Old 04-23-2010, 06:50 PM   #1
Sobe185
Member#: 186508
2005 WRX
Default Stage 2 HWG... worse?
I'll start with saying I'm not supper savvy with tuner gear. That said:
[edit: Both pulls started in 2nd and went through 3rd]
[double edit: List of related mods: Nvidia DWG downpipe, Cobb Catback, TurboXS Uppipe (with flex joint). Exhaust is fully catless. STI TMIC, SPT Short Ram intake.
The other day I noticed that I had some error codes, 3 of which being O2 sensor related. Sense I hadn't bothered to check for those since I'd flashed it roughly a year ago... I have no idea how long they'd existed. So, I reflashed with Stage 2 and they cleared up.
With much excitement to my noticible increase in power (as my A/F must have been FUBAR), a buddy and I went and ran her through 2nd and 3rd. The results included 15.2 peak boost tapering off to around 11.5.
Now: I decided I would flash the Stage 2 HWG to attempt getting closer to that 16.5 +/- .7, and when I recently datalogged the 2nd and 3rd gear pulls, I noticed one thing in common. 14.9 PSI Max @ roughly 4500 RPM, tapering to 12.18 @ 6600 RPM.
I did JUST flash it to Stage 2 HWG before.. but to the same token, I had JUST re-flashed to Stage 2 when I got 15.2.
Any Ideas / Help would be appreciated.
Here's my logs.
Seconds (sec),RPM (RPM),Ignition Adv. (),Dynamic Adv. (),Boost (PSI),Wastegate Duty (%),MAF Voltage (V),Fuel Trim (Long) (%)
0.00,2097,39.00,0.00,-7.98,0.00,1.88,-3.12
0.14,2081,39.00,0.00,-7.98,0.00,1.88,-3.12
0.31,2094,39.50,0.00,-7.98,0.00,1.90,-3.12
0.45,2116,39.50,0.00,-7.83,0.00,1.90,-3.12
0.62,2099,39.50,0.00,-7.83,0.00,1.98,-3.12
0.76,2114,39.00,0.00,-7.25,0.00,2.00,-3.12
0.95,2148,36.00,0.00,-3.19,9.41,2.42,-3.12
1.15,2158,33.00,0.50,-1.45,18.82,2.48,-3.12
1.32,2183,26.50,3.50,0.00,25.09,2.52,-3.12
1.48,2233,27.50,5.50,0.87,31.36,2.58,-3.12
1.63,2330,26.50,6.00,1.74,40.77,2.64,-3.12
1.79,2394,21.00,7.00,2.32,47.04,2.68,-3.12
1.95,2468,22.50,7.50,3.34,56.45,2.74,-3.12
2.11,2495,21.50,8.00,3.77,62.72,2.82,-3.12
2.27,2611,19.50,7.00,4.35,72.13,2.86,-2.34
2.43,2680,19.00,7.00,5.22,78.40,2.94,-2.34
2.59,2708,17.50,7.00,5.95,84.67,2.98,0.00
2.74,2836,17.00,7.00,6.96,84.67,3.12,0.00
2.90,2953,17.50,8.00,7.83,84.28,3.20,0.00
3.04,3003,16.50,8.00,8.85,84.28,3.30,0.00
3.21,3153,16.00,8.50,10.44,83.89,3.40,0.00
3.36,3241,15.50,9.00,11.46,83.89,3.48,0.00
3.52,3381,14.00,8.50,12.18,83.50,3.54,0.00
3.67,3524,14.00,8.50,12.47,83.50,3.56,0.00
3.83,3649,13.50,8.00,12.76,83.50,3.62,0.00
3.98,3816,13.50,7.50,13.20,83.10,3.72,0.00
4.11,3904,14.00,7.50,13.34,82.71,3.74,0.00
4.31,4102,15.00,7.50,13.63,82.71,3.80,0.00
4.46,4232,15.50,8.00,13.49,82.32,3.82,0.00
4.60,4347,16.00,8.50,13.49,81.93,3.82,0.00
4.77,4437,16.00,8.50,13.34,81.54,3.94,0.00
4.90,4661,16.00,9.00,13.63,81.14,3.98,0.00
