wait, I don't have any (see original post). The wg solenoid? O wait, I don't have any (see original post). Plus, these codes are supposedly BLOCKED OUT with the map. And they are coming back.
Do you have any tuning recommendations besides random babbling about nothing? I'm looking for advice, not smart ass comments that are of no use. Do you have personal experience tuning with the AP? That's the advice I need.
Or perhaps you could fill me in on what I should be worried about by the camshaft position sensor code. Do I have a bad sensor? Could it be wiring? Do I need to check to see if my timing belt skipped?
As for the MAP sensor, Harvey spent 1.5 hours on the phone with Cobb trying to get it calibrated correctly. He sent me an update and we shall see if it works.
Old 05-11-2010, 03:30 PM   #4
rexblake
Member#: 178426
2010 Audi S4
Since there's so many people interested in this thread, I figured I'd post my results from trouble shooting.
Replaced camshaft position sensor. So far, pretty much taken care of the issues. Been on for a couple days once, got codes once. No camshaft codes, just the others. Cleared them and they haven't been back yet.
Old 05-12-2010, 02:01 PM   #5
Gluis
Member#: 245584
07 Impreza WRX STI
Smile
Actually I'm very interested because I'm about to remove my TGV and I wanted to know if I can clear those codes permanently with my accessport 2.
So if I understand correctly, it is possible to do it right?
My mechaninc is suggesting me to take out the butterflies and leave the rest of the system, but I rather eliminate everything, if I can erase the codes permanently.
Thanks for your help,
GS
Gluis is offline   Reply With Quote
Old 05-12-2010, 02:46 PM   #6
rexblake
Member#: 178426
2010 Audi S4
Yes, you will be able to block out the codes with the AP.
I contacted Cobb with my issue and they didn't know what to do. They looked at the map and could see that they codes are disabled on the map, they should not be showing up. I don't know if having the one extra code brought all of them back or what, hopefully they will stay clear.
Old 05-12-2010, 06:23 PM   #7
Cobb Tuning
Member#: 4803
I talked to one of our customer service guys about this, I think you called in and discovered that the cam-sensor was unplugged and that plugging back in solved the problem.
If not, let me know if we need to take another look at your concerns.
Running EWG should not have an effect on the boost control solenoid, UNLESS it is unplugged and you are running a Manual Boost Controller.
The sensor codes could be from bad or unplugged sensors or chaffed wires. This can happen when doing your TGV mod. As far as the TGV codes, they should be turned off if you have altered that in your map. If not, you will have to load a map with these codes turned off as a base flash.
The barometric sensor is the MAP sensor, is this plugged in? I would go over your engine harness and make sure everything is plugged in.
Travis
COBB Tuning
Old 05-12-2010, 10:11 PM   #8
rexblake
Member#: 178426
2010 Audi S4
Cam sensor was plugged in. It was apparently bad though, the new one took care of the cam sensor code.
No manual boost controller.
I'll have to check my TGV's. I never knew that was an issue. They are turned off in my map.
MAP sensor is plugged in. Although, maybe it's just taking a bit to get used to the new altitude?
Old 05-14-2010, 10:58 PM   #9
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Who tuned it? and when yu shut off the codes in the Protuner you have to flash that map saved as the base map or reflash. If you havent then they wont shut off.
robbieshonda is offline   Reply With Quote
Old 05-16-2010, 05:47 PM   #10
rexblake
Member#: 178426
2010 Audi S4
Tuned by Harvey in Longmont CO. It is flashed correctly, double checked actually.
Illegal Mexican immigrant with 4.09 GPA can't figure out how to pay for school Gek Off-Topic 353 06-02-2010 08:17 AM
can't pull my codes with OBD-II reader daprez Service & Maintenance 28 03-22-2006 11:52 PM
Crazy Mikie: he can't figure out text mesaging but can expose major tuning flaws!! The Modaholic Off-Topic 9 03-13-2005 12:53 PM
Can't get out of Park with A/T mshenhouse Legacy Forum 3 08-26-2004 12:22 PM
Can't figure out whats wrong with my car Revision Mid West Subaru Owners Club Forum -- MWSOC 10 05-05-2001 01:41 AM
