Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 08-25-2011, 02:57 PM   #1
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Default How do you "preserve tires" and still be fast
In regards to racing (both endurance road and rally), what are the professionals doing when they say they are "preserving" or "going easy" on the tires?
Obviously they don't want to slow down, this is a race. On the road, they obviously weren't trying to slide. In rally, the road is the road.
What are they changing in the way they drive that is a "preserving tire" strategy?
chimchimm5 is offline   Reply With Quote
Old 08-25-2011, 03:41 PM   #2
silverhks
Member#: 242402
It's all about not going as fast as you can. Not diving as as deep into the corner before getting on the brakes, not carrying quite as much speed through the corners, not spinning tires on corner exit.
Doing everything just that little bit less on the edge. You are going slower, but not SLOW.
Also known as driving 8-9/10ths instead of all out.
silverhks is offline   Reply With Quote
Old 08-25-2011, 03:58 PM   #3
Rokkit
Member#: 84181
NASA #530 GTS2
Dont slide them.
also included in don't lock up/spin them.
You can still drive at the limit and preserve tires. Watch video of Jensen Button, he's awesome at it.
Rokkit is offline   Reply With Quote
Old 08-25-2011, 04:01 PM   #4
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Smooth driving. Don't bomb into corners and use the turn/understeer to scrub off speed, don't wail it on the way out, press on the brakes instead of slamming them and working the ABS...
Crazy_pilot is offline   Reply With Quote
Old 08-25-2011, 04:41 PM   #5
04trailsti
Member#: 179170
Proper tire pressure, rotation. And alignment but that goes with tire care in general.
04trailsti is offline   Reply With Quote
Old 08-25-2011, 10:37 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Uhhhh... that's not what this thread is about.
Old 08-26-2011, 12:15 AM   #7
ptclaus98
Member#: 87888
1988 Toyota Supra
Boredom Personified
Is it a momentum thing?
ptclaus98 is offline   Reply With Quote
Old 08-26-2011, 12:19 AM   #8
ptclaus98
Member#: 87888
1988 Toyota Supra
Boredom Personified
Originally Posted by Rokkit View Post
Dont slide them.
I'd say Dario Franchitti is the best at it. He's also awesome at saving fuel while being fast, which is the same thing, really.
Old 08-26-2011, 12:48 AM   #9
vicious_fishes
Member#: 158864
2003 GD w/EZ30D swap
by being super smooth.
vicious_fishes is online now   Reply With Quote
Old 08-26-2011, 08:09 AM   #10
04trailsti
Member#: 179170
Yes I stated the obvious about tires but does all that not take part in preserving your tires. Reguardless of how smooth you drive if you dont use incorrect tire pressure etc. they wont last as along
Old 08-26-2011, 09:53 AM   #11
Rokkit
Member#: 84181
NASA #530 GTS2
Tire pressure is more of a traction element on the track... sure you can't run them at 2 psi, but tire pressure on the track has more to do with how the car handles than "wear". Most track wear characteristics come from overheating, sliding, and spinning them.
Old 08-26-2011, 10:33 AM   #12
kfoote
Member#: 39180
2004 WRB STi
Slash Ten - FBHIC
Not so much. If you're trying to save fuel, you want to carry as much speed as possible on corner entry and through the middle of the corner at the potential expense of lateral tire wear. Throttle on is the same for tire wear and savign fuel, but corner entry to mid corner is not.
As mentioned earlier, preserving tires is mostly about driving at 8-9/10ths and minimizing the amount of tire slip and scrub. In cars with more grip than power (Miata, for example), from the time you start applying maintanenece throttle you want to minimize tire slip and scrub anyways to maintain speed, and it does help tire wear.
From the driving I've done, in general, I am harder on brakes and fuel and easier on tires than most people, but it's an easy transition for me if I need to either be easy on the brakes or conserve fuel...it just means I slow down a bit compared to an all-out flying lap.
kfoote is offline   Reply With Quote
Old 08-26-2011, 06:28 PM   #13
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Hmmm.. as I suspected. Ok thanks.
Old 09-01-2011, 12:48 PM   #14
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
One way to preserve tires in stage rally is to pick one step harder compound. You trade off a bit of grip in return for tread blocks staying sharper a bit longer.
Another way to preserve tires in stage rally sounds simple but can be surprisingly hard to accomplish...."don't hit stuff." Some drivers' insistence on cutting corners often adds up to blown tires (or corners getting ripped off the car).
RB5 Clone is offline   Reply With Quote
Old 09-01-2011, 01:26 PM   #15
Lowrider
Member#: 222032
04 STi..Reloaded!!
Howbout Shaving them?...Maybe that's for track dedicated tires and not rally tires.
Lowrider is offline   Reply With Quote
Old 09-02-2011, 12:55 PM   #16
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Monitor the tire temperature and make sure you are not higher than the recommendation. This is of course tied with driving smoothly and not scrubbing.
I like even heating across the whole tire at about 3/4 the max rate. Good wear, great grip.
mick_the_ginge is offline   Reply With Quote
How do you rekindle racism and hatred about slavery? Ask Al Sharpton MK19_ Off-Topic 16 02-26-2007 05:26 PM
How do you shoot women and children? cwb124 Off-Topic 25 06-07-2006 04:34 AM
OT Gun Nuts: How do you deep clean and lube your firearms? Janq Off-Topic 36 03-20-2006 08:26 PM
How do you kill women and childern?? 4x4GGG Off-Topic 7 10-02-2003 02:21 AM
How do you know when timing is being pulled roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-07-2002 07:54 PM
