Old 04-21-2010, 02:17 PM   #1
newrx
Member#: 229821
Default "stage 2" boost question
Hello,
I've searched these forums a few days now and didn't find a satisfying answer.
My 06wrx with a catted bellmouth (speedtech) downpipe doesn't seem to get past 12 psi in 3rd at WOT. This is according to my Lamco gauge/AP reading. stock turbo/stock catback/stock intake (no snorkle)/ stock BPV with new gasket & STI TMIC. I rechecked the intercooler piping/fittment.
I reused the OEM downpipe gasket because it looked great (30K miles) and seemed to be more durable than the one supplied with DP. Have a rally sport adapter to mate DP to catback. NO leaks there.
Question: Am I not hitting target boost due to the OEM catback and catted dp? Anyone install a DP only (with EM) and have these issues?
I know 06-07s are recommended catted DP due to boost spike issues (per cobb map notes)
Is there anything on a data log that would be "out of wack" if there was a leak someplace?
BTW the car ran stage 1 for 4 months with no issues. car idles and drives smoothly I'm just curious what's going on. I've driven for 5 days to give the ECU time to learn still no improvement (COBB OTS stage 2 map). It seems to hit slightly higher boost on the interstate in 5th gear WOT (~12.6psi)
I am tempted to redo the DP gasket.....but I don't think a leak there would impair boost capability of the turbo.
Thanks for your input!
newrx is offline   Reply With Quote
Old 04-21-2010, 03:35 PM   #2
07wrx4life
Member#: 171514
07 DOM 3 WRX
352/326 @ 20psi EQ Tuned
You most likely have a leak post turbo, Build your self a pressure tester and have at it, Most cars have a number of leaks and the owner doesn't even know it.
07wrx4life is offline   Reply With Quote
Old 04-21-2010, 04:02 PM   #3
bzbuzz
Member#: 116052
2011 STI ( Sold )
you not supposed to use sti tmic with ots map.
bzbuzz is offline   Reply With Quote
Old 04-21-2010, 04:14 PM   #4
Want_To_Buy
Member#: 238843
1997 Honda
Accord
who says?
Want_To_Buy is offline   Reply With Quote
Old 04-21-2010, 04:19 PM   #5
d4nk
Member#: 127103
2006 WRX Wagon
Grey
While the OTS stage 2 map was not designed to be used with a STi TMIC, I don't think that it would be the main contributor to your boost issues.
I actually have a similar setup; stage 2 06 wrx w/ STi TMIC. I just added a catback recently and it did lead to an increase to peak boost. Prior to the catback, I was peaking at ~14psi in third gear and now I'm consistently hitting 15.5 to 16psi in 3rd and 15 psi in 2nd, according to my accessport.
You may still want to check for leaks where your dp connects to the turbo b/c I think that it would factor into your issue.
d4nk is offline   Reply With Quote
Old 04-21-2010, 04:30 PM   #6
Want_To_Buy
Member#: 238843
1997 Honda
Accord
Originally Posted by newrx View Post
Hello,
stg 91 or 93
Old 04-21-2010, 04:55 PM   #7
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I think you mean pre-turbo
Not true, kind of. Cobb has said that it will no create an issue if your talking about their OTS map. Somebody else might have had a very specific one that you can't use it, but that would be so specififc you shouldn't use it on multiple cars.
Will
GrimmSpeed is offline   Reply With Quote
Old 04-21-2010, 08:40 PM   #8
newrx
Member#: 229821
any way to confirm leak theory with datalog?
appreciate everyones help. btw using stage 2 cobb 91 octane map
Old 04-21-2010, 09:32 PM   #9
hobbesnapoli
Member#: 221436
02 WRX vf39
Could be a vacuum line problem or a bad boost control solenoid... you could test ****CAREFULLY**** by unhooking the vacuum lines to the WG and Compressor housing and letting the car build boost... just be careful, it'll spike really quickly
hobbesnapoli is offline   Reply With Quote
Old 04-24-2010, 09:02 PM   #10
newrx
Member#: 229821
oh so update on my problem......I checked for leaks using a home made pvc/leak tester and found 3 leaks on the STI top mount that are now patched up.
I was unable to build enough pressure in the Inlet pipe/pre turbo to see if there's any leaks there. (blocked off PVC and purge solenoid) but air is still leaking someplace. Any advice? I used the old soap water and low pressure air compressor trick....
Boost is now up an extra PSI but still below target....
Thanks!
Old 04-25-2010, 10:51 PM   #11
norcalwrx816
Member#: 203489
03 wrx wagon
flat4/Mayhem Tuning!
Hello,
5th gear pulls are bad.to always check your boost use 3rd gear from 2500 pull to 7k...like grimmspeed said you can use a sti tmic.you do have a bad boost leak somewhere if your only hitting 12.6lbs and the exhaust gaskets shouldnt effect your boost that much ur leaking...my guess is your tmic coupling to turbo so build a boost leak tester and go from there......
norcalwrx816 is offline   Reply With Quote
'07 STi "stage 2" at the track rxer311 Proven Power Bragging 14 04-27-2008 04:51 PM
Looking to go to "stage 2" 07SWPSTi Newbies & FAQs 31 10-18-2007 08:13 PM
Our take on a "stage 2" P&L Motorsports Inc. Proven Power Bragging 30 04-12-2007 12:29 PM
"stage 2" 2.5L WRX at 3500' and sea level Airboy Engine Management & Tuning 1 01-09-2007 01:27 PM
FS: 04 Ecutek ecu - "stage 2" Panic Engine/Power/Exhaust 5 10-03-2006 04:16 PM
