Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 04-20-2010, 09:47 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default MAF Scaling - Smoothness Theory (Some Experiments)
So I've been wondering how "smooth" a maf scaling has to be. So I did some homework and made a tool that "best" fits some high order polynomial equation to the maf scaling. Taking into account suggested corrections for romraider's maf tool and airboy's spreadsheet.
So here's my original scaling that kept all my fuel trims <4%
Maf Scaling:
first discrete derivative to show smoothness or slopes between cells
Not so good. Looks like it could be smoother. So I used the smoothing tool and got:
and the smoothness looks like:
Loaded the map and tried it out. Took the CL part for a spin and found out I have 18% - 7% corrections all over the place. So then I applied the RR suggested corrections to my maf scaling and I'm back at:
for smoothness.
So, in conclusion, it looks like the maf curve doesn't have to be "super smooth" From what I can tell, as long as there are no jagged spikes or huge dips in the scaling, it's all good.
-BN
Bad Noodle is offline   Reply With Quote
Old 04-20-2010, 09:49 PM   #2
SubieFiesta
Member#: 149426
2002 Subaru WRX
and 2005 Subaru STi
nice job
SubieFiesta is offline   Reply With Quote
Old 04-21-2010, 12:18 AM   #3
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I still think smoother would be better. Try setting up a scatter plot in Excel, and smooth it manually, that's what I do. I've been accused of being obsessive though and I can't argue with that.
Old 04-21-2010, 02:34 AM   #4
arghx7
Member#: 232940
As a control, why don't you use this method on the stock calibration for several different models? Like 02 WRX, 04 STi, 05 LGT just download the stock roms and pull the data from there.
arghx7 is offline   Reply With Quote
Old 04-21-2010, 06:57 AM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I've been obsessive about it too, but am starting to realize that it might not be beneficial. I smooth manually, run the auto smoothing algorithms, then manual smooth again.
I ran the last smoothness scaling I posted this morning and I'm back within 4%.
I agree that smoother would be better, in theory, but practice isn't coming to the same conclusion. I guess the lumpiness of the first derivative is just a way of saying that the MAF sensor isn't a perfect sensor and the deviations from the perfectly smooth graph are it's shortcomings. I'm sure everyone's would look different on the fine scale but show the same patterns on a large scale.
I've checked them out and they're somewhat smooth. They have dips in places where the voltage step isn't consistent. I've also checked out other scaling people have posted and some from protunes I've gotten. Same result, they're not all super smooth. The first derivative is usually "lumpy" to a limit
Old 04-21-2010, 09:27 PM   #6
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
I found the same thing you have. I try to keep some form of a smoothness to the curve but most of the time the maf scale wont be a perfect curve.
fastblueufo is offline   Reply With Quote
Old 04-21-2010, 09:43 PM   #7
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I worked out my maf curve to <4% again. Car runs smooth, good power, no knock but the curve looks like:
it ain't pretty, but it works
Old 04-22-2010, 12:17 AM   #8
NSFW
Member#: 140444
05 Stage Free LGT
I just realized that when you say "smoothness" you mean the derivative, not the curve itself. I take back what I said. I thought those wiggly lines were your MAF scaling.
Yeah, I wouldn't lose sleep over the wiggly lines in the derivative of the scaling. I basically just want the "actual AFR / desired AFR" scatter plot to be symmetrical and not too wide.
Old 04-22-2010, 10:30 AM   #9
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Mine is definitely not perfectly smooth. I don't think it's a problem with the sensor, I think it's turbulence in the MAF pipe that creates a non-linear relationship between total mass air flow and air velocity at the sensor. The MAF sensor is essentially reading air velocity, in a perfect world this would be directly proportional to the mass air flow rate in the pipe at all flow rates, however in the real world it's HEAVILY dependent on the air flow pattern through the pipe, and how that changes with varying air speeds. At low speeds you might have a high velocity node right at the sensor, so the sensor reads higher than what a smooth curve would dictate and your MAF scaling has to be reduced at that voltage. At higher speeds you might have a high velocity node in another part of the pipe, and a low velocity node right at the sensor, so the sensor reads a little lower than what a smooth curve would dictate and your MAF scaling has to be increased at that voltage.
Old 04-22-2010, 10:42 AM   #10
arghx7
Member#: 232940
You have to remember that the factory scaling is done in expensive simulation software using proprietary data. If it's not perfectly smooth then it doesn't surprise me that a decent custom scaling isn't perfectly smooth either.
Also, are you using an Excel macro to calculate these derivatives?
Old 04-22-2010, 10:49 AM   #11
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
na, the derivatives are slopes between adjacent cells.
Old 04-22-2010, 01:18 PM   #12
NSFW
Member#: 140444
05 Stage Free LGT
The more factory tunes I see, the more I'm convinced that they don't use any better tools than we do.
