Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-06-2002, 01:23 AM   #1
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
Default Can you say OUCH!...check it out.
My rebuilt block is back. Here is the pic of the piston that failed. Nasty eh?
hayscoob is offline   Reply With Quote
Old 06-06-2002, 01:25 AM   #2
hayscoob
Member#: 4544
Bone Stock for now
Here is a pic of the block after the pistons, O-rings and rods etc.
Old 06-06-2002, 01:41 AM   #3
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Phew! That piston got toasted! But your new block looks immaculate, nice. How much was the rebuid?
Good Luck with it after you get it all back together and on your car.
Paul
PaulRex is offline   Reply With Quote
Old 06-06-2002, 02:00 AM   #4
hayscoob
Member#: 4544
Bone Stock for now
Paul,
The rebuild cost about 2800 bucks. It included new custom forged 8.5:1 pistons, chromoly forged shot peened rods, knife edged balanced crank and O-rings. Of course it also came with a perfomance bearing kit for the rods and stronger wrist pins. All I need is some top end work and I will be able to run gobbs of boost. That is when I get the tranny rebuilt later on. I plan on running about 12-15 lbs of boost if the valves can handle it. I may have to shoot for lower boost if they can't handle it.
Paul...
Old 06-06-2002, 02:00 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
hmmm...detonation anyone?
Old 06-06-2002, 02:43 AM   #6
homegrownxt
Member#: 17659
Hey Paul,
The block looks good. Can't wait til you get that installed and take it out for a test burn. Maybe we can find that guy with the del sol and mess around with him.lol:
Kenny
homegrownxt is offline   Reply With Quote
Old 06-06-2002, 08:58 AM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Damnit! I think you blew off a bigger piece of piston then I did last time. I guess I'm just going to have to try harder this time.
Nice looking block, BTW.
Old 06-06-2002, 09:00 AM   #8
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
upgrading the valve springs and retainers at least?
Jon
omahasubaru is offline   Reply With Quote
Old 06-06-2002, 10:02 AM   #9
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
$2800 for all that stuff? I want some names Hayscoob!
The block looks incredible. Did you have to have the block bored or did you use standard bore pistons?
Graham
Graham is offline   Reply With Quote
Old 06-06-2002, 12:13 PM   #10
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
That looks EXACTLY like my piston did.
Eric
Eric SS is offline   Reply With Quote
Old 06-06-2002, 12:17 PM   #11
zaidallas
Member#: 4106
So who assembled the new block ? I'm assumin these are JE pistons but who makes the rods ? pauter ?
zaidoun
zaidallas is offline   Reply With Quote
Old 06-06-2002, 01:51 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
god damn...2800 for that lil bit of work?? i'm in the wrong field *shrug*
Old 06-06-2002, 02:59 PM   #13
RallyNavvie
Member#: 7113
2008 Spec B
I can't believe how small the skirts are on our pistons. I don't suppose the forged ones look any better do they?
~Garrett
RallyNavvie is offline   Reply With Quote
Old 06-06-2002, 04:23 PM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Garrett - Nope. There is only like 3-4mm of clearance below the piston at BDC between the skirt and the bottom of the cylinder bore.
You wanna stroke a 2.5L motor? It better be destroking.
Old 06-06-2002, 07:19 PM   #15
Brood
Member#: 3886
2011 STi Sedan
Mancream White
hayscoob, so did you determine that the cause of the problem was a lean condition in cylinder 3? Would a parallel fuel modification have helped?
Brood is offline   Reply With Quote
Old 06-06-2002, 10:41 PM   #16
hayscoob
Member#: 4544
Bone Stock for now
Graham: The block was bored out to 30 over. The cylider wall of #4 needed it. These pistons were special ordered to fit my application. Shelf pistons wouldn't have worked. I think I already told you who did the work. If not PM me.
8complex: After looking at your pic of your piston, I wondered what mine was gonna look like. I almost craped my pants when I saw it. The piece of piston that broke off did considerable damage to the piston as it tossed around in the combustion chamber.
zaidallas: The pistons are indeed JE. The rods are Pauter.
RallyNavvie: The skirts are small but they have what appears to be a Teflon coating on them. I can't believe how thin the pistons are above the first ring landing. I can see why it would be weak at the valve releif area. The material is very thin there. Seems to be a weak point and when they go they go there i assume.
