Old 04-20-2010, 07:59 PM   #1
TurboTrey03
Member#: 60096
02 WRX
Unhappy ej255 into 02 wrx?
First all, thanks for anyone who can be of any help. Will an 07 ej255 swap in an 02 wrx without any problems? My mechanic said I'm having oil issues thats causing the left side intake cam to lock up and he's not sure if its the block or the oil pump. All things aside would it just swap right in?
The car ran fine for the first 3 days after the swap but when I started it up one night it start making a screeching sound and then it would not start.
Any help would be great. Thanks
TurboTrey03 is offline   Reply With Quote
Old 04-20-2010, 08:19 PM   #2
skater0422
Member#: 121162
04 Wrx
Did you use your heads or 255 heads?
skater0422 is offline   Reply With Quote
Old 04-20-2010, 08:21 PM   #3
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
With your heads, yeah, with 255 heads, no. You would need to block off the AVCS ports, or do wiring and an ecu to use the AVCS.
elevenpoint7five is offline   Reply With Quote
Old 04-20-2010, 08:33 PM   #4
TurboTrey03
Member#: 60096
02 WRX
im pretty sure he used my heads. so the motor not starting/having oil problems wouldn't be the compatibility of the sb but something else.
Old 04-20-2010, 08:40 PM   #5
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Probably the pump. But verify the head and cam issue first.
Old 04-20-2010, 08:45 PM   #6
TurboTrey03
Member#: 60096
02 WRX
thanks a ton..could you clarify what the cam issue would be..whether or not he blocked off the AVCs port?
It ran fine for 3 days and then it cut out and the oil light came on and it wouldn't start. Just to clarify the car had been sitting for over 7 months before I got around to fixing it.
Thanks again.
Old 04-20-2010, 09:27 PM   #7
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Yeah. If he used 255 cams he needed to block off oil ports.
Once the oil light comes on USUALLY there is damage that needs to be fixed. Bearings, rods, crank, cly walls, pistons, who knows. Depends on how bad the failure was.
Andy
EJ255 into 04 wrx question gotawd Subaru Conversions 3 04-08-2009 01:34 PM
2004 Transmisson into 02 wrx/wrx SilvSuby Transmission (AT/MT) & Driveline 24 08-20-2006 10:54 AM
05 WRX tranny into 02 WRX...clutch problems? HeeroRaven Transmission (AT/MT) & Driveline 3 07-20-2006 03:26 PM
05 wrx 5mt into 02 wrx - can i use my 02 front axles? LatentWagen Transmission (AT/MT) & Driveline 5 05-29-2006 10:14 AM
02 sti headlights into 02 wrx lvperuano Subaru Conversions 1 02-23-2006 12:00 AM
