Old 04-19-2010, 09:07 PM   #1
cibon7
Member#: 227946
2003 WRX
Default First time doin the 1/4 mile
Hey guys Im going to the drap stip tommorow night for the first time.
Any advice? starting specifically. should be doing around 6 runs
my car il be running.
keep in mind its a DD and i need to make it home from St. Louis to Chicao in a few wks
03 WRX
-full turbo back exhaust
-STI tmic
-cobb access port 93 tune
-short ram intake
-competition stage 2 clutch
-subaru short throw
-Stance gr+ coilovers
-Enkei rpf1(18x8) with falken azenis rt-615s
cibon7 is offline   Reply With Quote
Old 04-19-2010, 09:16 PM   #2
The Cheshire Cat
Member#: 244390
Spark Silver
Arrow
Don't smoke your clutch, or bomb the hell out of your tranny specifically in the launches. Other than that, keep it straight and have fun.
The Cheshire Cat is offline   Reply With Quote
Old 04-19-2010, 09:26 PM   #3
ftnjun2x
Member#: 107096
04 WRX
I usually launch mine at around 5-5500 RPM. We pretty much have the same set up, post your time after the race.
ftnjun2x is offline   Reply With Quote
Old 04-19-2010, 09:29 PM   #4
cash1220
Member#: 156342
the best advice i received for launching is to push the clutch in just a bit so you arent moving and rev to about 2500rpm. when you are ready to go floor it and around 5500rpm slowly let the clutch out. good luck!
cash1220 is offline   Reply With Quote
Old 04-19-2010, 09:29 PM   #5
cibon7
Member#: 227946
2003 WRX
im obviously not goin to drop the clutch because of the fragile trans and i dont wana burn my clutch up because its fairly new but well broken in.
any suggestions on starting at lower rpms?
Old 04-19-2010, 09:33 PM   #6
Ash_J
Member#: 78125
07 WRX STi Ltd 128
Satin White Pearl
Careful not to wreck your trans; launch softly, don't try to rush the shifts, and have fun!
Ash_J is offline   Reply With Quote
Old 04-19-2010, 09:41 PM   #7
The Cheshire Cat
Member#: 244390
Spark Silver
Arrow
Like other people have said, keep it low for the first stage, wind up to a good (but not too high RPM) for second stage and slip the clutch out while trying not to let your RPM's drop too low.
Old 04-19-2010, 10:25 PM   #8
cibon7
Member#: 227946
2003 WRX
i kinda tryed that in an industrial area today and when i let the clutch go it bogged down and it felt like it lagged terribly
Old 04-19-2010, 10:47 PM   #9
ScoobieNoobie790
Member#: 242947
13 WRX Hatch
its cause you were in an industrial area...should have been doing it down some side street with children playing in the street.
lol jk. good luck man, post times aft!
ScoobieNoobie790 is offline   Reply With Quote
Old 04-19-2010, 10:51 PM   #10
WhiteTurbo13
Member#: 134971
2006 Limited WRX
Its not an rsx, dont drop the clutch!!! feather it out...Have fun mann
WhiteTurbo13 is offline   Reply With Quote
Old 04-19-2010, 11:11 PM   #11
Molotov
Member#: 211488
2014 MB C300
1990 Mazda Miata
1. rev engine to redline
2. drop the clutch
3. hold on & enjoy!
4. start wtb 6-speed/ppg thread... lol
Its the question of what you wonna do, have fun or post the best time? Launch gently, shift gently (quite hard to shift smooth but fast). Your main goal to post the best times will be to learn your perfect shift points and shift at them (they will be before redline with your stock turbo).
Had BNR32 and was launching it at 5000-7000rpm (8500 redline) by just dropping the clutch, the way AWD car should be launched imho. Clutch was gone on the second run after switching from street tires to MT ET Street Radials. 450hp @ crank. That was a sweet time...
Molotov is offline   Reply With Quote
Old 04-20-2010, 11:57 AM   #12
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
keep in mind its a DD and i need to make it home from St. Louis to Chicago in a few wks
03 WRX
-STI tmic
-short ram intake
-subaru short throw
don't take it to the strip. i'm not joking. i don't know how to launch either and i wouldn't dare do it with my DD.
Nimbus09 is offline   Reply With Quote
Old 04-20-2010, 02:29 PM   #13
sagvr4
Member#: 170718
04 WRX
dont worry about the tree at all. the timers start when you pass them not when it goes green. also, running the shifter 1-2-3-2-1 a couple times can help smooth things out when you go to shift quickly.
sagvr4 is offline   Reply With Quote
Old 04-20-2010, 02:56 PM   #14
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Please don't ever give advice about launching again. Thank you.
OP- I'm assuming you don't have launch control.
First, before you go you need to find a nice quiet road and find the catch-point of your clutch. The catch-point is the point where the clutch starts to engage. Finding your catch point and knowing how to hold the clutch JUST below it will take the slack out of your drivetrain and allow for a smoother, more precise, and safer launch.
Blip the throttle around 5k-5500. Blipping it allows you to build a bit of boost (or less vacuum) as opposed to holding it at a certain RPM. As you're blipping the throttle, get your clutch to JUST below the catch point.
Don't worry about the green light, as the clock doesn't start until you move. In fact, I suggest waiting and letting the guy next to you be good and gone so you can concentrate, you'll already be nervous just being there.
On an upswing of the RPMs, pull your foot quickly (but not abruptly) up off the clutch as you pretty much put your right foot to the floor. If it's timed right (it will take some practice) you will get just a smidge of tire-spin, and the launch will be smooth and fluid, with virtually no bog and only a tiny bit of clutch slippage.
