South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 04-22-2010, 11:25 AM   #1
ArronStump
Member#: 182620
07 sti
Default transmissions?
I dont feel like asking the rest of nasioc and get burned and put down for breathing wrong so I ask you south west...
Im going to by a sti swap, just the motor, ecu, wireing harness and cross member.
My question is does my lil 2.5i have the same trans as the 06/07 wrx's???
I need to buy a heavier duty clutch and if I do have the same ill just get one for the wrx.
I know I know i have to be easy on the transmission, no lauching, no hard sprints from 1st to 2nd. and rev match....Ive done my search, I just need this one question answered.
ArronStump is offline   Reply With Quote
Old 04-22-2010, 12:14 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
As far as I know, the 2.5i trans is not the same as the WRX trans. I know the ratios are different at the least. I'd suspect that it is likely weaker, but I don't know for sure.
EDIT: Subaru Genuine parts lists them as the same price, but without the part numbers to compare, that really means nothing.
I say build it and see what happens. If it blows up, you consider transmission options at that point. You can get a true WRX 5MT for 600-1000 or a 6MT for 3000.
Old 04-22-2010, 03:36 PM   #3
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Ken accepts BJ's and reach arounds as payment.. Only if you smell like cheap hookers perfume and speak with a very deep voice though.
KP is offline   Reply With Quote
Old 04-22-2010, 04:51 PM   #4
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
"they smelled like the perfect mix of vanilla and daddy issues."
AWDshenanigans is offline   Reply With Quote
Old 04-22-2010, 06:34 PM   #5
ArronStump
Member#: 182620
07 sti
thats as far as i got on the price thing...I called dale @ boxer4racing.com and he says he ran 19 psi out his sti swapped GD rs with a stock transmission and a stage 1 organic clutch and it help without slipping so i night go that route
Old 04-22-2010, 07:03 PM   #6
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
You have to keep in mind that the rs weighs 400lbs less then your car. That makes for a lot less stress on the gears
Old 04-22-2010, 07:16 PM   #7
ArronStump
Member#: 182620
07 sti
very true...
Old 04-22-2010, 08:19 PM   #8
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
Exactly, that's the problem, the trans was designed for a car that is 400-500 lbs lighter.
You take any RS/GC bodystyle with a WRX/RS trans and (stock wrx clutch) and less than 300hp and you can beat on it all day. Alot of the major force that would break the trans, is turned into clutch slip (or tire slip).
Imagine the same car with 500 extra pounds of dead weight, plus your body weigh, plus any passengers. A GD WRX with four people weighing between 150-200lbs each is an additional 1000-1200lbs over the weight of an empty RS/GC , for the most part, the same transmission that's in both cars.
"Shock" is actually what breaks a transmission, theoretically you could put 1000hp through a stock trans in a perfect world and the power was delivered smoothly. Shift hard into 2nd gear under almost WOT and you'll blender the gears into dust.
You could use a stock 2.5i trans for quite while with an STI motor. Don't ever launch hard or shift hard or drive around with a lot of weight in the car and your trans will last forever, kinda defeats the purpose of doing the STI swap. What ends up happening is that somoene does a turbo swap into an NA car or an STI motor into a WRX, they drive around for a while, blow up the trans and then have it rebuilt. At that point they've spent enough money and lost money on be able to sell the stock trans to cover the cost of just buying an STI trans in the first place.
Sell stock trans $1000-1200 + buy STI trans = blown trans removal labor + trans rebuild ( and then you run the possibility of needing a rebuild again)
It's not the gears that's the problem, it the case, there's a reason the 6spd case is completely different. I ahd RA gears in WRX box built by dynocomp and I shredded 2nd gear with 310whp and a ACT clutch, but I drive like an idiot.
My advice for guys in your situation (trust me there are plenty and most of us have been there),
1. sell/trade your car and buy a used STI
2. buy a COMPLETE STI swap or a wrecked STI (donor car)
By the time you buy a swap, do the labor and work out all the bugs (are the 2.5i fly by wire?) you might be close to the cost difference of just trading in the car on an STI. The only downside would be the cost of insurance, not sure what you pay now though, might not be that bad.
You're gonna have to do the math out, I don't know how cheap you can get a swap for or how much you know about swaps or how much you can pay someone to do it, who knows you may be able to do it cheaper than everyone else.
If you find a whole donor car or a more complete swap, you can sell your car and just buy a shell and swap everything into the shell instead tearing apart a perfectly good driving car, unless your motor is bad or something, I don't know.
I think I even saw someone selling a shell on here too. That way you could take your time and still have a car to drive.
I personally have an RS coupe shell on the side of my house and I'll wait for a swap to come along instead of paying high dollar for the first one can I find.
bobturismo is offline   Reply With Quote
Old 04-23-2010, 12:59 AM   #9
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
AAron I think you changed the oil in my moms Legacy the other day she was saying something to me about it if I knew you.
Anyways is there a reason you want to swap your car? You have probably heard before what Bob just said but it is the truth. I went down the wrx to sti swap route and spent tons more then if I would have if I bought an sti. Only cool thing is I have a bugeye but if you have a new body style it is little pointless.
If you do not have the funds I suggest saving up or getting a loan cause really you will thank yourself just buying a STi. If you really want to do a swap a lighter shell is the way to go and a lot cheaper.
Smoby is offline   Reply With Quote
Old 04-23-2010, 01:03 AM   #10
Sting_Ray1502
Member#: 188814
2009 Ford Focus
Gold
It shouldn't be much weaker, but the ratios are definitely different. It would be much better for you to just swap in a tranny at the same time.
Sting_Ray1502 is offline   Reply With Quote
Old 04-23-2010, 02:14 AM   #11
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
2007 2.5i Curb weight: 3037 lb
2006 wrx tr Curb weight: 3140lbs
where are you getting 400 lbs from? did you not notice that the above post said GD rs???
SubeSTIle is offline   Reply With Quote
Old 04-23-2010, 03:07 AM   #12
racingfish
Member#: 60976
1969 LGT
FATURBO
sti 3351
ltg wagon 3354
racingfish is offline   Reply With Quote
Old 04-23-2010, 04:42 AM   #13
kpluiten
Member#: 120273
06 WRBWRXWGN
Originally Posted by racingfish View Post
sti 3351
ltg wagon 3354
WTF? What does this have to do with the OP?
Old 04-23-2010, 05:25 AM   #14
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
I must have read right over the who GD part. I was thinking and speaking about the GC.
Old 04-23-2010, 11:11 AM   #15
ArronStump
Member#: 182620
07 sti
it was a GD i think a 04 or an 05. he said he just didint drive a moron and all was well.
Old 04-23-2010, 11:23 AM   #16
ArronStump
Member#: 182620
07 sti
I did have your mom in the shop, all she did was talk about how you waste your money on your car...lol
I agree with you, and i will buy an sti. but ill have this one too and it will be a fun broken project all the time...I can live with that
Sold! Deuce Cam SWIC Private Classifieds 3 06-09-2010 02:56 PM
Are forester transmission 2006 stronger than 06 wrx transmission? 06wrxlbart Transmission (AT/MT) & Driveline 3 09-11-2007 08:39 AM
Wated: Transmission and rear diff for WRX or Transmission for 2.5RS navpo55 Private 'Wanted' Classifieds 0 03-06-2007 09:14 PM
06 WRX Transmission VS. 02 WRX Transmission? 02BlueSuperRoo Transmission (AT/MT) & Driveline 17 08-06-2006 10:27 PM
WRX Transmission VS RS Transmission VEGETA_GT Transmission (AT/MT) & Driveline 3 10-26-2001 11:49 PM
