Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 04-18-2010, 09:25 PM   #1
turbosmart
Vendor Sales Rating: (0)
Member#: 243303
Default Got a technical question about a Turbosmart products?
Be it a wastegate, BOV, BPV, boost controller, fuel pressure regulator - if it's got Turbosmart logo on it we can help.
turbosmart is offline
Old 05-05-2010, 11:31 AM   #2
turboge
Member Sales Rating: (91)
Member#: 35076
2004 507whp Wagon
Do you have a picture of the part # TS-0402-1002 and how it would work with the 800 series FPR? I just did a bosch 044 inline and my stock FPR is holding 65psi base pressure now instead of 43.5.
turboge is offline
Old 07-24-2010, 01:19 AM   #3
turbosmart
Member#: 243303
It's the last adapter on the right in the top row. Yes, it will work with the FPR800.
http://www.turbosmartonline.com/images/4601.jpg
__________________
[I]Thinking [B]PERFORMANCE?[/B]
Think [B]TURBOSMART![/B][/I]
Old 08-04-2010, 12:04 AM   #4
turbosmart
Member#: 243303
This is the FPR800 with its dimensions.
__________________
Old 08-04-2010, 05:09 PM   #5
acssa
Member#: 184023
Default Bov
Why does my TS BOV let the car jerk on partial throttle driving?
acssa is offline
Old 08-10-2010, 02:14 AM   #6
turbosmart
Member#: 243303
Have you set the BOV up correctly?
Below are the instructions for setting up and adjusting a Turbosmart BOV or BPV..
Each BOV needs to be adjusted to suit the vehicle it is being mounted on. The aim of the adjustment on Vee Port’s, Supersonic’s and Dual ports is to make sure that the piston is hard closed at idle and that the piston closes fast enough to minimise backfiring and not stall the engine. Plumb back BOV’s are equipped with a spring which are designed to keep the piston open at engine idle and hence the cap can be left in the middle position.
Adjustment to the BOV is made by rotating the cap. To increase the spring force on the piston, rotate the cap clockwise in the direction of hard as marked on the top of the cap. To decrease the spring force on the piston, rotate the cap anticlockwise in the direction of soft as marked on the top of the cap - CAUTION - Do not rotate the cap beyond the first O-Ring indicator groove.
• Start with the BOV cap at the maximum soft position (The indicator O-Ring should be completely covered by the edge of the cap)
• With the engine at idle the exhaust port should be closed off by the piston – the piston should be hard against the seat and not floating or moving
• Free rev the engine and back off quickly, the engine should return to normal idle speed – if the engine drops below idle or stalls increase the spring tension by one turn
• Repeat this process until the engine free revs and returns to normal idle speed
• Test drive the car and ensure that when decelerating or changing gears that the engine has minimal backfiring and no stalling. If backfiring is excessive or stalling is noticed then check all connections made during the installation, otherwise increase the spring tension.
__________________
Closed Thread
OT DVD/Computers Wiz - technical question about DVDs and files Sharkbait Off-Topic 20 10-25-2004 05:32 PM
Technical question about CEL Turbo NV Mid Atlantic Impreza Club -- MAIC 5 12-19-2003 06:00 PM
Technical question about gearboxs Aussie_STI555 Normally Aspirated Powertrain 1 03-01-2003 02:22 PM
Technical questions about ignition system mgmetalworks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-01-2001 03:00 AM
