Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-24-2010, 04:40 PM   #1
Ryan314
Member#: 82989
Hybrid EJ257
Default Tuner is asking me what compression I am using.
Doing a usual brand new EJ257 short block with 2.0 heads, using STi head gaskets. Tuner is asking me what compression I am using. Sorry if this sounds newb, but is he asking for my compression test numbers on all 4 cylinders? This is first time around on this stuff, help me out!
Ryan314 is offline   Reply With Quote
Old 04-24-2010, 04:44 PM   #2
modaddict
Member#: 95840
sold to a good bud
awaiting next car
compression test or compression ratio?
Are you using stock pistons?
If he needs compression test numbers then...........you need to do a compression test. Not sure why he needs these unless he wants to verify your engine is in good working order.
If he wasnts compression ratio..........we need to know which pistons you're using. I can understand why he wasnts to know this.
modaddict is offline   Reply With Quote
Old 04-24-2010, 04:46 PM   #3
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
He is wanting you to do a compression test it sounds like. You are going to need one of these...
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
And doing this on our cars is a real pita, because of the position of the engine/body.
And like modaddict said above, I really don't understand why he would want this. Compression ratio makes more sense.
2006whitesti is offline   Reply With Quote
Old 04-24-2010, 05:16 PM   #4
Ryan314
Member#: 82989
Hybrid EJ257
I've got a compression tester, that's not an issue. If that's what he needs it's no issue. I emailed him again to clarify. What's going on is my tuner isn't local, so he's gonna send me a base map to break-in my new block until I can get down to him for a complete road tune.
Yes, I'm using the stock EJ257 pistons, so what would my compression ratio be?
Old 04-24-2010, 05:27 PM   #5
dr3w
Member#: 222318
1993 RHD GC8
He wants to know your compression ratio I guarantee you it, he couldn't care less about your cylinder compression pressure.
dr3w is offline   Reply With Quote
Old 04-24-2010, 05:28 PM   #6
Ryan314
Member#: 82989
Hybrid EJ257
How do I figure my compression ratio?
Old 04-24-2010, 05:41 PM   #7
prometheum
Member#: 92003
04 bicycle!
uuh just tell him what pistons you're running, what headgasket you've got and what heads you're using...any competent subaru tuner should be able to figure it out.
prometheum is offline   Reply With Quote
Old 04-24-2010, 05:44 PM   #8
Ryan314
Member#: 82989
Hybrid EJ257
Ok thanks. He says he's all set.
Since everyone Is asking. "The what car is Bogus Getting" Thread. BlackSnake Mid West Subaru Owners Club Forum -- MWSOC 191 07-06-2007 08:20 PM
Wifey asked me what tax software to get... C-daleRidr Off-Topic 20 02-24-2005 08:28 PM
Go ahead, ask me what I did for my friends 21st bday... huckedup16 Off-Topic 11 12-02-2004 11:46 AM
My friend just asked me what "ricing out a car" means CandyO Off-Topic 21 11-13-2003 01:32 PM
tell me what exhaust i am asking for... DangeRS Normally Aspirated Powertrain 9 08-19-2001 07:04 PM