5.08,4789,16.50,9.00,13.78,80.75,4.00,0.00
5.25,4892,17.50,9.00,13.92,79.97,4.06,0.00
5.39,5050,18.50,8.00,13.92,76.44,4.08,0.00
5.56,5200,19.00,7.50,13.63,73.70,4.12,0.00
5.69,5357,20.00,8.00,13.49,73.30,4.16,0.00
5.89,5458,20.00,8.50,13.34,73.30,4.18,0.00
6.04,5601,21.50,9.00,13.05,73.30,4.20,0.00
6.20,5685,21.50,8.50,12.91,73.30,4.22,0.00
6.35,5868,23.00,8.00,12.76,72.52,4.22,0.00
6.48,6014,23.50,8.00,12.47,71.74,4.26,0.00
6.68,6062,23.50,8.00,12.33,67.42,4.24,0.00
6.83,6260,27.00,8.50,11.89,59.58,4.28,0.00
6.99,6323,27.50,8.50,11.46,57.62,4.26,0.00
7.14,6432,28.00,9.00,11.31,57.23,4.26,0.00
7.27,6255,11.00,0.50,-6.24,0.00,2.36,0.00
7.47,6107,11.50,0.00,-9.72,0.00,1.94,-0.78
7.62,5751,11.50,0.00,-10.01,0.00,2.14,-0.78
7.78,4550,20.00,7.50,2.61,46.65,3.60,0.00
7.93,4675,4.50,10.50,7.69,52.92,3.82,0.00
8.09,4649,19.00,11.00,11.02,59.19,3.94,0.00
8.25,4708,19.00,11.00,12.33,68.60,3.96,0.00
8.40,4819,19.50,11.50,12.62,74.87,3.94,0.00
8.56,4870,19.00,10.50,12.91,81.14,3.98,0.00
8.71,4889,17.50,9.00,13.34,81.54,4.00,0.00
8.85,4993,18.00,8.50,13.78,81.54,4.04,0.00
9.04,5043,17.50,8.00,14.36,81.54,4.10,0.00
9.22,5140,18.50,8.00,14.50,81.54,4.14,0.00
9.38,5190,19.00,7.50,14.36,81.54,4.16,0.00
9.56,5244,19.00,7.50,14.36,81.54,4.18,0.00
9.73,5341,20.00,8.00,14.21,81.54,4.18,0.00
9.89,5376,20.00,8.00,14.21,81.54,4.20,0.00
10.04,5411,20.00,8.50,14.07,81.54,4.20,0.00
10.18,5502,20.50,9.00,14.07,81.54,4.22,0.00
10.36,5534,21.00,9.00,13.92,81.54,4.22,0.00
10.54,5651,21.50,9.00,13.78,81.54,4.22,0.00
10.69,5729,22.50,8.50,13.63,81.14,4.24,0.00
10.89,5795,22.50,8.00,13.63,80.75,4.22,0.00
11.06,5827,22.50,8.00,13.49,81.14,4.26,0.00
11.20,5845,23.50,8.00,13.34,80.75,4.26,0.00
11.37,5928,23.00,8.00,13.20,80.75,4.26,0.00
11.50,6062,23.50,8.00,13.05,80.36,4.26,0.00
11.69,6043,23.50,8.00,12.91,80.36,4.28,0.00
11.83,6167,24.50,8.00,12.91,79.58,4.30,0.00
11.98,6147,24.50,8.00,12.91,79.58,4.28,0.00
12.17,6234,27.00,8.00,12.91,79.18,4.30,0.00
12.30,6307,27.00,8.50,12.76,79.18,4.30,0.00
12.49,6339,27.00,8.50,12.62,79.18,4.32,0.00
12.63,6372,27.50,8.50,12.47,78.79,4.32,0.00
12.78,6410,28.50,9.00,12.47,78.40,4.30,0.00
12.97,6544,28.50,9.00,12.33,78.01,4.30,0.00
13.10,6527,28.50,9.00,12.18,76.83,4.30,0.00
13.30,6355,11.50,0.00,0.73,0.00,1.86,-0.78
13.45,6188,11.50,0.00,-10.30,0.00,2.04,-0.78
13.59,5919,11.50,0.00,-10.01,0.00,2.14,-0.78
13.76,5534,11.50,0.00,-10.30,0.00,2.14,-0.78
13.89,5255,11.50,0.00,-10.44,0.00,2.14,-0.78
14.08,4957,11.50,0.00,-10.30,0.00,2.14,-3.12
14.22,4752,11.50,0.00,-10.15,0.00,2.10,-3.12
14.37,4393,11.50,0.00,-10.15,0.00,2.02,-3.12
14.56,4185,11.50,0.00,-11.31,0.00,1.54,-3.12
14.69,3995,11.50,0.00,-10.30,0.00,1.92,-3.12
14.89,3759,11.50,0.00,-10.44,0.00,1.84,-3.12
15.04,3584,11.50,0.00,-10.44,0.00,1.76,-3.12
