Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 11-27-2013, 05:37 PM   #1
pasths
Member#: 113878
2004 STi
Default Wheel Bearing Bad??
I've ready plenty of threads, but most tend to lean towards noise rather than movement in the wheel for bad bearings.
My front passenger wheel (04 STi) I can move fairly easily from top to bottom and side to side - not a ton of movement but enough to be sure it's not normal. The rotor assembly is moving with the wheel as well - I did double check the lugs.
I knew I had to check due to weird vibration where it literally felt like the wheel was wobbling though it felt like driver side was wobbling. Vibration only occurs on highway when moving to a left lane. Other than the left lane switches the suspension feels solid.
Side note - I just had a whiteline sway and endlinks installed in the front - coincidence or possibly related??
Thanks!
pasths is offline   Reply With Quote
Old 11-27-2013, 05:49 PM   #2
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Check to make sure the movement is not the tie rods or ball joint.
If not then most likely its the bearing.
Bikelok is offline   Reply With Quote
Old 11-27-2013, 10:22 PM   #3
JeffGarrett
Member#: 371799
1993 Impreza WRX
I'd say for sure your bearing. I had the same problem, not the vibrations while driving, but ever tight right turn (like a U-Turn) i could hear a grinding/squealing noise, from the front right wheel. So since im in college for automotive i put it up on a hoist and checked how much movement there was. As suspected, there was quite alot of slop, even the left wheel was pretty darn bad. Checked with my instructor and he agreed as well. Replaced the bearings today, both the front cause why not? Noise is gone . Price of both front bearings, 2 inner seals and 2 outer was $130 so not to shabby.
JeffGarrett is offline   Reply With Quote
Old 11-28-2013, 12:57 AM   #4
Back Road Runner
Member#: 60082
2004 Forester STI
They don't really move. They're pretty mechanically constrained. They mostly just get noisy be it small irregularities or major failure. The whir just gets louder and louder or if in the event of heavy failure, metal on metal squeal. You don't really get any play until you loosen the nut.
Back Road Runner is offline   Reply With Quote
Old 11-29-2013, 10:17 PM   #5
Web Foot STi
Member#: 39086
2004 STi
Try re-torquing the axle nut. If that doesn't work I'd schedule a bearing replacement. Much easer to do when you want than when the car needs it.
P.S.: You're scarring me.
Web Foot STi is offline   Reply With Quote
Old 11-30-2013, 10:34 AM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I've read accounts of WB failure with no signs.. just boom gone..
Swap wheels with another corner first and see if it follows
Old 11-30-2013, 04:20 PM   #7
Schikane
Member#: 337700
2013 WRX
Ice Silver Metallic
Spin the wheel while holding the spring, if you can feel a vibration then its a wheel bearing. This is how I've checked for them in the past.
Schikane is offline   Reply With Quote
