South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 04-22-2010, 10:54 AM   #1
enominus
Member#: 130622
1998 2.5RS
Default 04 sti pulling ? info?
hey guys im looking at this 04 sti right now, and it seems like its pulling to the right a little bit, any ideas what the problem could be?
enominus is offline   Reply With Quote
Old 04-22-2010, 11:14 AM   #2
PHXSTI
Member#: 144620
2006 Dom 3 STI
needs an alignment?
PHXSTI is offline   Reply With Quote
Old 04-22-2010, 01:13 PM   #3
enominus
Member#: 130622
1998 2.5RS
thats what i was thinking since its not during braking or anything, just cruising. thanks for the input.
Old 04-22-2010, 05:26 PM   #4
washingtonian
Member#: 239426
05 sti
My '05 sti pulls a little to the right too while crusing. I had the alignment checked and that wasn't the problem. Still pulls...
washingtonian is offline   Reply With Quote
Old 04-22-2010, 05:49 PM   #5
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
theyre supposed to pull to the right a little.
AWDshenanigans is offline   Reply With Quote
Old 04-22-2010, 06:20 PM   #6
enominus
Member#: 130622
1998 2.5RS
yea i did some research and it might be a worn steering rack bushing. or uneven treadwear, idk i dont want to buy this if it is puling at all.
Old 04-22-2010, 06:37 PM   #7
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
It should always pull a little bit to the right over a distance because of the crown of the road. The freeway is a better place to test it as they are flatter.
Old 04-22-2010, 06:37 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
Perhaps it was in a wreck and not repaired properly. If the chassis is tweaked, you may never solve the problem.
Old 04-22-2010, 07:04 PM   #9
racingfish
Member#: 60976
1969 LGT
FATURBO
1. check ur tire pressure
2. tire wear
3. crown of road (drive on the oppisite side of the street and if your car pulls left then its the crown).
4. kick the fat chick outta the passenger seat.
racingfish is offline   Reply With Quote
Old 04-22-2010, 07:36 PM   #10
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
^ @ 4
Old 04-22-2010, 09:37 PM   #11
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
ask teh guy if YOU can take it to an alignment shop and if it checks out you'll buy it (not really but that's the only way you can get him agree if he's not hiding any prior knowledge of damage)
If you don't tell him that you'll buy it, he just might not want to deal with going out of his way when other people will probably buy it.
Or you can check it yourself, check all the fender, bumper and door gaps. Look under the car and see if anything looks misaligned or and differences in gaps between the frame and subrame.
Look at the tires, if one of them is worn badly on the inside or outside then that is an indication of a problem, specially if they are on the back as they have rotated them to the back. If two tires are worn on the edges, but evenly between the two, then it could just be normal.
Pulling to the right is normal in AZ though, because we take some many long left turns and sharp right turns. That's how the tires will wear, combined with what fish said the crown of the road.
Could be simple low tire pressure, slow leak. But the flip side to that is, most people that take their cars in for regular service at a decent place, they will fill the air in the tires when they change oil or whatever. They would then tell the owner that one tire needed a lot of air and should be checked.
bobturismo is offline   Reply With Quote
Old 04-22-2010, 11:02 PM   #12
enominus
Member#: 130622
1998 2.5RS
Oh yea the guy seems legit, he's going to take it to an alignment shop to see if that's the issue and take care of it as I told him I'll buy it if that issue and a possible idler pulley going out are fixed. I'm just trying to figure what it could be since i used to have a 04 wrx and never had a pulling issue.
Old 04-22-2010, 11:21 PM   #13
hkssubbie02
Member#: 146863
2004 STI
jbp 98 fozzy
pulling to one side is always alignment or tire issue
hkssubbie02 is offline   Reply With Quote
Old 04-22-2010, 11:56 PM   #14
kpluiten
Member#: 120273
06 WRBWRXWGN
Or a tweaked chassis. I've driven behind cars that are going down the road sideways because of a terrible chassis repair. I mean I could see 1 inch of front tire and the side of the vehicle on the right side and nothing on the left.
Old 04-23-2010, 01:26 AM   #15
gormonk
Member#: 98960
1978 brat (fo realz)
red
wrong
pulling while accelerating or braking is a alignment or tire issure. a car can still pull with neither of those being the problem
gormonk is offline   Reply With Quote
Old 04-23-2010, 01:52 AM   #16
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
I have nothing to add but funny how people chime in like this. Did you read any post in the thread at all? Are you contradicting what others are saying? Not trying to be an asshat.
Smoby is offline   Reply With Quote
Old 04-23-2010, 04:05 AM   #17
racingfish
Member#: 60976
1969 LGT
FATURBO
i find it funny too.. and considering that me and gormonk worked for SUBARU..... id probably have to side with what we say... lol if soa trusted us... than u should too.
Old 04-23-2010, 04:14 AM   #18
FastS2k
Member#: 59577
04 fxt notansti
s2000 reallynotthatfast
If it's pulling to the right only on acceleration, then it's most likely a low right tire pressure. If it pulls to the right all of the time, then it's possibly suspension/alignment issue.
FastS2k is offline   Reply With Quote
Old 04-23-2010, 04:17 AM   #19
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
No one trusts you Fish.
C-grunt is offline   Reply With Quote
Old 04-24-2010, 01:29 PM   #20
racingfish
Member#: 60976
1969 LGT
FATURBO
i was going to say "your mom does"
but i wont
Old 04-24-2010, 02:28 PM   #21
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
wait didnt you get fired?
SubeSTIle is offline   Reply With Quote
Old 04-24-2010, 03:48 PM   #22
enominus
Member#: 130622
1998 2.5RS
ouch!
Rebuilding an 04 STi 6MT? INFO? hotshot2109 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-02-2009 06:18 PM
04 sti hub info Decon Transmission (AT/MT) & Driveline 3 04-06-2009 03:01 AM
04 STI Security Info KillerRabbit Car Audio, Video & Security 7 02-13-2009 01:27 PM
Question about deal on an 04 STI - pull the trigger or not??? joeyb7 General Community 39 02-22-2006 09:15 PM
04 RS and 04 STi Tophat info needed Vkng Brakes, Steering & Suspension 3 12-01-2005 10:03 AM
