Old 04-19-2010, 09:59 PM   #1
rrsettgast
Member#: 104
2009 WRX Wagon
Default how do you remove the ignition from the steering column?
Hi all,
Does anyone know how to remove the ignition from the steering column. I only see two bolts that appear to be non-removable?? Any help would be appreciated
rrsettgast is offline   Reply With Quote
Old 04-19-2010, 10:07 PM   #2
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
oops, wrong thread. gl tho, btw, what does it look like on the other side ?
etothen is offline   Reply With Quote
Old 04-20-2010, 02:47 AM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
drill a hole into the tops of the bolts and use a screw extractor.
jamal is online now   Reply With Quote
Old 04-20-2010, 03:21 AM   #4
shatteringstar
Member#: 149604
2006 Limited WRX
planning on stealing a car? just cuirous
shatteringstar is offline   Reply With Quote
Old 04-20-2010, 04:13 AM   #5
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
i had to do this on my CRX after it was stolen and i had to replace the piece that was broken off with a hammer. i took a dremel and cut a slot into it, then used a flat head screwdriver to remove it.
gsrcrxsi is offline   Reply With Quote
Old 04-20-2010, 07:11 AM   #6
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Dremel a slot into the bolt heads, then unscrew them. They come out easily.
sniper1rfa is offline   Reply With Quote
Old 02-20-2013, 04:39 PM   #7
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Hate to bring back from the dead but mine was broken into and I bought a new steering column. Could i simply do this instead of installing the whole column? I have the key for the old and new one also.
boostmasterflex is offline   Reply With Quote
Old 02-20-2013, 06:01 PM   #8
25rsti
Member#: 166324
Yes you can swap it all over.
How do you remove 6point lugs after the tool has been destroyed?? NewShockerGuy Tire & Wheel 14 05-24-2009 05:01 PM
How do you remove the throwout bearing from the PP? TreyS Transmission (AT/MT) & Driveline 2 10-20-2007 09:46 AM
How do you remove front axle from the diff??? krayjeegsr Transmission (AT/MT) & Driveline 3 07-19-2007 07:39 PM
How do you remove leather boot from leather shift knob? Bob O Normally Aspirated Powertrain 2 12-13-2000 07:31 PM