Brood: I have yet to determine what caused the "problem". I think I spiked some how. There also may have been a time prior to the major failure that the ring landing simply cracked and eventually broke. Ironically, the #3 cylinder was not the one that broke. It was #4. To make it even more interesting, the #4 cylinder is the one that gets fuel first with the stock fuel delivery. I think the Parallel fuel rail mod may have prevented this, then again maybe not. If I spiked on boost, there may have been now way to combat the problem. Another theory I have is boost creep. Perhaps with the high compression motor and crappy 91 octane gas, the exhaust velocity at the wastegate may have overwhelmed the wastegate. Who knows. I pray it doesn't happen again. I am putting faith in my new motor and TEC III to handle the job.
homegrownxt: When it's done you will know it. I have a 1000 mile break in with low low boost. When done I will creep the boost up till I hit 300+ hp// should be about 12 lbs of boost. I think I will be around 330 lbs of torque too, I hope. When I get the TECIII tuned by Shiv, he will dyno tune it when his Dyno is up and running. Till then I can only shoot in the dark about the true fugures on HP and Torque. Wish me luck buddy....
omahasubaru: The bank account is drained from this project so far, not to mention that my mother has been suffering from Stage IV Metastic Breast Cancer. I have been funding some of her issues with her health and her health is my highest priority right now. When I begin to recover from all of this financialy, I plan on having the heads done up. But I will get the transmission hopped up first. I will just have to learn to keep the boost low till I am ready. 300+ HP is enough to shoot for, for now. I t will be comforting to know I can cram more boost into my motor and be way safer doing it now. I am glad it is nearly done. This has beena nightmare to deal with. Getting the parts and waiting for them is a big huge PAIN IN THE ASS! No body has pistons in stock for what happened to my block. I had to get them made to fit after I had the cyliders honed. I think I have a 2.6 liter moter now. Maybe more???
Paul...
Old 06-06-2002, 11:53 PM   #17
zaidallas
Member#: 4106
hayscoob : check your pm
zaidoun
Old 06-07-2002, 03:14 AM   #18
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
why would you have shiv tune a tec 3?? it's got the wintec software to help you learn how to tune it yourself *shrug*
Old 06-07-2002, 04:06 AM   #19
hayscoob
Member#: 4544
Bone Stock for now
He will have his 4 wheel dyno up and running soon and after one blown engine, I don't want to make any more mistakes.
Paul...
Old 06-08-2002, 01:38 AM   #20
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
It's always #4, and lit ooks just like my #4 piston did.
That's a shame about your Mom. I'll keep her in my prayers...
ImprezaRS dot com is offline   Reply With Quote
Old 06-08-2002, 01:47 AM   #21
Brood
Member#: 3886
2011 STi Sedan
Mancream White
Why is it always #4, it shouldn't be a lean fuel condition right?
Old 06-08-2002, 01:16 PM   #22
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Personally I believe that #4 gets the lowest fuel pressure in the stock lines. Previously it was #3 thought to do that, but I think that is quite wrong.
Take for instance jellybeans rolling down a channel. Since they're already moving at a regulated speed (regulated at the bottom), if you pull one out near the regulator, the rest above it move faster down to compensate and fill the gap. Take three along the line, see how fast the top section moves at that point.
Now I believe it's Bernoulli's principle that states that velocity is inversly proportional to pressure. Meaning, the faster something flows, the less pressure that is behind it.
So since the #4 injector has 3 injectors pulling fuel out between it and the regulator, it naturally has the highest velocity of fuel going by it, thus the lowest pressure.
Old 06-08-2002, 11:39 PM   #23
hayscoob
Member#: 4544
Bone Stock for now
Wow 8, that's an interesting theory. It make total sense. Kind of like an old fashioned perfume bottle with the bulb that you have to squeeze. That would translate into lower fuel pressure at the first junction based on how much fuel and the velocity of the fuel traveling past the first hole. This would be easy to duplicate with clear tubes to see just how bad the effect is. I would like to see it in action. Good thinking dude!
Paul...
Old 06-08-2002, 11:41 PM   #24
hayscoob
Member#: 4544
Bone Stock for now
Larry, thanks for your kind words about my mother. My nerves are shot these days. On a good note, I just asked my girl to marry me and she said yes. So, I am officially semi hitched.
Paul...
Old 06-09-2002, 01:35 AM   #25
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Congrats Man!!
8, seeing that our cars obviously have a some sort of detriment in the fuel line system, I devised somewhat of my own Fuel Line Mod. This is not parallel, all I did was simply add a fuel line into the mix. I mentioned this a few months back, but no one seemed to care. Since then, I have documented the entire Fuel Line Mod, and it is posted on the main page over on RS25.com.
Here's the link:
http://www.rs25.com/_How%20To/Fuel%20Rail%20Mod.cfm
Just on a side not, my J&S Sensor is placed DIRECTLY above cylinder #4, so it hears everything that goes on inside, plus a little more. On a hot day, it might pull 4 degrees, and at night it harldy pulls any timing (this makes me happy). I am running 4 psi with around 66 psi fuel press. on boost.
Graham
The Only Brake Thread, that has ALL you need! Come Check it out for yourself! RallySport Direct RMIC Vendor Classifieds 5 01-07-2010 01:39 PM
The Only Brake Thread, that has ALL you need! Come Check it out for yourself! RallySport Direct Suspension/Brakes/Handling 1 12-17-2009 12:33 PM
can you say ouch? Blackaxela General Community 46 08-24-2007 11:55 PM
check it out...check it out...my pics from detroit :D shukes24 Mid West Subaru Owners Club Forum -- MWSOC 7 01-24-2001 10:01 PM
Slightly OT: But you have to check it out! ^Dream_weaveR^ General Forum Archive 1 12-12-2000 04:25 AM