Do NOT ride the clutch, or you'll be smelling it for hours and hating yourself. At the same time, you're not dumping the clutch. If you've taken the slack out of the drivetrain by finding your catch point, and you get just a tiny bit of wheelspin, you're taking stress off both the transmission AND the clutch, and at the same time getting a solid 60ft time.
If it's done right, be ready to grab 2nd because it will come up quick. Be smooth with the clutch going into 2nd, a tiny bit of clutch slip there will still allow for a very quick run, but won't DROP the torque on the gear. It's shockload that breaks gears, so the smoother you can be about letting out of the clutch and getting into power in 2nd, the better. I wouldn't worry too much about 3rd gear.
As for shift points, on your setup I'd say
1st-7200
2nd-7k~ish
3rd- 6500-6800
And you won't have to worry about 4th-5th
With wheels and tires of that size, you're going to have a tough time getting the perfect launch with the power you've got.
But with a Cobb OTS map and that setup, if you break 13.5 I'd call it a day, as that's about as good as it's gonna get.
Breaking 13s at all on that setup with this being your first time would be considered a good day in my book
Good luck!
And have info and cash for a tow truck JUUUUUST in case
Audiosavvy is offline   Reply With Quote
Old 04-20-2010, 03:26 PM   #15
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
fear the 1-2 shift, if you do it wrong, you'll grenade second gear.
I would ride 1st on the limiter for just a second at times before going into 2nd with the RA gears. I had plenty of passes on my 5sp at the strip. I got through track days by riding the clutch enough to get out of the hole but not completely sidestep the clutch.
Add some air to your tires too, this is key to getting some wheelspin.
SBW is offline   Reply With Quote
Old 04-20-2010, 03:44 PM   #16
Xawn
Member#: 214441
2012 STi
Dude... you're gona' put down a FAST.3 seconds at ZOMGmph.
Xawn is offline   Reply With Quote
Old 04-20-2010, 03:49 PM   #17
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
are you goin to gateway. cuz i drve from st.l to chicago all the time.
crash60068 is offline   Reply With Quote
Old 04-21-2010, 11:46 AM   #18
Alibaba6.0
Member#: 216080
02 PSM BugEyE stg2
Evos can suck it!!
do everthing except launching it unless you chage the tranny, from what i heard the tranny is weak on the bugeyes
Alibaba6.0 is offline   Reply With Quote
Old 04-21-2010, 12:21 PM   #19
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Thousands of us have hundreds of launches and 1/4 mile passes on the stock transmission. Funny thing is, very few of the failures EVER came from launching, most came from the shockload going into 2nd gear.
If he's going to the track and doesn't launch the car, there is zero point in going to the track
Old 04-21-2010, 12:23 PM   #20
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
I've only done drags a few times....never with a Subaru. My rule, if I go again. Bring a car trailer.
Old 04-21-2010, 12:24 PM   #21
unloco187
Member#: 98467
2002 wrx
03 WRX
-STI tmic
-short ram intake
-subaru short throw
you should not go to the track with your DD, that is a horrible idea.
unloco187 is offline   Reply With Quote
Old 04-21-2010, 12:32 PM   #22
Heider
Member#: 172173
2005 Impreza WRX
marked. thanks for the info audiosavvy.
Heider is offline   Reply With Quote
Old 04-21-2010, 12:38 PM   #23
Audiosavvy
Member#: 150794
Qcab dakota 4x4
I recommend doing this in the dirt first, to practice finding your catch point and timing the launch.
Then find a wet or dirty road and practice a few more times.
Then find a clean, smooth road.
Then, if you still have a transmission, take it to the track
Just remember, if you EVER, and I mean EVER get wheel-hop, get out of the throttle. And there's no need to ask what wheelhop is, when you get it you WILL know, it will be violent
It shouldn't be an issue at the track with that power and the grip, but you may get it on the street and especially on a wet road, where it's easier to really break loose.
Old 04-21-2010, 02:51 PM   #24
toneekay
Member#: 185126
2005 STI
AWDtuning feels like sex!
I've been running my car at the track for almost 2 years or so now with no launch control; I've gotten quite well at slipping the clutch heh. My advice to you, since this is your first time, make that first run down the track with no launching/or if you'd like, a very soft launch. Launch rpm can be different from car to car, and this is what you'll need to know before actually "launching" the car. Get familiar with shifting quickly on your first run; get to know your shift points (this'll help eliminate tranny/diff shock). Once you've gotten familiar with shifting, the only thing you have to worry about next is the actual "launch."
The easiest way, imo, to know you're launching correctly (or on the right path) is to keep your foot on the gas at your launching rpm (ex: 4500rpm). When it's time to GO, keep your gas foot there and steady, ease off of the clutch and once you feel the initial pull of the car, that's when you put more gas into it and take your foot completely off the clutch. I don't know if I explained it right, but it seems to work pretty damn well for me... no burning clutch, no tranny shock, no nothing... just you, the car, and the track.
Your tranny won't blow up right away (unless you're being a complete ratard), so try out a couple rpm ranges to first get that "initial pull," and once you've achieved that, then you're on the right path into getting the car off the line and making those quick 60ft times! Good luck and have funnn!
toneekay is offline   Reply With Quote
First time on the 1/4 mile ever. Help diagnose kellygnsd Proven Power Bragging 17 11-02-2008 12:46 PM
First time at the 1/4 sjs0433 Proven Power Bragging 23 04-27-2006 08:56 PM
First time at the 1/4 track, any weight reduction recommended? ST3 Motorsports 2 04-24-2006 11:26 PM
First Time at the 1/8 Mile How did I do... Oo DaRk StAr oO Proven Power Bragging 5 08-02-2003 05:56 PM
First time at the 1/4 mile ([email protected]) dallas_wrx_blue Proven Power Bragging 4 10-28-2002 07:59 PM
