Old 04-24-2010, 05:59 PM   #1
craig007
Member#: 161507
2008 WRX 5 Door
Question Knock Correction question...Noob here.
So I got my AP last week and installed it per installation instructions. I am running an SPT CBE and ditched the K&N drop-in for a normal flowing paper filter. Stock motor otherwise, 4EAT tranny. I have been driving the car conservatively, never over 4K RPMS. My question is, what is acceptable for the knock correction? I have seen as low as -6.7 (today, climbing a decent hill, 3rd gear, 4k RPM and groceries in the back ). I have done some research here and on the Cobb Forums, but maybe I am a missing something. Usually with normal driving, I get around -1.4 or so. Using the Stage 1 91 tune with Sunoco 93 Octane gas. Thanks.
Craig
craig007 is offline   Reply With Quote
Old 04-25-2010, 09:55 PM   #2
craig007
Member#: 161507
2008 WRX 5 Door
No one has any ideas? I know it's probably a new guy type of question. Just don't want to hurt the family grocery machine. Thanks.
Old 04-25-2010, 11:31 PM   #3
norcalwrx816
Member#: 203489
03 wrx wagon
flat4/Mayhem Tuning!
yeah your using stage 1 91 use stage 1 93 map
norcalwrx816 is offline   Reply With Quote
Old 04-29-2010, 06:51 AM   #4
flatthump
Member#: 102749
2005 impreza STi
OBP'
It depends on 100 other things. You need a log so we can view a lot of crucial factors that have an affect on the danger related to knock.
If you don't have a custom tune I'm not surprised.
flatthump is offline   Reply With Quote
Old 04-29-2010, 07:34 AM   #5
ohm
Member#: 178468
2007 UGM STI
IAG Built
Under normal driving conditions (non-boost low RPM) the ECU will reduce timing for a number of reasons, one of them being to maximize fuel economy. I wouldn't be concerned, it is perfectly acceptable. If you are seeing this in the high RPM range while under boost, then I would investigate further. If your IAM were to drop, then I would be concerned.
ohm is offline   Reply With Quote
Old 04-29-2010, 01:46 PM   #6
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
Use the right map with the right Gas.
91oct with ACN Stg1 91 Map
93oct with Stg1 93 Map.
Kupkake is offline   Reply With Quote
How come I Can't see feedback knock correction, fine learning knock correction? AraSh Open Source Reflashes 23 01-08-2014 08:04 PM
Knock Correction Question maherbaz Engine Management & Tuning 0 10-13-2009 05:49 PM
noob here with a noob question about this thread junkboxer Engine Management & Tuning 14 01-05-2006 12:11 AM
EcuTek knock correction question LiquidForce Engine Management & Tuning 28 03-26-2005 12:34 PM
Timing, knock correction, and other questions root Engine Management & Tuning 18 07-26-2004 07:24 PM
