Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 04-23-2010, 04:24 PM   #1
wrex19
Member#: 238811
2006 wrx wagon
Default waste gate malfunction help!
The code of p0244 ( waste gate solinoid malfunction) keeps coming up. How do I fix this and how much will it cost me?
wrex19 is offline   Reply With Quote
Old 04-23-2010, 04:50 PM   #2
jay25RS
Member#: 4273
2011 GR-STI
& 2015 Legacy Ltd.
replace it with a GrimmSpeed EBCS and get a tune... better performance and problem solved!
jay25RS is offline   Reply With Quote
Old 04-23-2010, 04:53 PM   #3
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Is it just the code? Or also cutting out?
wrxdrvr is offline   Reply With Quote
Old 04-24-2010, 12:35 PM   #4
wrex19
Member#: 238811
2006 wrx wagon
I'm only hitting 11.5psi with a stage 2 tune ( should be hitting 15.2) and if i drive it hard the check engine light comes on and the code is po244 which is waste gate solenoid malfunction
Old 05-04-2010, 07:38 PM   #5
bwilliams373
Member#: 210785
Your car wants (and is capable) of a few more psi boost... the map you are using is set at a peak boost level but the parameters are most likely somehow allowing boost and wastegate action to produce a bit more than its supposed to... check out how I fixed mine
http://forums.nasioc.com/forums/show....php?t=1982882
bwilliams373 is offline   Reply With Quote
Old 05-04-2010, 07:42 PM   #6
Cobb Tuning
Member#: 4803
You probably have a faulty solenoid or the wastegate could be stuck or not functioning properly. Can you post a datalog so we can see what is going on. Log WGDC, boost, rpm, throttle position etc. Let's take a look at what is happening.
Travis
COBB Tuning
External Waste Gate install help johnlattanzi Newbies & FAQs 23 03-17-2010 10:05 AM
waste gate DP... none waste gate UpPiPe...?? yub2da Newbies & FAQs 1 02-13-2006 04:44 PM
leaking waste gate help! Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-07-2004 02:46 PM
How far does the waste gate open anyways? jaxscuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 06-19-2002 08:03 PM
Preloading waste gate WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-23-2002 05:03 AM
