Welcome to the North American Subaru Impreza Owners Club Tuesday October 21, 2014
Old 04-08-2010, 01:46 AM   #1
jlangv2
Member#: 235375
1996 impreza brightn
Default ej18 to ej22t swap help
i have a subaru impreza brighton with the 1.8l and just bought a ej22t to swap in,i dont have the wiring/ ecu for the 2.2turbo. can i use the 1.8 wiring and ecu to run the 2.2? can i use the 1.8 harness and a boost controller or something for the turbo? and what all do i need to get this to work from what i have read that i wil need a new clutch/ fly wheel for the turbo motor. what else will i need? sorry for the newbie questions but ty for your help.
ty, john
jlangv2 is offline   Reply With Quote
Old 04-08-2010, 02:50 AM   #2
gene4ace
Member#: 108210
yup just get the ecu connectors from a legacy 90-94(some honda and mitsu also) and just merge the harness pins from one connector to the next, also adding the 7-8 wires to control the rest of the new stuff an ej22t has
4th wire for throttle sig, knock sensor, 3 wires for map sensors , 2 wires for boost control, maybe another one but im still in process myself of this swap, also the cam/crank sensor wires get switched over on the turbo models
ps also an Ignition signal to the keep alive memory pin with a diode or else the car will not start
gene4ace is offline   Reply With Quote
Old 04-08-2010, 10:39 PM   #3
jlangv2
Member#: 235375
where can i find ecu connectors?
Old 04-12-2010, 07:39 AM   #4
STIdreamer17
Member#: 68853
'02 WRX
junk yard?
STIdreamer17 is offline   Reply With Quote
Old 04-28-2010, 11:02 PM   #5
DrunkenDragon
Member#: 21471
bumpppp
Can u just swap over the 1.8 intake on the block and heads?
DrunkenDragon is offline   Reply With Quote
EJ22 to EJ20 swap HELP!!!! 96SubyImpreza Built Motor Discussion 3 09-20-2007 03:25 PM
EJ22 to EJ22T swap Jutboy Normally Aspirated with bolt-on Forced Induction Powertrain 32 03-06-2007 10:36 PM
EJ18 to EJ25 swaps with 4EAT? redwagon Subaru Conversions 11 10-18-2006 06:01 PM
Ej18 to ej25 swap, idle issue Qaveboy Subaru Conversions 0 05-30-2006 02:18 AM
EJ22T Swap Help seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 50 02-18-2003 03:30 PM