Maybe here there, to check some aspect of their tune... But in general I suspect they were done by people who get paid to churn out as many "good enough" tunes as possible, as cheaply as possible. Not by people who get paid to produce perfect tunes using amazing tools, and are given enough to time to do it right.
There's a little bit of hyperbole in what I just wrote, but not much.
Old 04-22-2010, 01:30 PM   #13
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Is each tune custom to the car or do they just make one tune and slap it on all factory vehicles?
Old 04-22-2010, 01:35 PM   #14
Member#: 51961
2005 STi
2012 WRX
One tune for all vehicles of a given year/model. Sometimes they'll revise the tune mid-year, but that's about it.
Old 04-27-2010, 10:09 PM   #15
shutupnshift04
Member#: 101710
BOSS
Shouldn't you get the maf scaled then smoothed and then change the other tables ie timing and afr to get the car to run its best?
shutupnshift04 is offline   Reply With Quote
Old 04-28-2010, 06:35 AM   #16
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
yeah, but that's a whole different thing.
This thread is about defining or finding the meaning of "smooth" in terms of the the allowable changes between cells on your maf table.
Old 04-28-2010, 06:40 PM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i still dont really understand what the hell im looking at.....
Old 04-28-2010, 07:20 PM   #18
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
You're looking at the maf scaling as a graph, then the corresponding slopes between cells. Slopes between cells can be used to describe "smoothness". When a function or graphed line is "smooth", the changes between two values are predictable. Therefore you can judge how smooth something is by taking the derivatives of the equation. In this case, there is no equation for the maf curve. So you look at the slopes between cells to determine if the maf scaling is changing in a gradual and predictable way. If it is, then it's "Smooth"
The more discrete derivatives you take of the data, the more you can tell how smooth a data set really is.
In this case, my maf scaling got bumpy after the first derivative showing that my scaling isn't smooth. I fitted polynomial equation to the maf scaling to make sure it is smooth, then tried it out. It didn't work, reverted to original unsmooth scaling, and everything was ok again. Conclusion is that maf scaling doesn't have to be super smooth, so it's probably best to just use the romraider maf tool suggested value.
Old 04-28-2010, 07:23 PM   #19
flatthump
Member#: 102749
2005 impreza STi
OBP'
I'd much rather have the AF corrections linear or flat than i would want the MAF scaling smooth.
flatthump is offline   Reply With Quote
Old 04-28-2010, 07:34 PM   #20
flatthump
Member#: 102749
2005 impreza STi
OBP'
Use a Delta command to find corresponding deltas between cells then make another command using those Deltas to calculate the slope between cells. Then just graph it.
Old 04-28-2010, 07:46 PM   #21
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
you gotta use the slope formula because the voltages are not all evenly spaced.
So just use
slope = (gs[x+1] - gs[x])/(v[x+1] - v[x])
and I agree about the zeroed learning view over smooth scaling.
It always bothered me that cobb's tuning guide says the maf scaling should be smooth, but doesn't specify how to judge that.
Old 04-28-2010, 08:11 PM   #22
flatthump
Member#: 102749
2005 impreza STi
OBP'
So just use
That would work. But I just evenly space them. In 2007 Excel I can do it easily. I'll try your way next time.
Old 04-28-2010, 08:18 PM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
you judge it visually......you'd be surprised at what some peoples maf scales look like....
i use the MAF tab to collect data....but i input the data into ecuflash while im looking at the graph to make them smooth....
Heres 5 MAF scales.....i did 4 of them.....1 of them is "not smooth"...its pretty apparent which one.
Old 04-29-2010, 01:00 AM   #24
arghx7
Member#: 232940
Have you ever heard of tools like Matlab Simulink? Are you familiar with hardware-in-the-loop simulations?
Old 04-29-2010, 01:45 AM   #25
NSFW
Member#: 140444
05 Stage Free LGT
No hands-on experience, but sure I'm passingly familiar with the theory.
Why do you ask? Do you have reason to believe that Subaru's (Denso's?) tuners use them?
I have a hard time believing it makes economic sense to invest that much in something that can be done sufficiently well. with trial-and-error. Or maybe that's the problem... I mean, a hastily brewed simulation would go a long ways toward explaining the wacky timing tables I've seen in stock 2002 WRX tunes.
Anyone have the maf scaling values for an Perrin Big MAF. Stock WRX injectors NITROS Open Source Reflashes 1 02-05-2008 06:57 PM
probably elementary questions - maf scaling, afr targets, UTEC wg control gpatmac UTEC 36 04-05-2006 05:11 PM
UTEC MAF Scaling? Ski Man Engine Management & Tuning 1 10-10-2005 08:48 AM
a/f learning and maf scaling deluxsti Engine Management & Tuning 2 06-06-2005 04:22 PM
what is MAF scaling? erggy Engine Management & Tuning 0 11-29-2004 11:36 AM