23.79,3504,35.00,0.00,-3.77,15.29,2.56,-2.34
23.94,3556,35.00,0.00,-3.77,16.07,2.58,-2.34
24.10,3564,34.50,0.00,-3.48,17.25,2.64,-2.34
24.25,3581,34.00,0.00,-1.74,18.42,2.82,-2.34
24.41,3603,33.00,3.00,-0.87,18.42,2.86,0.00
24.57,3660,30.50,4.00,0.73,18.42,2.98,0.00
24.72,3712,27.50,5.50,2.18,19.60,3.10,0.00
24.88,3774,26.00,8.00,3.48,25.09,3.28,0.00
25.03,3858,24.50,9.00,6.09,31.36,3.40,0.00
25.17,3968,22.00,8.00,7.40,37.63,3.46,0.00
25.36,4082,19.50,8.00,8.56,47.04,3.58,0.00
25.55,4213,17.50,7.00,9.57,56.45,3.68,0.00
25.71,4300,17.50,8.00,10.15,62.72,3.70,0.00
25.89,4422,18.50,10.00,11.02,72.13,3.82,0.00
26.04,4539,18.00,9.50,11.89,78.40,3.92,0.00
26.20,4678,16.50,9.00,13.05,81.93,3.98,0.00
26.35,4798,17.50,9.00,13.92,81.54,4.04,0.00
26.49,4973,18.00,9.00,14.36,81.54,4.10,0.00
26.64,5047,19.00,8.00,14.36,81.54,4.14,0.00
26.83,5165,20.00,7.50,14.21,81.54,4.16,0.00
26.98,5307,20.00,8.00,14.07,81.54,4.18,0.00
27.12,5450,21.00,8.50,13.92,81.54,4.20,0.00
27.31,5601,22.50,9.00,13.78,81.54,4.24,0.00
27.47,5747,22.50,8.00,13.34,80.75,4.26,0.00
27.62,5809,24.00,8.00,13.34,80.36,4.26,0.00
27.77,5961,24.00,8.00,13.05,79.18,4.28,0.00
27.91,6162,25.00,8.00,12.62,67.03,4.28,0.00
28.10,6239,27.50,8.00,12.47,66.64,4.30,0.00
28.26,6355,28.50,8.50,11.31,57.62,4.28,0.00
28.40,6250,42.50,0.00,-5.22,7.84,2.62,0.00
28.59,6048,11.50,0.00,-8.99,0.00,1.88,-0.78
28.75,5725,11.50,0.00,-10.15,0.00,2.16,-0.78
28.90,5349,15.50,0.00,-8.70,20.38,2.50,-2.34
29.06,4427,27.00,0.00,-5.08,21.56,2.86,-2.34
29.21,4561,35.00,0.00,-3.77,21.95,2.90,0.00
29.35,4567,19.50,0.00,-3.34,21.56,2.90,0.00
29.50,4501,38.50,0.00,-6.24,20.78,2.38,-0.78
29.70,4477,11.50,0.00,-9.57,0.00,2.10,-2.34
29.83,4466,11.50,0.00,-10.15,0.00,2.06,-2.34
30.00,4437,11.50,0.00,-10.59,0.00,2.00,-2.34
30.14,4464,11.50,0.00,-10.73,0.00,1.86,-2.34
30.33,4429,11.50,0.00,-11.17,0.00,1.76,-2.34
30.49,4373,11.50,0.00,-11.60,0.00,1.64,-2.34
30.64,4330,11.50,0.00,-11.75,0.00,1.64,0.00
30.78,4307,11.50,0.00,-11.75,0.00,1.62,0.00
30.93,4322,11.50,0.00,-11.75,0.00,1.60,0.00
31.08,4283,11.50,0.00,-11.75,0.00,1.70,-1.56
31.22,4263,11.50,0.00,-11.60,0.00,1.64,-2.34
31.41,4266,11.50,0.00,-11.75,0.00,1.64,0.00
31.57,4215,11.50,0.00,-11.75,0.00,1.62,0.00
31.72,4237,11.50,0.00,-11.75,0.00,1.60,0.00
31.87,4206,11.50,0.00,-11.75,0.00,1.62,0.00
32.01,4161,15.50,0.00,-11.60,19.99,1.66,0.00
32.19,4180,39.00,0.00,-11.02,19.99,1.92,-0.78
32.34,4139,42.50,0.00,-10.73,19.99,1.94,-2.34
32.55,4118,42.50,0.00,-10.73,19.99,1.96,-2.34
32.69,4145,42.50,0.00,-10.59,19.99,1.98,-2.34
32.87,4161,38.00,0.00,-2.61,26.26,2.98,-2.34
33.04,4194,30.00,3.50,0.00,32.54,3.12,0.00
33.20,4187,27.00,8.00,2.61,38.81,3.36,0.00
33.35,4210,20.00,8.00,7.54,48.22,3.66,0.00
33.49,4297,18.00,9.00,10.15,54.49,3.76,0.00
33.67,4355,17.50,9.00,11.31,63.90,3.78,0.00
