#1 |
Member#: 208575
BAIC
Vehicle:2004 wrx silver |
so i pulled the motor out of my car yesterday due to a broken connecting rod. Ive decided to take the route of a hybrid motor. i purchased an refurbished 07 sti block (by Subaru mechanic) and i plan to start the swapping later today. this is the fist time i have ever pulled a motor out of a car. i have read the threads time and time again, i have the OEM gasket set, and a torque wrench. dumb question but what is FSM and any advice at this point will help. thanks
#2 |
Member#: 177840
Vehicle:2000 swapped RS White 330whp |
FSM is Factory Service Manual.
And do you intend to use AVCS? Are you using cometic gaskets to help out the compression ratio? If you don't know what your doing it could be a costly mistake... search for some threads here in the built motor section. |
#3 |
Member#: 208575
BAIC
#4 |
Member#: 24890
SCIC
Vehicle:2002 Jackwagon WRB GG |
Fred Beans is cheaper gasket-set You will have to buy STI head gaskets as well.
#5 |
Member#: 133814
SCIC
Vehicle:2008 AW STI |
How much did you buy the engine for?
Go to flatironstuning.com or call them talk to Jon Cooley he has some knowledge about this swap. |
| Thread Tools | |
| Display Modes | |
| Wrx spring install instructions? | subwrx23 | Newbies & FAQs | 12 | 12-26-2012 09:11 AM |
| FS/PA 2004 EJ257/55 longblock Hybrid | bcooper22 | Engine/Power/Exhaust | 25 | 08-12-2010 05:15 PM |
| FS : PA/DE: Hybrid APS/Precision FMIC kit, TXS Stealthback + Catpipe + Racepipe | Merp | Engine/Power/Exhaust | 15 | 07-27-2010 02:25 PM |
| Hybrid Install issue | WRXbrother | Factory 2.5L Turbo Powertrain | 5 | 02-07-2008 12:17 AM |
| NEED HELP! hybrid install issue | WRXbrother | Newbies & FAQs | 12 | 02-06-2008 09:59 PM |
