Old 06-05-2002, 01:57 PM   #1
SoLo OnE
Member#: 9941
www.djforums.com
Question How can you tell if your clutch is slipping?
Whats an easy way to tell if your clutch is slipping or not?
I don't suspect my clutch is but I was wondering if there is a simple way to find out.
I tried testing the accleration, watching the rpms, but I don't know if I'm experiencing a slipping clutch or just turbo lag.
SoLo OnE is offline   Reply With Quote
Old 06-05-2002, 02:28 PM   #2
Jeff 2.5RS
Member#: 1590
2004 Rx8
If the car is in gear, the rpm's are rising like your accelerating, but the car isn't moving anywhere, there's a good chance you're clutch is slipping. It will feel odd the first time it ever happens, you'll probably think you just didn't put it in gear all the way or something, what exactly are you experiencing that you think might be your clutch slipping?
Jeff 2.5RS is offline   Reply With Quote
Old 06-06-2002, 04:01 PM   #3
SoLo OnE
Member#: 9941
www.djforums.com
Basically I put my car into first and the tach went to about 3K before I even started moving.
Plus, lately when I go to put my car into first I don't get any "notchiness" or resistance like I always did before.
Old 06-06-2002, 06:20 PM   #4
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
With a good working clutch, you should see the rpm rise at the same rate as your speed.
If the rpm is rising faster than your speed given the respective gear, then your clutch is probably slipping.
ChrisW is offline   Reply With Quote
Old 06-11-2002, 11:18 AM   #5
SoLo OnE
Member#: 9941
www.djforums.com
Whats a good speed to test the car at?
Cause at lower RPMs the RPMs are gonna rise faster than MPH cause of turbo lag.
Old 06-11-2002, 11:26 AM   #6
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
Any speed should work as long as the engine/clutch is under load
Old 06-12-2002, 01:55 AM   #7
WRXJeep4.0Man
Member#: 19444
97 Wrangler Sport
Royal Blue
pop it a few times, if it jerks like a normal clutch dump its aight but if it dont jerk real hard b/c of takeoff, its slipping
WRXJeep4.0Man is offline   Reply With Quote
Old 06-12-2002, 02:05 AM   #8
Scoobie Snack
Member#: 15548
The more I read your responses to posts the more I think you have no clue what you are talking about.....
put the trans in 5th and put on the e-brake. Slowly let out the clutch and see if the engine dies. Do not give it any gas. If it dies, the clutch is fine, if not.. the clutch is going bad or is bad.
Scoobie Snack is offline   Reply With Quote
How can you tell when your clutch is worn out?? waitandbleed92 Transmission (AT/MT) & Driveline 5 11-01-2003 03:01 PM
How can you tell when the clutch is slipping? quickscooby Proven Power Bragging 7 08-16-2003 07:21 AM
how do you know if your clutch is slipping? jakester Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-09-2002 07:13 PM
How can you tell if your boost gauge is accurate? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-01-2001 07:24 PM
How can you tell if your diff is not working? codemunky Technical Forum Archive 5 09-17-2000 09:53 PM
