Old 06-05-2002, 05:52 PM   #1
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Default creating to much interference from colder plugs???
plugs that your using are to cold and are creating to much interference. We have seen
this before in coils and non-resistive plug wire
from link as to why I'm having issues at full boost
anyone want to comment on this?
Jan even told me that he has seen this on older Links
I can upgrade the software thats on the board right now...
JenisonWRX is offline   Reply With Quote
Old 06-05-2002, 06:46 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Sounds like they don't even realize you're running a Coil-On-Plug (COP) ignition. I would expect zero interference/noise. Sounds like BS to me.
Jon [in CT] is offline   Reply With Quote
Old 06-05-2002, 08:15 PM   #3
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Links are not just used in subarus
Old 06-06-2002, 01:26 AM   #4
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
What issues you seeing at full boost?
I'm running colder plugs in my car, and my full boost (20psi) situation is just fine... other than the occassional TP slap in the face, but even that has disappeared a bit since I reduced my accel numbers down to anywhere from 9 to 12. I think the bug is still there, it just doesn't "hit" me as hard for some reason
DarthChicken is offline   Reply With Quote
Old 06-06-2002, 03:16 AM   #5
JenisonWRX
Member#: 6049
02 WRX & 99 RS
you didn't see my other threads???
injectors slam shut...
when did you get your Link? They have a software upgrade that I can do...
Old 06-06-2002, 10:09 AM   #6
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Sorry, I had missed those - did a search, know what you're talking about now.
So, zone 745 and 750 are 4500 to 5000 RPM, on row 120. Boost isn't too high, RPM obviously isn't.... care to share a log with us?
It sounds like Just the opposite of what Sponaugle and I (and I'm sure many others see). TBS of:
98,98,98,98,98,98,12,98,98,98,98
but %FF of:
75,75,76,76,76,76,99,99,99,99,87,77
I'm not using their latest upgrade (the 5/22 upgrade) at this time, because I have an issue with using a software upgrade with no release notes. And to think I use windows
What do you mean software upgrade? You mean firmware, on the board? Flashable bios type of thing? I bought my Link probably 2 months ago or so...
Old 06-06-2002, 11:58 AM   #7
Kartoffel
Member#: 12976
grocery getter
I've been running 7 temperature range NGK platinums for 5000 miles in a COMPLETELY STOCK motor. No boost control. No aftermarket turbo. Stock injectors. Only mods are silicone intake and intercooler hoses and some Redline water-wetter in the radiator.
Plugs work just fine. No problems, whatsoever.
Maybe the people who are having plug problems aren't gapping them properly?
Kartoffel is offline   Reply With Quote
Old 06-06-2002, 05:22 PM   #8
JenisonWRX
Member#: 6049
02 WRX & 99 RS
yes the actual board it self. if they replace a chip or reflash or what...I dunno
my gapping matched stock
Old 06-06-2002, 05:41 PM   #9
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Log as requested...
records 63 - 73 is when it happens....
Old 06-06-2002, 07:12 PM   #10
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
What do you have your accel numbers set at? I see your coming off throttle, then getting back on the throttle when it occurs - does it always happen at about that time?
You got some NASTY knock in there as well, although I'm guessing thats probably just you shifting at 7500RPM, right?
Old 06-06-2002, 07:25 PM   #11
JenisonWRX
Member#: 6049
02 WRX & 99 RS
yes...I was shifting...
and its not the accel....cause I get it to happen at that zone at any time. The boost creep thread...I can still hit 15psi...as soon as I do....bam...it happens...
so it doesn't happen right when I get on it...I can do partial throttle and it will still happen
Old 06-06-2002, 07:31 PM   #12
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Are you controlling your boost via the LINK, or with another method (ie MBC or EBC). I'm grasping at straws now... as you said, knock is ok, o2 is ok (right up until it dies on you) %FF is ok... maybe you should just avoid that particular part of the map
(sorry, not very helpful)
Old 06-07-2002, 10:39 AM   #13
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Lightbulb
One thing I would remedy right away is your TPS settings. I noticed your full throttle setting yeilds 102% TPS which I heard is *bad*
ScoobieSnaX is offline   Reply With Quote
Old 06-07-2002, 11:23 AM   #14
JenisonWRX
Member#: 6049
02 WRX & 99 RS
I had reset to the stock map just to see if that would 'help'
yes...didn't reset that...
*sigh*
Old 06-07-2002, 12:54 PM   #15
phast
Member#: 7957
Interesting.. I still have the stock plugs, so I can't really add.
I noticed your o2 values are reading somewhere in the range I'd like mine too. I see anywhere from .97-1V at WOT. I try to take out fuel and the thing just knocks like mad. I wish I had access to a WB(waiting for a tech edge kit) so I could get some real numbers.
What kinda o2 voltages are other people seeing at WOT on boost?
phast is offline   Reply With Quote
Old 06-07-2002, 02:59 PM   #16
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
I'm usually at around 11 or 12.0:1 at WOT. I managed to get my knock under control with the help from my newly installed WBo2!!!
So I use the laptop to tune the Link and the Palm IIIc to datalog the WBo2 stuff....
You NEEEEED to get one dude!
Old 06-07-2002, 03:52 PM   #17
JenisonWRX
Member#: 6049
02 WRX & 99 RS
why not 1 unit for both?
Old 06-07-2002, 07:04 PM   #18
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
The laptop only has one COM port
I've thought about using a USB--->Serial adaptor but the WBo2 program will only read COM ports....not USB...
STI NGK Colder plug numbers from SEMA. Wombat North Service & Maintenance 27 06-09-2014 12:33 PM
Which of these NGK Iridium one-step colder plugs should I buy? lotarg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-01-2010 12:54 PM
where to buy one step colder plugs drifterATheart Texas Impreza Club Forum -- TXIC 3 06-29-2007 06:38 PM
When to use 2 stg colder plugs Porkchop-WRX Service & Maintenance 5 03-05-2007 08:25 AM
how to install one step colder plugs and Fuel pump? stevo2234 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-18-2005 10:57 PM
