Old 04-22-2010, 10:30 AM   #1
CastIron
Member#: 191940
Default 97 LGT - Replacement Engine Compatibility
The engine in my '97 LGT just imploded, so I'm looking for a replacement. Is it safe to assume that all four-cam non-turbo EJ25s will wire up without a problem? Is there anything else that will work without too much headache? Any of the SOHC motors perhaps? I'm just looking for something cheap and easy.
CastIron is offline   Reply With Quote
Old 04-22-2010, 05:47 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
You're basically stuck with the EJ25D (DOHC non-turbo), as the SOHC engines used a different ECU and the harnesses aren't interchangeable.
Old 04-23-2010, 12:37 AM   #3
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
You can however put the DOHC heads on to a later model "Phase II" SOHC with no major issues although you will be significantly increasing the compression ratio. In fact, Subaru did build several DOHC Phase II hybrid motors when SOA's inventory of EJ25D engine blocks ran out late in the 1999 model year. This to me suggests that Subaru likely produced a number of lower compression pistons to work in such a hybrid motor. Correct ?
Cam sensors, knock sensors, etc... these should work fine in both motors, right ?
It is basically an issue of using the Mass Air Flow (MAF) sensors in place of the Manifold Absolute Pressure (MAP) sensors, right ?
What other issues are there ?
Yeah, I know that the conversion between these two motors is far more complex than you might at first think. But before one can seriously consider such a swap it might be smart to identify what the major stumbling blocks are.
Jonathan is offline   Reply With Quote
Old 04-23-2010, 09:00 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
If you use the stock DOHC head gasket the CR is hardly changed at all.
All of this has been covered repeatedly in the Normally Aspirated forum and the Subaru Conversions forum.
Old 04-23-2010, 11:17 AM   #5
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Sounds like these are both great forums to check out.
Old 04-25-2010, 07:33 PM   #6
CastIron
Member#: 191940
I thought that would be the case, but I just wanted to check.
Regarding variation within the EJ25D line, however, I have a couple more questions. First, how does one distinguish the 165hp version (97+ here) from the 155hp version (96 here)? I'd like to avoid inadvertently purchasing the latter. Also, some are designated EJ35DE; what does the DE designate? Lastly, did the 155hp/165hp change happen between 96/97 in other markets as well, particularly the Japanese market?
Old 04-25-2010, 09:25 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Based on my experience and that of someone else on the forum here (I can't remember who it was), the lower power rating seemed to be a matter of the '96 ECU's overly conservative tuning, and not a matter of the mechanicals of the engine. The Ebay engine that I had in my car for a while was an HLA EJ25D and it put down very respectable numbers on the dyno and ran just fine at the couple track days it went to.
As for visually distinguishing the two variants, I think that the HLA engines have "DOHC" in big letters cast across the valve covers, and the non-HLA engines don't. At least, that was the case with mine. That's a pretty small sample size, though, so I can't definitively say that was always the case.
Not sure on the EJ25DE thing. I've seen some listed like that on Ebay, but just chalked it up to incorrect labelling of the engine designation by the vendor.
Pat
Old 04-26-2010, 12:09 PM   #8
CastIron
Member#: 191940
Pat
I was suspicious of the same thing for the "DE" designation.
Out of curiosity, was your Ebay engine USDM or JDM? It seems like most of the cheap ones are JDM. Is there any difference? I just don't want to end up with any extra trouble during install.
Old 04-27-2010, 12:19 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
It was a JDM engine. I don't think I've ever seen one on Ebay that was not a JDM engine. The only somewhat weird thing was that the engine didn't have EGR; the port on the back of the driver side head was there, but it wasn't drilled and tapped, and the intake manifold didn't have any provision for EGR. That meant I popped a CEL for no EGR, but I was constantly resetting CELs anyway (for "misfires" due to the aluminum flywheel) so that didn't really bother me.
Apparently some of the JDM engines have EGR and some don't. Not sure if there's any rhyme or reason to it.
97 LGT front cat replacement? boosted02suby Legacy Forum 2 02-01-2009 01:09 PM
Will Trans out of 97 LGT work in 99 LGT? PLEASE HELP! PrototypeGarage Transmission (AT/MT) & Driveline 2 08-07-2008 02:52 PM
05 lgt motor in 97 lgt what fmic/turbo to use warped-v Legacy Forum 5 04-24-2007 03:46 PM
05 lgt motor in 97 lgt what fmic/turbo to use warped-v Subaru Conversions 1 04-21-2007 05:41 PM
97 lgt- 05 lgt warped-v Subaru Conversions 7 06-05-2006 11:59 AM
