Old 04-22-2010, 12:06 AM   #1
Heater Guy
Member#: 215239
Default Laminovia Oil Coolers
Anyone using these water to oil coolers? Results good or bad?
Heater Guy is offline   Reply With Quote
Old 04-22-2010, 01:26 PM   #2
garageGT
Member#: 80524
i got 4 cores here sitting for over 2 years.. couldnt get around the fact that i needed a huge heat exchanger... i have a design (on paper) where you integrate the cores into the STi intake manifold, pretty cool but no testing yet..air to air does the job well for us. Do some search on the off road forums, there are guys who are running these already..but they dont reach the speeds we do on hi speed tracks.
garageGT is offline   Reply With Quote
Old 04-22-2010, 03:15 PM   #3
MasterKwan
Member#: 98961
2003 WRX
Why not just use the water lines from the existing oil cooler? I've been thinking about using one for my M3 but, it doesn't really have a natural hookup point like the STI/WRX does. I'd probably have to use the heater lines and have to remove the heater control valve or maybe the throttle body heater circuit might work too.
Old 04-22-2010, 04:24 PM   #4
garageGT
Member#: 80524
I dont think it will be cool enough with the OEM cooler setup..
laminova is very tempting but i just cant think of a good enough reason to do the setup..maybe if i was a drag racer
Old 04-22-2010, 04:25 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
He's talking oil-to-water coolers for engine oil, not air-to-water cooler for the intake charge air. No huge heat exchanger needed - it's called the radiator.
I've never used a Laminova personally, but from what I've read they seem to be very effective. Assuming, of course, that your coolant system has the capacity to handle the added heat load.
Pat Olsen
Old 04-22-2010, 04:54 PM   #6
garageGT
Member#: 80524
Pat Olsen
hmmm yes he was sorry..
oil cooler issue 06D Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-07-2010 05:26 AM
Top mount Oil cooler/tran cooler ColesSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-31-2006 09:10 AM
Leaking Oil from oil filter/oil cooler AustinSTi Normally Aspirated Powertrain 3 01-08-2004 01:42 AM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2002 10:40 AM
spark plugs, oil coolers, transmission coolers, upgraded radiator, who has them? ChristophWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-04-2002 01:48 AM
