Old 04-24-2010, 10:19 PM   #1
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Default So i needed a shelf for the radio, shop fab
yea, this is totally random fab but still fun
So i needed a shelf to hold my little radio as i wanted it off my bench, as bench space is at a premium in my little garage.
so i started off with a piece of 20 ga alu sheet i had laying around
Since this was really thin metal i figured i would make it stronger. and i need this to be uber light weight :LOL: so i drilled holes, and just to go that extra step i decieded to dimple them also
i also cut the corners some to keep me from cutting myself. i just used some simple tin snips.
and after i used my box break to bend the sides and back.
and installed in the corner, i set it up to just mount on the wall but figured i would try it in the corner, seemed to work very well. also happend to hit two studs so that worked out perfect.
PARANOID56 is offline   Reply With Quote
Old 04-24-2010, 10:19 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
anybody make randome crap? if so post up
Old 04-25-2010, 11:49 AM   #3
Chris_Lee
Member#: 110667
2006 WRX
Nice! A few rows of rivets to give it that aircraft sheet metal look would've looked cool.
Chris_Lee is offline   Reply With Quote
Old 04-25-2010, 12:15 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
good point. might think about doing that as i do have a crap load of rivets laying around LOL
Old 04-25-2010, 12:18 PM   #5
2:43AM
Member#: 190273
05 WRX evoIII-16G
Taking otherwise useless scrap and making something useful is always a plus! Better than junking it. Great job!
2:43AM is offline   Reply With Quote
Old 04-25-2010, 12:30 PM   #6
Bob the fabricator
Member#: 104246
I love dimple dies...parts just look cooler made with them!
I built my tubing bender from some leftover scraps primarily (the base anyway), and needed a linkage to actuate the recycled hydraulic pump. So I used some sheetmetal and tubing to create this:
Which after some paint and assembly became this:
Bob the fabricator is offline   Reply With Quote
Old 04-25-2010, 12:50 PM   #7
PARANOID56
Member#: 22035
2003 Brocoma DCab
wow, nice job, and man, puts my bender to shame. i did a HF air/hydro conversion on my protools HD bender. I love the linkage setup on that. very smart.
Old 04-25-2010, 01:03 PM   #8
Bob the fabricator
Member#: 104246
Thanks. I had a manual Pro Tools bender for about 17-18 years and it just wore out at all the pivots.
I bought a JD2 Model 4 and decided to upgrade to full hydraulic using some stuff I had laying around which I scavenged from some industrial machinery that was being thrown away. I figured I saved $1800 compared to buying their own full hydraulic setup. I've used air-over-hydraulic before but I like the fact that the full hydraulic works quite a bit faster.
Old 04-25-2010, 01:16 PM   #9
PARANOID56
Member#: 22035
2003 Brocoma DCab
yea, thats the worst part is how slow the air over hydroulic is. but at a cost of 60 bucks i cant complain. beats pulling the bar and having to hard mount the bender. i wish i could find a full hydro setup for under 100bucks as that is so much faster. but since i am just a home fab guy dont need to much speed
Old 04-27-2010, 12:21 AM   #10
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
What tool do you use to put those dimples in the metal?
BeBop86 is offline   Reply With Quote
Old 04-28-2010, 08:30 AM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Uh......
Old 04-28-2010, 01:58 PM   #12
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
I must have missed that part.
Old 04-28-2010, 04:32 PM   #13
Deathclutch
Member#: 232012
i noticed one day that the shops computer was sucking in alot of dust and grinding particles.. so i made this up!
Deathclutch is offline   Reply With Quote
Old 04-28-2010, 11:32 PM   #14
tobylazur
Member#: 150289
2006 SV650N
1972 Travelall
are you guys using pre-made dimple dies, or are you making your own?
tobylazur is offline   Reply With Quote
Old 04-29-2010, 01:07 AM   #15
PARANOID56
Member#: 22035
2003 Brocoma DCab
i bought my set. but you can pick up cheap steel ones on ebay now for cheap. i have one of them and wile not as strong as my good set, it works just fine.
Old 04-29-2010, 03:41 AM   #16
tobylazur
Member#: 150289
2006 SV650N
1972 Travelall
I have a skid plate I'm thinking about putting a few lightening holes in, and I'm thinking about making something that would work instead of buying a full set.
Old 04-29-2010, 11:04 AM   #17
PARANOID56
Member#: 22035
2003 Brocoma DCab
you can, if you have a lathe and time it should be easy. but for 30 bucks for one, i didnt feel it was worth my time LOL
Old 04-29-2010, 11:40 AM   #18
Bob the fabricator
Member#: 104246
FWIW, I got my JMR chromoly dimple dies from VanSant Enterprises. I like them because they are seriously overkill. I've flared 10 gauge steel repeatedly with them and they still look perfect (gotta grease the dies to prevent scratching however). Cheaper dies cannot comfortably flare material thicker than 16 ga I've found, and even then they wear out quickly.
I've even found that if you anneal it first, you can flare 3/16" 6061-T65 aluminum sheet.
Old 04-29-2010, 04:07 PM   #19
PARANOID56
Member#: 22035
2003 Brocoma DCab
this is exactly right. i also bought the same ones from the same place LOL those ones are pure beef. the cheap ebay ones look the same but are of much softer material. i bought 2 ebay ones to fill the gaps i have in my full set and since i only use them on thin stuff they have been fine. havent tried any 10ga with them though
STI cluster gauge swap into wrx...everything works sept for the radio mike739wrx Interior & Exterior Modification 7 06-02-2009 12:24 AM
what is the part # for the radio/gauge pack housing SQC120 Car Audio, Video & Security 10 11-24-2005 10:01 PM
i made ATHF sweepers for the radio alacrity024 Off-Topic 1 08-19-2004 06:10 AM
Question for the Radio Controlled Car People Corn-Picker Off-Topic 10 07-01-2004 10:39 PM
Need More input for the shop! HiFiWRX North West Impreza Club Forum -- NWIC 8 06-11-2003 04:27 PM