33.85,4416,17.50,9.00,11.60,73.30,3.82,0.00
34.04,4488,16.50,8.00,12.47,79.58,3.90,0.00
34.20,4548,16.50,8.00,13.49,82.71,3.96,0.00
34.35,4620,16.50,8.00,14.65,82.32,4.02,0.00
34.49,4649,16.50,8.50,14.94,82.32,4.02,0.00
34.66,4728,17.00,9.00,14.94,82.32,4.04,0.00
34.79,4789,17.50,9.00,14.94,82.32,4.06,0.00
34.97,4860,18.50,9.00,14.79,82.32,4.08,0.00
35.15,4924,18.50,8.50,14.79,82.32,4.10,0.00
35.30,5057,18.50,8.00,14.79,82.32,4.12,0.00
35.51,5129,19.00,8.00,14.65,82.32,4.14,0.00
35.65,5190,19.50,7.50,14.50,81.93,4.18,0.00
35.82,5277,20.00,7.50,14.50,81.54,4.18,0.00
35.96,5292,20.50,8.00,14.36,81.93,4.18,0.00
36.12,5353,21.00,8.00,14.36,81.93,4.20,0.00
36.26,5450,21.00,8.50,14.36,81.93,4.22,0.00
36.45,5522,21.00,9.00,14.21,81.93,4.24,0.00
36.59,5551,22.00,9.00,14.07,82.32,4.24,0.00
36.76,5639,22.50,9.00,13.92,81.93,4.24,0.00
36.92,5703,22.50,8.50,13.78,81.54,4.24,0.00
37.07,5742,22.50,8.00,13.63,81.54,4.26,0.00
37.21,5818,23.00,8.00,13.49,81.14,4.28,0.00
37.35,5882,24.00,8.00,13.49,81.14,4.26,0.00
37.55,5966,24.00,8.00,13.34,80.75,4.28,0.00
37.70,6038,24.50,8.00,13.20,80.36,4.28,0.00
37.91,6077,25.00,8.00,13.05,79.58,4.30,0.00
38.07,6172,25.00,8.00,12.91,78.40,4.30,0.00
38.24,6224,25.00,8.00,12.91,76.83,4.32,0.00
38.39,6270,27.50,8.00,12.76,76.44,4.30,0.00
38.55,6355,28.50,8.50,12.62,75.26,4.32,0.00
38.70,6388,28.50,9.00,12.62,74.09,4.32,0.00
38.84,6426,28.50,8.50,12.47,72.91,4.34,0.00
39.02,6504,28.50,9.00,12.33,72.91,4.30,0.00
39.20,6550,29.00,9.50,12.18,73.70,4.32,0.00
39.33,6631,29.50,9.50,12.18,74.48,4.30,0.00
39.50,6625,29.50,9.50,12.18,74.87,4.30,0.00
39.64,6714,29.50,10.50,12.04,75.66,4.30,0.00
39.84,6768,29.50,10.50,12.04,76.05,4.32,0.00
40.01,6842,30.00,10.00,11.60,54.49,4.32,0.00
40.17,6684,11.50,0.00,-6.24,0.00,1.88,0.00
40.34,6493,11.50,0.00,-10.30,0.00,2.00,-0.78
40.52,6234,11.50,0.00,-10.15,0.00,2.14,-2.34
40.70,4832,11.50,0.00,-10.30,0.00,2.12,-2.34
40.87,4892,11.50,0.00,-10.01,0.00,2.12,-2.34
41.02,4832,11.50,0.00,-10.01,0.00,2.12,-2.34
41.16,4789,11.50,0.00,-10.15,0.00,2.10,-2.34
41.29,4801,11.50,0.00,-10.44,0.00,2.04,-2.34
Sobe185 is offline   Reply With Quote
Old 04-23-2010, 08:48 PM   #2
Sobe185
Member#: 186508
2005 WRX
a little bump for a little help
Old 04-24-2010, 11:37 AM   #3
Sobe185
Member#: 186508
2005 WRX
bump..
Difference between Stage 2 and Stage 2 HWG KDX AccessPort 8 08-11-2009 03:34 AM
Anyone ran 1/4 mile with Cobb stage 2 and stage 2 HWG map? txl146 Engine Management & Tuning 2 05-15-2005 09:08 AM
Cobb Stage 2 HWG??? txkellers Engine Management & Tuning 6 04-24-2005 05:16 PM
water injection and cobb stage 2 HWG map feels good !! phamster Water/Methanol Injection, Nitrous & Intercooler Cooling 11 04-23-2005 04:01 PM
Cobb stage 2 HWG map WRXVII Engine Management & Tuning 1 08-25-2004 08:53 AM
