Old 04-19-2010, 01:28 AM   #1
Civ2Sub311
Member#: 178149
2004 Impreza WRX
WRB Stage 2
Default Question about mixing O-Nex HID kit (JNA's) with STi HID housing
Hey guys. I know most people who buy the O-Nex kit or any other aftermarket HID kit for that matter either throw 'em in their stock halogen reflector housing or use them with projectors either through a mod or aftermarket housing.
If you have an '04 WRX like I do, and you installed an HID kit like O-Nex, but installed '04-'05 STi headlight housings in place of the WRX OEM ones, would the O-Nex kit installed look pretty good with decent cut-off line/output (4300k bulbs)?
AKA if I installed the O-Nex kit in my WRX but got the STi housings first which are made properly for HIDs, it shouldn't look much different than stock STi lights right? B/c the housings will have proper reflectors and cut-off plate that my stock ones do not. Also, I won't have to buy the Lightwerks adapter or STi HID parts.
Is any of this incorrect or will I have to do anything special with the housings/HID kit since I would have the STi housings?
Civ2Sub311 is offline   Reply With Quote
Old 04-19-2010, 01:58 AM   #2
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
There is a vast different in quality between OE make HID equipment and your cheapo/knock off kits.
Byzantium is offline   Reply With Quote
Old 04-19-2010, 02:03 AM   #3
Civ2Sub311
Member#: 178149
2004 Impreza WRX
WRB Stage 2
Thanks. That part I understand but comparing the O-Nex kit + stock '04 WRX housings to O-Nex kit + STi housings....the latter must make way more sense since STi housings are build differently correct?
I mean it will have a correct or close cutoff (better than no cutoff at all lol) and won't shine the light all over the road right? And I don't see any reason why it still isn't plug-n-play..I mean you replace the different housings (easy) and still connect the O-Nex kit the same way as before right? And they'll still pop right into the bulb hole of the new housings?
Old 04-19-2010, 02:06 AM   #4
Byzantium
Member#: 207826
85k 2002 WRX
Yes, HID reflectors are different. Aside from quality and longevity aspects, OE HID bulbs also produce less glare than some of the generic brands.
Old 04-19-2010, 02:15 AM   #5
Civ2Sub311
Member#: 178149
2004 Impreza WRX
WRB Stage 2
Thanks. I guess one last thing I don't understand, when you buy stock STi housings with OEM bulbs/ballasts, is there anything to installing in a WRX when you buy the Lightwerks harness (half way down this page, $75: http://www.lightwerkz.net/prod_subaru.htm)?
Does that harness totally make the install plug-n-play? As in: replace WRX housings with STi ones, mount ballasts, stick STi bulbs into housings and connect to car via Lightwerks harness and adjust level? Is there anything else or does that harness completely take the place of all soldering and anything else difficult?
Thanks guys.
Old 04-19-2010, 02:30 AM   #6
Byzantium
Member#: 207826
85k 2002 WRX
That's a question you should ask Lightwerkz.
Question about mixed race dmpi Off-Topic 52 09-09-2008 07:41 AM
Impreza headlight housing with sti HIDS, will it work? whifkey Sti Electrical & Lighting 1 04-11-2007 04:20 PM
Question about mixing a JDM and EDM headlight (jdm left side edm right side datdudedennis Electrical & Lighting 5 07-22-2004 11:15 AM
JDM HID light assembly with aftermarket HID kit nicktckhoo Interior & Exterior Modification 8 10-28-2002 10:22 PM
