Old 04-20-2010, 07:28 PM   #1
04sedantyson
Member#: 233011
2004 04 sedan
Default stage 1 boost
04 wrx stage 1 93 oct. I used my v1 to see what kind of boost I’m hitting . I’m hitting 13.8 ps (.08 stock gauge)i. I think my target boost is supposed to be around 15psi.
My question is, is this ok, or do I need to load HWG map?
I looked into adjusting the wastegate, but my arm has no slop in it. Its snug with no play.
The adjustment nut looks like it would be a pita to get loosened up
I was thinking of slapping on a Dp and going to stage 2 , but would I still get the same boost?
Any suggestions? Should I just let it roll like this, i realy dont want to mess with the wastegate unless i have to.
04sedantyson is offline   Reply With Quote
Old 04-20-2010, 09:05 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
the maps have boost targets. air temperature and humidity can affect boost levels. try hitting boost in 3rd or 4th gear. stage 2 might be higher boost levels depending again on what are the targets. maybe someone else can add more.
424wrx is offline   Reply With Quote
Old 04-20-2010, 10:31 PM   #3
04sedantyson
Member#: 233011
2004 04 sedan
thanks for the reply, i have to buy a adapter so i can load the hwg map and try it. if theirs no change i'll just leave it as is.
Old 04-25-2010, 01:18 PM   #4
04sedantyson
Member#: 233011
2004 04 sedan
wanting to go stage2 , but i have a turboxs sri. I like the sound of the factory bov,but can i safely leave this on there. would i need to extend it into the fender to draw cool air in? have catless dp on the way
Old 04-25-2010, 10:37 PM   #5
norcalwrx816
Member#: 203489
03 wrx wagon
flat4/Mayhem Tuning!
your stock BPV will be ok there are no good after 23psi and your SRI will fine also just get that TBE,UP,DP
norcalwrx816 is offline   Reply With Quote
Old 04-26-2010, 07:08 PM   #6
04sedantyson
Member#: 233011
2004 04 sedan
catless uppipe has been installed
Stage 1 Boost 06 WRX with Spt Intake? dan1587wrx AccessPort 2 05-02-2007 08:31 AM
06 STi AP Stage 1 Boost FtW_STi AccessPort 4 04-14-2007 12:33 AM
Cobb Stage 1 Boost brizey Engine Management & Tuning 11 09-27-2003 03:02 PM
Utec Stage 1 boost tuning C Dust Engine Management & Tuning 10 08-01-2003 01:14 AM
Help with Stage 1 boost questions trehlo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-27-2002 01:50 PM
